XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme > Xtreme Overclocking
Reply
Old 12-13-2006, 02:41 PM   #1
before
reaching perihelion
before's Avatar
Send a message via MSN to before
E6600 @4926MHz under BEFORE's cascade
[System]
E6600 L627B156 OEM
Quent's Biostar P965 TForce Deluxe bios 914 Rebels Heaven mod (Vcore, Vdimm mods)
Quent's Team Xtreem TXDD2048M800H C4DC
Windows 2k3 Server (tweaked)
Western Digital IDE 80Gb
2-Stager @ -100C unloaded
I've tried this golden E6600 under cascade today. This amazing chip did OCCT stable at 3708MHz @1.320V watercooled...
I was limited by the Biostar which can't go over the 540FSB range; but the E6600 ran nicely with 1.73V idle to 1.71V loaded DMM (1.80V bios) and could definitely scale above without an issue...
[Suicide CPU-Z]
[Super Pi 1M]
As can be seen, speedfan wasn't able to show the temps for an unknown reason. I didn't really play with timings (instead of the RAS to CAS write set to 2, tRP set to 3 and tRAS set to 4); other are SPDs. That means the time isn't the fastest I can acheive.
A better board is required to push that bad boy to higher skies. If one of you has a P965 C2 revision board to sell...
I would like to thank Quent for the board and the memory, and watercooling.fr for the chip.
Thx for reading!
__________________
Best Regards,
Xavier
"I prefer to fly alone... when alone, I perform those little coups of audacity which amuse me..." Col. René Fonck (1894-1953), the Ace of Aces.
before is offline   Reply With Quote
Old 12-13-2006, 02:59 PM   #2
Extera
Extera's Avatar
Send a message via MSN to Extera
another powerfull chip limited by the motherboard
nice clocking, we need 600+ fsb (see my sig)
Extera is offline   Reply With Quote
Old 12-13-2006, 03:08 PM   #3
boblemagnifique
Xtreme X.I.P.
boblemagnifique's Avatar
Send a message via ICQ to boblemagnifique Send a message via AIM to boblemagnifique
Great score my friends
Good cpus of WC.Fr
__________________
OCM Member / IXTREMTEK Admin !!
DDR1 2*256 BH5 Adata @324.7Mhz 1.5/2/2/5 1T at 4v @318.6Mhz Benchs
DDR2 1*512 Kingston Pc8500 @702Mhz 5/5/5/18 at 2.42v réel
DDR2 2*1024 Cell Shock Pc8000c4 @534Mhz 3/3/3/8 at 3.5v réel
Cooling : XP90C , Big Typhoon , waterchiller R507 , LN2 ....
boblemagnifique is offline   Reply With Quote
Old 12-13-2006, 03:22 PM   #4
afireinside
I am Xtreme
afireinside's Avatar
Send a message via AIM to afireinside Send a message via MSN to afireinside
Nice results BEFORE How do you like that BIOSTAR board? Was near 550 fsb hard to get?
__________________
Phenom II 940 BE / ASUS M4A79 / HD5770
3808mhz CPU 2720mhz NB | DDR1088 5-5-5-15 | 975/1300
afireinside is offline   Reply With Quote
Old 12-13-2006, 03:26 PM   #5
Spacemaster
Spacemaster's Avatar
Send a message via MSN to Spacemaster
I think that is CPU Wall,not FSB.Nice score bay the way.
__________________
Spacemaster is offline   Reply With Quote
Old 12-13-2006, 03:28 PM   #6
jmax_oc
jmax_oc's Avatar
Héhé very good score
jmax_oc is offline   Reply With Quote
Old 12-13-2006, 03:38 PM   #7
Extera
Extera's Avatar
some Biostars realy fly (like syngrows @ 585fsb) but some just suck.
If more Vcore (like from 1,7 to 1,8v does not help 1 little mhz of fsb, then you are limited by the board.
But i'm quite sure you already knew that :P
Old 12-13-2006, 03:56 PM   #8
before
reaching perihelion
before's Avatar
Thx guys!
@bob: yeah, these chips are hell of clockers
@afireinside: getting 420FSB bootable was impossible with original bios; but newer bioses help a lot (actual benching was performed with 530FSB set into the bios). It wasn't really difficult. Actually, the only noticable issue is to set the Vcore above 1.7V bios (which corresponds to something like 1.63V... I guess). The board fails to reboot properly but after turning off and then turning on manually it works fine.
@spacemaster: You can believe me dude, it's a motherboard wall. I've tried with different chips that were able to climb over this range on another motherboard but the Biostar always stopped in the 540FSB's no matter the chip.
@jmax: Thx!
@Extera: you'r right buddy! A better board is the solution now
__________________
Best Regards,
Xavier
Old 12-13-2006, 03:57 PM   #9
jmax_oc
jmax_oc's Avatar
Before, 4-4-4-4 is faster than 4-4-3-4 on P5B Dlx.
Maybe same for Biostar (same chipset)
Old 12-13-2006, 04:05 PM   #10
before
reaching perihelion
before's Avatar
I tried this after cpull suggested it but I saw no difference... BTW I may have done something wrong.
__________________
Best Regards,
Xavier
Old 12-13-2006, 04:12 PM   #11
jmax_oc
jmax_oc's Avatar
The difference is little but is real.
Old 12-13-2006, 04:13 PM   #12
before
reaching perihelion
before's Avatar
I'll give it a try again
__________________
Best Regards,
Xavier
Old 12-13-2006, 04:20 PM   #13
afireinside
I am Xtreme
Hmm may give one a shot.
__________________
Old 12-13-2006, 05:04 PM   #14
Eldonko
Eldonko's Avatar
Very nice before, hellofa cpu.
__________________
Eldonko is offline   Reply With Quote
Old 12-14-2006, 03:13 AM   #15
before
reaching perihelion
before's Avatar
Thx Eldonko
@jmax: Boot with 4-4-3 (as suggested to me by cpulloverclock) and then 4-4-4 set thx to memset gave me 10.422s instead of 10.390s with boot with 4-4-4 and 4-4-3 set thx to memset...
How do you guys manage to get faster times with 4-4-4? I believe you , and my guess is we can't really compare our times and timings because we don't use the same memory management and other registery changes. To my own experience some dword values have an effect on how timings react with Spi times.
__________________
Best Regards,
Xavier
Old 12-14-2006, 04:03 AM   #16
Bootup05
Xtreme Cruncher
Bootup05's Avatar
How comes cpuz is showing your 6600 only having 1 Core?
Bootup05 is offline   Reply With Quote
Old 12-14-2006, 04:09 AM   #17
before
reaching perihelion
before's Avatar
You can disable a core with boot.ini
__________________
Best Regards,
Xavier
Old 12-14-2006, 06:03 AM   #18
Misko
Misko's Avatar
@before maybe board isn't limiting factor, my Biostar on AIR, 1.35, 1.3 voltage for vmch&vfsb:
p.s. I have scrshots with fsb 560.
Misko is offline   Reply With Quote
Old 12-14-2006, 06:08 AM   #19
Misko
Misko's Avatar
Sorry I see yours Biostar is C1, my 965PT is C2, so I think also board is limiting u.
Old 12-14-2006, 07:39 AM   #20
before
reaching perihelion
before's Avatar
You'r a lucky guy I'm trying to find one of those P965 C2 boards which seem very FSB friendly.
__________________
Best Regards,
Xavier
Old 12-14-2006, 07:44 AM   #21
NiCKE^
NiCKE^'s Avatar
Send a message via ICQ to NiCKE^ Send a message via MSN to NiCKE^
Most P5B-E Plus boards are C2.
__________________
Intel FTW!
Beanna
NiCKE^ is offline   Reply With Quote
Old 12-14-2006, 08:03 AM   #22
jmax_oc
jmax_oc's Avatar
Most or all of them ?
Old 12-14-2006, 01:01 PM   #23
before
reaching perihelion
before's Avatar
As far as I know, Misteroadster tested 4 of them and all were C2... 3 were Prime stables @590FSB That's F***ing amazing!
__________________
Best Regards,
Xavier
Old 12-14-2006, 05:14 PM   #24
Misko
Misko's Avatar
Not all of them, I think 1.02 and up
Old 12-15-2006, 01:40 PM   #25
Leon2ky
Send a message via AIM to Leon2ky Send a message via MSN to Leon2ky Send a message via Yahoo to Leon2ky
VERY nice overclock
__________________
[-AMD Opteron 165 @ 3.0Ghz-]
[-DFI LAN Party UT uNF4 Ultra-D-]
[-AData 4GB (4x1GB) DDR484-]
[-eVGA Geforce 8800GTS 640MB 320-Bit-]
[-Creative Sound Blaster X-Fi XtremeMusic-]
[-Seagate 160GB & 250GB 16MB Cache SATA300-]
[-OCZ GameXStream OCZ700GXSSLI-]
[-DELL 2005FPW LCD Monitor via DVI-D- & Westinghouse 22w3 LCD Monitor via DVI-D]
[-Windows Vista Ultimate x64-]
Leon2ky is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
