12-11-2006, 07:08 PM
#1
2 Loops versus 1 loop with 2 rads?
I am slowly putting together my new system in my mind and I am certainly going to upgrade my MCR220 to 320.
Thermochill is out of the question, because nobody who ships internationally is stocking it right now, and nobody who sells second hand wants to ship int. So that leaves me with one move - the second best.
I will also be buying a DDC18w/Petras top to replace my noisy D5.
Now, I don't want to just throw away my MCR220 - but it's not exactly going to sell for very much and if I pay shipping to the states or europe, I will lose money on the sale.
So that leaves me with two possibilities:
1. Single loop - two rads: Res->DDC2w/Petras->MCR320->MCR220->CPU Block->GPU Block->Chipset Block
OR
2. Dual loop: Res->DDC2w/Petras->MCR320->CPU->Chipset AND Res->D5->MCR220->GPU
Which would you recommend? One means buying 2 resevoirs which is a pain (I want to replace my leaky switchtech mcres with some of the nice EK ones) but if it yields better performance, then why not?
As it stands, I won't be using a very high restriction loop. Most likely candidates for blocks are Apogee, MCW60/Apogee-1U, MCW30 so perhaps the first loop with a single res and that powerful pump wouldn't suffer from the restriction caused by the second rad.
What are your opinions?
__________________
"Language cuts the grooves in which our thoughts must move" | Frank Herbert, The Santaroga Barrier
i7 920 3924A 205x21 / 4315 | 4870x2 | EVGA M-ATX X58 | 6GB Corsair Dominator | Corsair HX1000 | Intel X25-M 160 G2 | OCZ Vertex 60 | WD 320 || Apogee XT - XSPC FC | (2)DDC3.2 | (2)PA 120.2 | (2)BI SR-1 120 || MM H2G0
12-11-2006, 09:33 PM
#2
2nd one for sure if performance matters. forget res, get 2 t-lines and 2 caps for them. much easier for filling/bleeding.
12-11-2006, 10:03 PM
#3
Yulp 2# Loops is better.
__________________
Dfi Ultra-D XP4000-LCBBE 0643SPMW.(Topless) Evga 8800gts. OCZ700GX 2#Raptor2's-raid0All kind's of stuff I forgot to list. Storm Rev2, MCP655,PA120.3. 310X10 @1.54vid 1-1 2.5-4-4-8,ect 24/7 Allways clockin'' up and tryin' to trim voltages
LP-B XP-M2600,OCZ pc4800 plats.6800gt apogee, maze5,d5,mcr220 252X10- 24/7
Don't mind me folks I was just lurkin' about again. And thought I'd drop my 2 cents.
12-11-2006, 10:45 PM
#4
I find reservoirs easier to bleed my self. No turning the case upside down and what not.
With Eddie's res's, I plan on drilling a circular hole in the top so the cap sticks out just a bit which would make for very easy filling.
So I suppose the consensus is #2 then. How much of a performance difference are we talking about between options #1 + #2?
A great advantage to option 2 is that I can replace my GPU/CPU systems independently without having to drain the entire thing. A big plus for me seeing as I'm always fiddling with mounts and stuff. When I still had my 165 on water, I must've remounted about 10 times within 2 months...
Time to figure out how to fit an MCR320+220 inside a Lian-Li PC-007...
__________________
12-14-2006, 07:21 PM
#5
Ok, as it stands, I don't think I will be able to mod the Lian-Li PC-007 (PC-60 size) to accomodate two loops.
I'll be able to have a single loop with two rads, but I can't find a place to put two pumps, particularly since the triple rad will lie along the bottom eliminating practically all surface space. I'm not even sure where I will put 1 pump, but I'll figure that one out.
Would a DDC2w/Petras be able to handle this setup:
MCR320>MCR220>Apogee>Maze4/MCW60>MCW30>EK Res>DDC2
Without running into flow troubles? I doubt it will, as it's a powerful pump but I'm just searching for a second opinion. I don't have the space to use two loops so I'm going to have to make it 1 loop.
EDIT: Hmm, perhaps it's just a better idea if I ditch the 220 and go for a single 320 set-up.
__________________
12-14-2006, 08:53 PM
#6
Considering you're on a C2D ,and an x1600, I'd say leave the 220 in the closet for now, untill your next build. The 320 should do just as good a job by itself. Once you start to OC the E6300, then throw 220 in.
__________________
12-15-2006, 05:23 PM
#7
Hmm?
This is for my rig I'm building:
E6600/Xeon 3060
8800GTX
P5B-DLX
__________________
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
