XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > General Computer Hardware
Reply
Old 12-09-2006, 02:25 PM   #1
bigKr33
water cooling 8800gtx?
I want to water cooling my 8800gtx when i get it, but i don't know what to do for cooling the ram modules on the card. I have a reference pick of the ram sinks swiftech used on there website, but theres 4 other ramsinks that i don't know where to find thats on the card.
__________________
Gaming PC
In planning stages...
Living Room
46" Sony Bravia XBR4 | Xbox 360 Elite | Arcam AVR-600 rcvr | Paradigm studio 60's v.5 (fronts) bi-amp'd | Paradigm studio cc-590 v.5 (center) bi-wired | Paradigm studio 10's v.5 (rear) | Velodyne optimum-12" sub | Richard Gray 400 pro power conditioner | Analysis oval-12 speaker cable
Heatware
bigKr33 is offline   Reply With Quote
Old 12-09-2006, 03:09 PM   #2
Nanometer
Xtreme Mentor
Nanometer's Avatar
Send a message via AIM to Nanometer
I would use a cheap Zalman NB cooler for the Physics die. And the rest I would keep the same(in the picture). Check out Frozen CPU, Newegg, Performance PCs, and Xoxide to find the heatsinks.
__________________
PC Lab Qmicra V2 Case SFF
i7 950 4.4GHz 200 x 22 1.35 volts | Cooled by Swiftech GTZ - CPX-Pro - MCR320+MCR220 | Completely Silent loads at 66c
GTX 260 EVGA SuperClocked Plain stock
12 Gigs OCZ Reaper DDR3 1600MHz) 8-8-8-24
ASUS Rampage Gene II | Xigmatek Northbridge cooler mounted to the stock system.
OCZ Vertex RAID-0(60Gig x 2) | WD 1000Gig Storage
Enermax Liberty 620| With a low speed yate, the stock ball bearing fan crapped out after 1 year of service.
Nanometer is online now   Reply With Quote
Old 12-09-2006, 03:13 PM   #3
Growly
Growly's Avatar
That is so hawt.
I had nothing better to contribute.
Growly is offline   Reply With Quote
Old 12-09-2006, 03:20 PM   #4
bigKr33
Sounds good, but something i just found out though, the mcw60 doesn't completely cover the the card. Is this true because if so, i might just wait for a different waterblock.
__________________
Gaming PC
Living Room
Heatware
Old 12-09-2006, 03:51 PM   #5
phelan1777
BLAH!!!!!!!!!!!
yes but if you remove the IHS then it would fit fine :-P
__________________
Mammal brains are rather like the engines in American performance cars. We tend to use cubic inches to compensate for the lack of precision engineering.
Movieman's alter ego ---------> SUPER MOD NOOB ADMIN!
Originally Posted by nn_step View Post
(A Professor to a class of students)
"If you put the sand into the jar first," he continued "there is no room for the pebbles or the rocks. The same goes for your life.
Take care of the rocks first - the things that really matter. Set your priorities. The rest is just sand."
Originally Posted by Omastar View Post
Those chubby chicks can be amazing in the sack sometimes, you know. (waits to be sigged)
phelan1777 is offline   Reply With Quote
Old 12-10-2006, 03:31 PM   #6
bigKr33
yeah I guess I could take off the ihs,but the thing is though, I dont want to mess up the gpu because its not like a cpu that u can actually remove so its easier. and I backed out in buying a 8800 anyway because the price is a little rediculious. ill just wait till the card drops $150-200. by then vista and crysis will be out.
__________________
Gaming PC
Living Room
Heatware
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
