XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > General Computer Hardware
Reply
Old 12-17-2006, 11:36 AM   #1
bigKr33
xbox 360 controller (pc)
First let me say YES i do have the pc version of the xbox 360 controller and YES i have the software installed. My problem is, is that it will not calibrate properly. I went into the control panel settings and went to "game controllers" window and it still would not function properly.
I do not know what to do and i'm about to throw the controller off the 24th floor of my condo.
Thanks in advance.
__________________
Gaming PC
In planning stages...
Living Room
46" Sony Bravia XBR4 | Xbox 360 Elite | Arcam AVR-600 rcvr | Paradigm studio 60's v.5 (fronts) bi-amp'd | Paradigm studio cc-590 v.5 (center) bi-wired | Paradigm studio 10's v.5 (rear) | Velodyne optimum-12" sub | Richard Gray 400 pro power conditioner | Analysis oval-12 speaker cable
Heatware
bigKr33 is offline   Reply With Quote
Old 12-17-2006, 12:16 PM   #2
Soulburner
Just deleted over 900 PMs
Soulburner's Avatar
It won't matter whether its labeled as the "PC version" or not because its the same one they package with the system.
What exactly is it doing? Tried uninstalling/reinstalling the driver? Unplug/replug the USB cable?
__________________
Desktop:
NZXT Zero
Central Processing: ABIT IP35 Pro / Core 2 Duo E6850 @ 3.6Ghz / 4GB G.Skill F2-8000CL5D-4GBPQ
Cooling Station: Enzotech Ultra-X / Sharkoon Silent Eagle 120mm / Modded IP35 Pro Heatsink System
Storage Subsystem: WD Raptor 150GB / WD Caviar 640GB / WD GP 1TB / Samsung 18x DVD-R/RW
Networking Department: D-Link DIR-655 / Realtek Gigabit NIC
Visual Processing and Display: EVGA GTX 260 896MB Superclocked / BenQ 24" 1920x1200 LCD
Tonal Processing and Delivery: Auzentech X-Fi Prelude / Onkyo TX-SR304 / Athena S.5 5.1 / Velodyne VX-10
Peripheral Input: Razer Deathadder / Logitech LX710 / Steelseries 5L
Power Delivery: Corsair 620HX / APC BX1300LCD UPS
Midnight Blue Dell Inspiron 1720
Core 2 Duo T7500 @ 2.2Ghz
4GB PQI PC6400
NVIDIA 8600M GT 256MB @ 625/1250/1024
WD Scorpio 250GB (5,400RPM)
17" 1920x1200 LCD
< Nikon D300 >
Soulburner is offline   Reply With Quote
Old 12-17-2006, 05:48 PM   #3
bigKr33
yes ive done exactly what u said and still no luck
__________________
Gaming PC
Living Room
Heatware
Old 12-17-2006, 06:35 PM   #4
Celcius
Celcius's Avatar
Try this:
uninstall the software
unplug the controller
re-install the software
turn off pc
plug in controller and power up
The manual says to install the software before plugging in the controller, so that could be the problem.
__________________
Intel Q9650 @ 3.906Ghz (9x434, 1.224v) w/ Tuniq Tower
Asus Maximus II Formula @ 1736 fsb (bios 1901)
4GB dual-channel Corsair Dominator pc8500 @ 1084Mhz & 5-5-5-15-2T 2.1v
EVGA GeForce GTX 285 @ 722/1476/1351 & 75% fan speed
PC Power & Cooling Turbo-Cool 1 Kilowatt psu
X-Fi Xtrememusic + Logitech X-530 + Audio Technica ATH M20
dual Seagate Barracuda SATA2 250GB 7200rpm 16MB buffers
Dual Lite-On LH-20A1S's
CoolerMaster Stacker 830 Evolution
Logitech MX518, Alienware keyboard, xbox 360 controller
Asus VH236H 23" widescreen lcd
Windows 7 Professional x64
Celcius is offline   Reply With Quote
Old 12-17-2006, 07:41 PM   #5
bigKr33
hate to this, but I did that too. man I guess im SOL.
__________________
Gaming PC
Living Room
Heatware
Old 12-18-2006, 03:13 AM   #6
Soulburner
Soulburner's Avatar
WinXP w/SP2?
__________________
Desktop:
NZXT Zero
4GB PQI PC6400
17" 1920x1200 LCD
< Nikon D300 >
Old 12-18-2006, 07:50 AM   #7
Celcius
Celcius's Avatar
Originally Posted by Soulburner
WinXP w/SP2?
You don't need SP2, I'm only running SP1
__________________
Old 12-20-2006, 01:05 PM   #8
XenatR
SOL means 'Sh1t On LAN'
are you at lan? :o
XenatR is offline   Reply With Quote
Old 12-20-2006, 01:41 PM   #9
NickS
I am Xtreme
NickS's Avatar
No, it means s*** out of luck
I'd try installing SP2. Who runs SP1 anyway?
__________________
C2D E7200 @ 3.6GHz, 1.31v
Stock Q6600 HS/F
MSI P45 Neo3-FR
G.Skill 4GBPQ 8000's
Sapphire HD3870 Toxic 512MB
WD3200AAKS Single Platter
Enermax Liberty 500w
X-Fi XtremeMusic
CoolerMaster CM590
Vista Home Prem. X64 SP1
Westinghouse L2410NM
Logitech MX500, Saitek Eclipse, Logitech G25
NickS is offline   Reply With Quote
Old 12-20-2006, 01:44 PM   #10
phi|os
phi|os's Avatar
Run Vista, you don't even need to install drivers, already embedded
__________________
ASUS P5B-D WiFi
e6600 @ 3.40GHz
Corsair DDR2-800 2x1GB
Sapphire ATI X1900XTX
Scythe Infinity w/ FCG's mod
1 74GB WD Raptor HDD
2 x 250GB Samsung SP2504C HDD
OCZ 700W GameXtream PSU
Thermaltake Armor w/ side fan
Soon to be retired.
phi|os is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
