XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > General Computer Hardware
Reply
Old 01-02-2007, 02:43 PM   #1
bigKr33
future project
I have a pretty sick idea for a media/gaming rig. I don't plan on doing for 6-12months from now, but it does involve lian li's new pc-343b cube case. I'm inspired by the new design and have deemed it a good base for my new future project that i will most likely call "PowerRig5000". The budget will be $5k no more no less.
This is whats stumping me, supposdly the new lian li cube case can support two motherboards inside of it. I would have my media rig on one side and the gaming on the other. I would have dual monitor display and the gaming rig would be liquid cooled. I want to base this project around amd's long awaiting quad core 65nm beast. Sli is an option, and about 2terabytes of storage between the gaming rig and media machine. The media machine will not be sli, but it would however have a blu-ray, and hd-dvd all in one.
I love all the ideas (and believe me i can go on), but i don't know officially if the lian li cube case can hold two motherboards with minimal modding because i did see that there is only slot brackets on one side of the case which means no dual motherboard support. This project has been floating around in my head for about a week and it seems like it would a pretty fun project.
Any thoughts or downside to this project, just need to know the possibilities which i think are just about endless.
__________________
Gaming PC
In planning stages...
Living Room
46" Sony Bravia XBR4 | Xbox 360 Elite | Arcam AVR-600 rcvr | Paradigm studio 60's v.5 (fronts) bi-amp'd | Paradigm studio cc-590 v.5 (center) bi-wired | Paradigm studio 10's v.5 (rear) | Velodyne optimum-12" sub | Richard Gray 400 pro power conditioner | Analysis oval-12 speaker cable
Heatware
bigKr33 is offline   Reply With Quote
Old 06-21-2007, 12:14 PM   #2
Glitch4583
My sergeant just pointed this case out to me today. If you look at the back, it only has an I/O for one motherboard. Unless there's something I can't find about mod back-plates, it will only handle one (Look at the back of the case). Right now, I'm looking at having a gaming/server machine. Liquid cooling equipment on one side, hadware on the other with tubing running back and forth between the two sides.
Glitch4583 is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
