XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme > Xtreme Mods > Xtreme Motherboard Vmods
Reply
Old 01-02-2007, 12:57 PM   #1
before
reaching perihelion
before's Avatar
Send a message via MSN to before
Biostar TForce P965 Vdroop?
Hi guys;
I'm looking for the Vdroop mod of the Biostar TForce P965 Deluxe / PT...
__________________
Best Regards,
Xavier
"I prefer to fly alone... when alone, I perform those little coups of audacity which amuse me..." Col. René Fonck (1894-1953), the Ace of Aces.
before is offline   Reply With Quote
Old 01-02-2007, 01:45 PM   #2
Quentin
Quentin's Avatar
t'as trouvé le vmch ?
Quentin is offline   Reply With Quote
Old 01-02-2007, 04:16 PM   #3
celemine1Gig
IT Engineer in the making
celemine1Gig's Avatar
Send a message via ICQ to celemine1Gig
VCore controller chip used on the board?
__________________
celemine1Gig is offline   Reply With Quote
Old 01-03-2007, 07:43 AM   #4
before
reaching perihelion
before's Avatar
ISL6322CRZ http://www.intersil.com/data/fn/fn6328.pdf
@Quentin: non pas encore; effectivement, le Vdroop est plus important
__________________
Best Regards,
Xavier
Old 01-03-2007, 11:37 AM   #5
celemine1Gig
Please measure resistance between FB and IDROOP.
If I'm not mistaking, droop is regulated through a resistor and capacitor network between these pins, according to the datasheet.
__________________
Old 01-03-2007, 12:50 PM   #6
quent
quent's Avatar
Yes, I think so too.
So, add an variable resistor between FB and Idroop would solve this Vdroop issue.
Let's find easy access point linked to these FB and Idroop pins and fnd the good trimmer value thanks to the resistance there is between this 2 points.
I'll make a graph
Quentin
__________________
Cooling : Waterchiller, Cascade and ~100L LN˛
Hardware : Many things !
quent is offline   Reply With Quote
Old 01-03-2007, 02:08 PM   #7
before
reaching perihelion
before's Avatar
Thx so much to both of you
I'll make the measure tomorrow.
__________________
Best Regards,
Xavier
Old 01-04-2007, 01:31 AM   #8
before
reaching perihelion
before's Avatar
So, I've measured FB to IDROOP diff and I always found 0.4ohm...
I've tried measuring directly from the controler, but also from external points.
__________________
Best Regards,
Xavier
Old 01-04-2007, 05:31 AM   #9
quent
quent's Avatar
God damnit
__________________
Old 01-04-2007, 09:12 AM   #10
celemine1Gig
Seems as if the idroop pin is directly connected to the fb pin. Looks as if it would be best to find the feedback resistors for each phase and change these. Will have a look at that soon.
__________________
Old 01-04-2007, 09:45 AM   #11
celemine1Gig
OK, had a look. Please measure resistance between VDIFF (pin#16) and FB (pin#14).
__________________
Old 01-04-2007, 12:26 PM   #12
before
reaching perihelion
before's Avatar
Difference between FB and VDIFF is 2.12Kohm.
__________________
Best Regards,
Xavier
Old 01-04-2007, 02:57 PM   #13
celemine1Gig
Try and connect a 100K trimmer potentiometer, set to maximum resistance, between FB and VDIFF. Trimming it down should decrease vdroop.
Edit: 50K should also work.
__________________
Old 01-05-2007, 12:34 AM   #14
before
reaching perihelion
before's Avatar
Ok;
based on the same pic; does that make sense? Guess I'm right, but I prefer to ask prior doing wrong things...
__________________
Best Regards,
Xavier
Old 01-05-2007, 02:35 AM   #15
celemine1Gig
Looks good to me, but I don't own the board, so I can just judge from the pic. Now connect the VR between these solder points and hopefully vdroop will decrease when fine-tuning the resistance. At least according to the datasheet it should, as R(fb) needs to be decreased because [Vdroop = I(avg) x R(fb)].
__________________
Old 01-05-2007, 04:09 AM   #16
before
reaching perihelion
before's Avatar
Yea of course Thx so much for your input.
I'll do that ASAP.
__________________
Best Regards,
Xavier
Old 01-05-2007, 04:32 AM   #17
quent
quent's Avatar
I had a look at the datasheet, and indeed that should work
I'd rather use 50k trimmer :
__________________
Old 01-05-2007, 05:15 AM   #18
quent
quent's Avatar
__________________
Old 01-05-2007, 06:05 AM   #19
before
reaching perihelion
before's Avatar
First time I see the same solder point for both Vcore and Vdroop mods.
__________________
Best Regards,
Xavier
Old 01-05-2007, 07:40 AM   #20
Misko
Misko's Avatar
Before did u try it? No problems with both vcore&vdrop mod?
p.s. Does anybody know where are the readpoints for vmch&vcore?
__________________
Born to overclock
Misko is offline   Reply With Quote
Old 01-05-2007, 08:41 AM   #21
T07N
didn't even know that was possible...
__________________
E6600 @ 3.2ghz (400x8), P5B Deluxe, 2GB Ballistix DDR2-1000 @ 600mhz 5-5-5-15, X1950 Pro, Antec Neo HE 500w
T07N is offline   Reply With Quote
Old 01-05-2007, 10:38 AM   #22
quent
quent's Avatar
Please post a pic of the socket area.
__________________
Old 01-06-2007, 09:18 AM   #23
before
reaching perihelion
before's Avatar
The Vdroop mod is working perfectly!
Thx both celemine1Gig & Quent for your help
__________________
Best Regards,
Xavier
Old 01-06-2007, 09:25 AM   #24
quent
quent's Avatar
Nice to hear, let's have a look at the MCH one !
__________________
Old 01-06-2007, 09:40 AM   #25
quent
quent's Avatar
I bet the red circled controller is the VDDRII one, and the yellow could be the Vmch one.
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
