XtremeSystems Forums
Closed Thread
Old 12-08-2006, 12:44 PM   #1
Fuzzy_3D
Fuzzy_3D's Avatar
Daisy Chain water cooling. 6 PCs, 1 Pump. Any Advice?
They story goes something like this. I’m looking at adding a few more machines to our render farm (my accomplice and I), and we’re gonna be outfitting them with E6600 Core 2 Duos.
The last nodes we added were D820s. We all know what the heat output on those was like, so we tacked some aftermarket Zalman HSFs on each one of those for about $50 a pop. This let us squeeze quite a fair bit of speed out of them, which my friend was reluctant to do at first, but when it proved to take about 30% off of the stock rendering time, he came around.
So this time, we’re seriously considering the idea of water cooling for the E6600 stack. Price is obviously the issue here, were looking at about 4-8 separate nodes, depending on the final rendering load. So I got the idea of hooking all the blocks into a single loop, with one pump and a few rads. I’m fully aware that we’re burdening about 6 systems onto a single point of failure, but I’m sure we’ll think of something in terms of a failsafe.
I’d really like to get some feedback on what you guys think of this, so I can start bouncing a few ideas around. We figured a relatively cheap water cooling solution would surpass any aftermarket air cooling at the same price.
Besides that, I’d love to get some advice on the kind of components that would fit the bill. Keeping in mind that at a certain price point, we’d prefer to add another node to the system and just use stock cooling, rather than have an expensive/elaborate water cooling setup.
First of all, I’m looking to use a single swiftech MCP655 as the pump. This forum seems very fond of the DDC+Petra top, for good reason I presume, and I’d be glad to spend the extra $25 if you guys reckon it’s a worthy upgrade.
Looking at the cheaper CPU blocks, I figure we’d go with the Apogee over the AX MP1. Simply because the MP1 has a built in accelerator nozzle that would cause a huge pressure drop, considering there’ll be 6 of them routed through a single pump. And besides that, the Apogee looks to have a larger cooling area.
Now for the complicated part. We need to find a “cost effective” rad arrangement.
The only headway I’ve made on this so far is that we’ll probably need a 120mm cooling area for each of the satellites.
Assuming we have 6 slaves, that’s either 6 1x120mm, 3 2x120mm, or 2 3x120mm rads. Obviously having a separate rad for every block would be optimal in regards to cooling efficiency, the main concern here though is raw rendering power/dollar.
We can get 6 Swiftech MCR 120s for about $150 ($25ea). However, 3 HWL BIP2s will only cost us $100 (~$33ea), and furthermore, 2 HWL BIP 3s would be $84 ($42ea).
My partner in crime insists on getting 3 MCR-220s (~$120), and I’m beginning to think this would work pretty well, since the MCRs have (apparently) relatively low restriction, and 3 120x2 rads “probably” have less flow resistance than 6 120mm rads.
Needless to say we’ll be going with a rather large res, and a T-Line is out of the question, unless someone can convince us otherwise.
Pricing it all out, aftermarket HSFs would run us about $300, the water cooling setup
(MCP655-$75, 6xApogee-$276($46ea), 3xMCR-220-$120($40ea), Res-$25) adds up to about $500, minus the shipping, tubing, fans, etc. Lets say $600 to be sure.
If we were to add another MCP 655 and use a single 120mmMCR rad for each node, the price of water cooling the array would jump to $700, and that’s where we would be inclined to just use stock cooling and throw another node onto the stack.
It all comes down to whether the crude method of water cooling is really worth twice as much as cooling with air on aftermarket heat sinks (Zalman CNPS7700-Cu).
Also to note, we’re looking to set this up some time Q2 2007.
My experience with water cooling is rather limited, and I’m feeling a little in over my head here, so I figured I’d ask sooner rather than later, so as to wrap my head around it beforehand.
Anyway, I’ll appreciate any constructive input or advice on this. Nothing is set in stone yet, so feel free to throw anything at me.
__________________
Fuzzy_3D is offline
Old 12-08-2006, 01:02 PM   #2
SparkyJJO
Xtremely High Voltage
SparkyJJO's Avatar
Send a message via AIM to SparkyJJO
For something like that, I'd go with 2 DDC+ with Petra's top and apogee blocks. Thermochill rads would be better but the 3 MCR 220s wouldn't be bad. THe two pumps are so that you don't loose too much flow and pressure through all that.
Something like this: Res > DDC+ > DDC+ > apogee > apogee > rad > apogee > apogee > rad > apogee > apogee > rad > res.
I think it is a kind of cool idea. Now I am no pro at watercooling so you'll probably want the input of the real pros around here.
__________________
This forum requires that you wait 70 seconds between posts. Please try again in 1 seconds.
SparkyJJO is offline
Old 12-08-2006, 01:18 PM   #3
Levish
Send a message via AIM to Levish Send a message via MSN to Levish
6x 50$ (cost of heatsink) = 300$ and more redundancy and considering you probably aren't going for max effort o/c due to need to be 100% stable, you'd be better off sticking to aircoolers.
furthermore to be honest you may be better off going with quad cores and cutting the number of nodes down to 3-4
__________________
i7 @ 4000mhz 1.25vcore | Evga x58 | OCZ Gold 3x2GB | Powercolor HD4890
Levish is offline
Old 12-08-2006, 02:31 PM   #4
Bun-Bun
Xtreme Cruncher
That is exactly what I was going to say.
I also wish I could be there to help you set that up....
EDIT: MCR220's < PA120.2 and the GTX240 is somewhere in there as well probably in the middle... but those three rads would be all I would recommend. Is noise an issue for your render farm?
or since its going to be a big res anyway, you could get fun and build a bong fish tank type thing.
__________________
Yin|Asus Maximus Formula|D-Tek Fuzion 2-> GTX240 -> DDC+ w/ Petra's|QX6700 @ 3.2Ghz 1.24v|4 x 2 GB OCZ Platinums PC2-8500|EVGA GTX 280|2 x 500 GB Hitatchi P7K500(Raid-0)|Plextor 755-SA|Auzentech Prelude 7.1|Seasonic M12-700|Lian-Li PC-6077B (Heavily Modded)
GiGi|Abit IC7-Max3|Zalman CNPS9500 LED|Prescott 2.8 @ 3.5GHz (R.I.P. 2.8 M0... you will be missed )|2 x 1 GB OCZ Gold XTC PC2-4000 3-4-3-7|BFG 6600GT @ 565/650|2 x 80 GB Maxtor 7200RPM 8MB cache (Raid-0)|2 x 250 GB Maxtor 7200RPM 16MB cache (Raid-1)|Plextor 716-SA & Lite-On 20A1H|Audigy 2 ZS|Zippy GSM-6600P|Coolermaster iTower 930
GuGu|Asus Z71|Dothan 725 @ 2.13 GHz|2 x 1 GB OCZ PC2-4200 4-4-4-12|Nvidia 6600Go 290/675|Custom made copper shim for GPU to heatsink interface|80 GB Hitachi 7200 RPM 8 MB Cache|Vantec Lapcool4
Squire|Shuttle SD36G5M| R.I.P.
Bun-Bun is offline
Old 12-08-2006, 03:12 PM   #5
Clay
Clay's Avatar
I'm by no means any kind of an expert either. Are the graphics to be cooled also? Are these seperate computers or are they all inna' rack? If seperate computers then wouldn't that be a pretty long loop? I think I would also find myself greatly concerned with preasure drop. Peeps are saying the apogees preasure drop is about 5% per block. With a bunch of blocks in the chain it could be alot more. (30% at least anyway.Maybe more) Then 3# swiftech 220 rads 17% or so each? (+51%? maybe more) So 1 D5 pump might not be the best idea. Then theres a chance that the processors will run warmer as the water warms down the loop. (Kinda' sure.How much? No clue.LOL) 2#res's and pumps and rads might be better. Maybe sumptin' like...
Res>Pump>Rad>Block>Block>Block>ResPump>Rad>Block>B lock>Block>Res.
But then there is also the length of tubing to consider. (And for every 90 degree bend another kitten implodes.LOL)
By the time you get done you could have probably spent alot more time rendering.
This is all speculation on my part. I know it's been done before but myself I have no experience with that. (Someone here will know though)
Edit: PA's have the lowest preasure drop of all rads.(Sofar) 2#120.3"s 2#D5's Might be good.
__________________
Dfi Ultra-D XP4000-LCBBE 0643SPMW.(Topless) Evga 8800gts. OCZ700GX 2#Raptor2's-raid0All kind's of stuff I forgot to list. Storm Rev2, MCP655,PA120.3. 310X10 @1.54vid 1-1 2.5-4-4-8,ect 24/7 Allways clockin'' up and tryin' to trim voltages
LP-B XP-M2600,OCZ pc4800 plats.6800gt apogee, maze5,d5,mcr220 252X10- 24/7
Don't mind me folks I was just lurkin' about again. And thought I'd drop my 2 cents.
Clay is offline
Old 12-08-2006, 03:21 PM   #6
Xeon th MG Pony
Xtreme Mentor
Xeon th MG Pony's Avatar
Send a message via Yahoo to Xeon th MG Pony Send a message via Skype™ to Xeon th MG Pony
6 systems? you use larg diameter tubing and make a sucking / pressure lines that tap into a 3/8th bleeder lines to the systems, use an iwaki or other such hi powered pump to suply the 6 systems parallel.
__________________
Bring back natural selection! No more warning lables!
The one and Only MG Pony
Today's Fortune Cookie:
- Imbesi's Law with Freeman's Extension: In order for something to become clean, something else must become dirty; but you can get everything dirty without getting anything clean.
- Life can be so tragic -- you're here today and here tomorrow.
- The chief danger in life is that you may take too many precautions.-- Alfred Adler
- Those who are too smart to engage in politics are punished by being governed by those who are dumb. - Plato
- Gunter's Airborne Discoveries: (1) When you are served a meal aboard an aircraft, the aircraft will encounter turbulence. (2) The strength of the turbulence is directly proportional to the temperature of your coffee.
- A wise man can see more from the bottom of a well than a fool can from a mountain top.
Xeon th MG Pony is offline
Old 12-08-2006, 03:26 PM   #7
Xeon th MG Pony
Xtreme Mentor
I do the same I cool(ed) (My stuff was ripped off a couple or so years ago and am trying to rebuild any way) Same way you do not do it series too many issues.
You select a high pressur pump that has high flow, and a huge rad system, or cooling tower. You use a 1 inch branch lines, now every system taps into the branch suply lines with 3/8 tubing. Every block in the whole system must be identicle as with the piping lengths inside the system as to maintain system balance. You can use the shut off valves as balancing valves for each parallel branch you add.
As a back up system you can have a parallel pump that kicks in if flow drops by X amount, and then sounds an alarm whilst spinning up the back up pump.
__________________
Old 12-08-2006, 03:46 PM   #8
Bun-Bun
Xtreme Cruncher
ooh that makes sense. Then you wouldnt need RAD's inbetween computers... you just have a huge one at the end... wouldnt even have to use a computer purpose built rad just get some huge one with a large fun...
And you wouldnt have to worry about pressure losses as long as your pump has enough flow.
This could be a lot of fun
__________________
Bun-Bun is offline
Old 12-08-2006, 03:50 PM   #9
Fuzzy_3D
Fuzzy_3D's Avatar
Regarding Quad Core, we've done our calculations (based on Cinebench), and the numbers show that a E6600 rig will yield 0.963 marks/$, while a QX6700 rig only gets us 0.800 m/$. That's in CND, and taking into account the cost of the whole computer, not just the chip.
If the price/performance ratio of Quad Core comes close enough to that of the dual core at the time we buy the systems, rest assured we'll be opting for the Quad.
The most puzzling part is getting efficient water cooling, and hopefully getting a bit more power out of the nodes while keeping them stable. For the 820 nodes we went 10% under a 74hr stable clock.
As for the loop order, wouldn't something like this be more ideal?
Res > Pump > Rad > Block > Block > Rad > Block > ?Pump? >Block > Rad > Block > Block > Res
The nodes are all using onboard graphics, I know how terrible onboard GPUs are, but the client software is a purely 2D GUI, so we don't see the need for anything fancy.
ThermoChill rads in N.America are Ridiculously over priced. Unless they cool 3 times better than the MCRs, we'll be sticking with Swiftech. Unless someone can suggest something better of course.
Each node will be housed in a seperate m/ATX tower. Hard as we tried, there just wasn't a viably cost effective way to use 4U Racks.
Though sound is not an issue, within reason.
Does anyone have any suggestions for going with Series VS Parallel?
The series loop is outlined above, I'm thinking somehting like this for parallel:
................. /> Rad > Block > Block \
res > Pump1 -> Rad > Block > Block - > Pump2 > res
..................\> Rad > Block > Block /
I'm pretty sure that a parallel setup will absolutely need 2 pumps.
__________________
Fuzzy_3D is offline
Old 12-08-2006, 04:18 PM   #10
CedricFP
CedricFP's Avatar
Thermochills do not cool 3x better. They do, however, cool better and that's what XS is all about.
I would recommend swiftechs myself. The HWL rads (all of them, BIP/BIX/GTS/GTX are all worse performing (with low CFM fans such as a Yate Loon) than the MCR series.
I would also recommend instead of going for 3xMCR220 (total of 6 120m fans) go for 2xMCR320 (also total of six) and this means slightly less restriction.
As for the pump, I would get 2xDDC-02 w/ Petras top (which should be more than enough).
Your lineup would become:
Res - DDC-02 - MCR320 - Apogee - Apogee - Apogee - MCR320 - Apogee - Apogee - Apogee - Res
That's my 0.2
__________________
"Language cuts the grooves in which our thoughts must move" | Frank Herbert, The Santaroga Barrier
i7 920 3924A 205x21 / 4315 | 4870x2 | EVGA M-ATX X58 | 6GB Corsair Dominator | Corsair HX1000 | Intel X25-M 160 G2 | OCZ Vertex 60 | WD 320 || Apogee XT - XSPC FC | (2)DDC3.2 | (2)PA 120.2 | (2)BI SR-1 120 || MM H2G0
CedricFP is offline
Old 12-08-2006, 04:27 PM   #11
NickS
I am Xtreme
NickS's Avatar
Apogees, an Iwaki and a few MCR-220's or MCR-320's.
__________________
C2D E7200 @ 3.6GHz, 1.31v
Stock Q6600 HS/F
MSI P45 Neo3-FR
G.Skill 4GBPQ 8000's
Sapphire HD3870 Toxic 512MB
WD3200AAKS Single Platter
Enermax Liberty 500w
X-Fi XtremeMusic
CoolerMaster CM590
Vista Home Prem. X64 SP1
Westinghouse L2410NM
Logitech MX500, Saitek Eclipse, Logitech G25
NickS is offline
Old 12-08-2006, 04:47 PM   #12
Aerou
Crunch-Fu Adept
Aerou's Avatar
Send a message via ICQ to Aerou
I agree with NickS, maybe you should put an Iwaki there,
I guess that putting such an amount of watter into movement will need a very powerfull pump = Iwaki.
That is if you REALLY wish to stick with the 6 rig 1 loop idea.
I would definetly prefer seperate a loop for each rig, cuz if something gets bad and your flowrate would collapse, all 6 rigs would go to hell ... Its risky man ...
I guess we should get some input from the gurus here ...
__________________
___________________________________________
For the love of people, please stop the p0rn!
dark-side i7 920 C0 | DFI LP UT X58 | OCZ Pl. 1600 C7 3x2GB DDR3 | Sapphire Toxic HD4870 1GB | Enermax Pro 82+ 625W | Audiotrak Prodigy 7.1 HiFi | Teufel Motiv 2 Black & Denon AH-D2000
Bios my arss.....
I can fix this problem with a hardware mod....
Spirit of Hipro5
"Overclock till death. Overclocking is life." Hipro5
formerly aka Aerosupra
awesome little fella: Celeron 420 WR http://en.ripping.org/database.php?username=Aerosupra
Aerou is offline
Old 12-08-2006, 05:00 PM   #13
NickS
I am Xtreme
NickS's Avatar
Ultimate reliability = Iwaki too.
__________________
Stock Q6600 HS/F
MSI P45 Neo3-FR
X-Fi XtremeMusic
CoolerMaster CM590
NickS is offline
Old 12-08-2006, 07:25 PM   #14
SiGfever
Hamster Powered
SiGfever's Avatar
Send a message via MSN to SiGfever
For that many systems I would go for the Iwaki for power and rock solid reliability.
ThermoChill is the best but the MCR-320QP is a very good rad.
__________________
XSWCG Disclaimer:
We are not responsible for the large sums of money that you WILL want to spend to upgrade and add additional equipment. This is an addiction and the forum takes no responsibility morally or financially for the equipment and therapy cost. Thank you and have a great day.
Sigmund Freud said... "Failure to CRUNCH is a sign of Sexual Inadequacies".
SiGfever is offline
Old 12-08-2006, 07:44 PM   #15
STEvil
tl;dr
STEvil's Avatar
Send a message via ICQ to STEvil Send a message via MSN to STEvil
You might consider using a gravity fed setup.
A res placed at a high place could drain down to each system seperately and collect in a res at the bottom. A pump would then lift from the lower res to the top res. A decent AC sump pump rated for continuous use would probably be ideal for flow/lift height and you could make use of a large copper radiator between the res's.
Alternately you could make the worlds largest PC cooling bong...
__________________
Heatware || 01.01.08; AND 110.9%
Dead Z7S-WS? Click!. || XS Z7S-WS Thread || Current Dead Asus Z7S-WS count: 14 of 16 (Thats nearly $10,000 in dead motherboards).
All along the watchtower the watchmen watch the eternal return.
Want to use my Anti-asus logo? Go ahead, but use this link please!: http://i853.photobucket.com/albums/a...sus/noasus.gif
LIST OF GAMES WITH ACTIVATION LIMITS/SONY SECUREROM 7: http://knowyourgame.reclaimyourgame....with+SecuROM+7
STEvil is offline
Old 12-08-2006, 08:37 PM   #16
_G_
I will probably burn for posting this in here but maybe you could build something
like this in an empty 4u case.
http://www.performance-pcs.com/catal...ducts_id=21026
_G_ is offline
Old 12-08-2006, 09:15 PM   #17
STEvil
tl;dr
STEvil's Avatar
can build an identical setup for 1/5th the price probably.
__________________
STEvil is offline
Old 12-08-2006, 09:43 PM   #18
BobMaximus
Koolance!
Burn complete
__________________
Lurker since Victor Wang's first Conroe thread
Xtremely Silent Rig in the making.
BobMaximus is offline
Old 12-08-2006, 11:01 PM   #19
Bun-Bun
Xtreme Cruncher
While there is proof that your claim is true for the BIP/BIX/GTS rads, there is no such proof for the GTX that I know of (if there is that you know of please let me know) so please stick to the facts.
Also noise is not a huge issue here so running 70+CFM fans could be a possibility bringing the HWLabs into play. Although the MCR220 would be the better bet as far as flow is concerned.
Personally I like the idea suggested above and going parallel loops with a good Iwaki pump. That is the way to go here. You get performance and reliability at the same time. With series you are adding heat from one CPU to the next in the loop, parallel you are not, and you are effectively only have the equivalent of one WB worth of pressure drop with parallel loops. And then you can have a giant bong or RAD right before it all and then back to the res/pump. If you must use purpose built rads then run 2 x MCR320 and have the rads run in series before you split to the processors and then after the rads split into parallel to each processor and then meet back up in the resevoir.
I think some variation of that would be great.
__________________
Bun-Bun is offline
Old 12-08-2006, 11:13 PM   #20
Mr. Peanut
Mr. Peanut's Avatar
All I can say is make sure none of your water-cooling components are flow-restrictive ones. Here is where you might have to sacrifice a little bit of performance for some feasibility. If it means Apogees instead of Storms, do it. If it means single-pass instead of dual-pass rads, do it. (Not that I'm saying it DOES mean that you have to make these sacrifices. I am only providing examples of what I mean by "sacrificing a little bit of performance for some feasibility.") Also, I would definately go with 7/16" ID tubing over 1/2" ID tubing for this one.
Mr. Peanut is offline
Old 12-08-2006, 11:17 PM   #21
Bun-Bun
Xtreme Cruncher
You want the least restriction so why 7/16" over 1/2"?
__________________
Bun-Bun is offline
Old 12-08-2006, 11:22 PM   #22
Fairydust
When I still had a folding farm, I used a setup with 2 D5s, a Mora2 with 9 fans, 6 custom CPU blocks (pingrid, no jet impingement) and Colder quick disconnects on the radbox and PCs, 1 2.
My main goal was managing the thermal load on the small room, as during summer the heat output from PCs in a 9 m2 room was raising ambient temps past viable levels, even with an airtunnel at the PSU exhausts. The airtunnel was working well though and if you do get problems with raised ambient temps from the farm, it's an easy and cheap way to direct loads of thermal energy away.
None of the D5s ever failed, but the dual setup put me at ease if 1 had. After passing through 6 CPU blocks on Athlon XPs running at 2200 MHz, the difference between input/output temp at the radiator never exceeded 1 K. The heat output of 6 (oced) Core duos will be higher, but your flowrate will most likely be higher compared to my 0.65 gpm with the very restrictive radiator and moderately restrictive blocks.
Using a centralised radbox with all electrical components made installation and maintenance pretty easy. I chose and like the simplicity of a a completely serial setup as I find even adjusting flowrates for individual sections a rather strenuous task. The setup Xeon th MG Pony posted sounds good though, especially for loops with very high pressure drop.
Fairydust is online now
Old 12-09-2006, 07:03 AM   #23
CedricFP
CedricFP's Avatar
Why would a radiator designed for high CFM fans be better than a radiator designed for low cfm fans when we are talking about low cfm fans??
I was under the impression the OP wanted acceptable noise levels. Forgive me if I'm mistaken.
__________________
CedricFP is offline
Old 12-09-2006, 07:44 AM   #24
Turtle 1
Banned
Turtle 1's Avatar
Iwould look at something like this . Its expensive but so are render farms. Better safe than sorry.
http://www.koolance.com/shop/product...roducts_id=372
Turtle 1 is offline
Old 12-09-2006, 07:45 AM   #25
NickS
I am Xtreme
NickS's Avatar
That might actually be a good idea there, Turtle. Expensive but clean, easy, etc.
__________________
Stock Q6600 HS/F
MSI P45 Neo3-FR
X-Fi XtremeMusic
CoolerMaster CM590
NickS is offline
Closed Thread
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
