XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Air Cooling
Closed Thread
Old 12-07-2006, 02:08 PM   #1
Vapor
Admin
Vapor's Avatar
120mm Fan roundup interest?
I'm considering doing a roundup of a bunch of 120mm fans, the full gamut really.....quiet, medium, high-performance.....testing at different volts, forming a general database, I guess you could say.
I'd do it semi-similarly to the Mad-Shrimps testing here. I'd also incorporate 'feel' for air moved in an open air situation (for a case, for instance)....and rank them to make it easier to compare to your own fans. I'd also include minimum starting and working volts....and if there's any more ideas, throw them this way.
If there's good interest, please speak up and 'convince' me so-to-speak....as it'd be a fair bit of my own money toward a dB meter and passive PSU (if memory serves me correctly, isn't there one that does AC -> single molex? Anybody have a link for that?), and for all the fans to start with and over time.
So, if there's interest in this, please speak up.
FWIW: here's my starting lineup that I'm considering: YLSL, YLSM, Scythe NMB (L/M), Artic Cooling 12025, Panaflo L1, SilenX 60/90CFM and maybe a few others....we'll see
EDIT2: now that I think about it, there's little reason why I also couldn't do 80mm/92mm roundups eventually as well.....other than cost and interest.
__________________
Current Waterblock Testing
Roundup #2: Overall Comparison Thread, Alphacool Livingstone, Alphacool Niagara, Alphacool Yellowstone, D-Tek Fuzion V2, EK Supreme, EK Supreme LT, Enzotech Sapphire Rev A., Heatkiller 3.0 LC, Heatkiller 3.0 LT, Koolance CPU-345, Koolance CPU-350, Phobya, Swiftech Apogee GTZ, Swiftech Apogee GTZ SE, Swiftech Apogee XT
Vapor is offline
Old 12-07-2006, 02:16 PM   #2
bofors
bofors's Avatar
I am interested. I would also like to see some serious analysis of aerodynamic issues with respect to fan design and radiators (air and water) both in terms of noise and pressure.
bofors is offline
Old 12-07-2006, 02:19 PM   #3
lowfat
I am Xtreme
lowfat's Avatar
I'd definately like to see that. With Medium to high speed fans.
lowfat is offline
Old 12-07-2006, 02:29 PM   #4
Vapor
Admin
Vapor's Avatar
Hmmm, if the interest leans more toward med/high speed fans, I could start there for sure....I already have 4 different high speed fans (Panaflos M1/H1/U1, and a YS Tech 108CFM fan that is no longer made), so that'd make things easier to start with.
Anyway, continue to say yay/nay and any other input you may have
__________________
Vapor is offline
Old 12-07-2006, 02:32 PM   #5
lawrywild
Xtreme Cruncher
lawrywild's Avatar
Send a message via MSN to lawrywild
Go for it
I'd prefer to see a nice compare of low-med fans including nexus, yateloons, noctua and sharkoon fans (actually very good fans).
__________________
Core 2 Quad Q6600 @ 3GHz . DFI DK P45-T2RS Plus . XFX 9800GT 512MB . 8GB OCZ Blade PC2-9200 . WD6400AAKS AHCI .
Creative X-Fi XtremeMusic . Hanns.G 28" LCD . Thermalright U120-E . Seasonic S12 600w . Windows 7 Professional E Retail x64 .
lawrywild is offline
Old 12-07-2006, 02:50 PM   #6
Vapor
Admin
Vapor's Avatar
Hmmm, how's this for a categorization system:
Taken from rated speeds:
<1201RPM: Ultra-silent
1201-1600RPM: Silent
1601-2000RPM: Quiet
2001-2400RPM: Medium
2401-2800RPM: Loud
>2800RPM: Xtreme
I could test one or two RPM groupings at a time, and supplement as necessary.
__________________
Vapor is offline
Old 12-07-2006, 02:50 PM   #7
Anavel0
100% love the idea. Fan list looks good to me.
__________________
God's in his heaven, all's right with the world.
AMD Athlon 64 4000+, ASUS A8R32-MVP Deluxe, eVGA GeForce 8800 GTX, 1Gb OCZ RAM, WD 10k RPM Raptor and 7.2k RPM Caviar, Thermalright SI-128 ,Lian-Li PC-V1000 Plus II
Anavel0 is offline
Old 12-07-2006, 02:58 PM   #8
SparkyJJO
Xtremely High Voltage
SparkyJJO's Avatar
Send a message via AIM to SparkyJJO
Go for it! Especially the quieter fans.
__________________
This forum requires that you wait 70 seconds between posts. Please try again in 1 seconds.
SparkyJJO is online now
Old 12-07-2006, 03:09 PM   #9
korby
Send a message via Yahoo to korby
1601-2000RPM: Quiet
2401-2800RPM: Loud
>2800RPM: Xtreme
<800RPM: Dead Silent
801-1200RPM: Ultra-silent
1601-2000RPM: Quiet
2401-2800RPM: Loud
>2800RPM: Xtreme
__________________
Benching machine: Athlon 64 3700+ SanDiego DH-E6 (ADA3700DKA5CF - CCB2E) @ 3141 MHz /w 1,55V*104% | Scythe Infinity | DFI LP NF4 Ultra-D (AD0) + Thermalright HR-05 SLI | Mushkin 2*256 MB DDR3500 Level II - Old BH5 @ 571 MHz /w 2-2-2-5-1T @ 3,8V | eVGA e-GeForce 7900GT RoHS @ 600/2100MHz (stock voltage) + AC NV Silencer 5.3 heatsink & Nexus DF1209SL-3 | Seagate ST380811AS | LG GSA-H12N | Chieftec GPS-400AA-101A + Nexus D12SL-12 @ 7V | No case
Originally Posted by SaII
uh oh, HOT DOG!!
korby is offline
Old 12-07-2006, 03:15 PM   #10
Vapor
Admin
Vapor's Avatar
Okay, I'm getting convinced I should do it! But, more help/input needed! First off, I'll probably begin this in January, maybe a bit sooner, we'll see
1) PSU, obviously it has to be silent. But that's only for sound tests....doesn't need to power a whole system. IIRC, there was a single molex PSU out awhile ago that supplied like 50W....looked KINDA like a laptop PSU....I looked at the Egg and couldn't find it, anybody have a link? Any cheap and silent 12V, ~3-4A PSU would do actually
2) dB meter....thinking the $50 one at Radioshack (search: decibel....they're site SUCKS), any other recs?
3) Testing will be done on a 'plugged' TTBT since it can take any thickness of fans easily and does well with quiet fans and scales surprisingly well with high-powered fans. Any objections?
4) Any way, other than feel, and not for a lot of money, to do CFM tests? I can't think of one....but I'm open to ideas for sure
And I can add sub-800 no problem, didn't even think of that, thanks
__________________
Vapor is offline
Old 12-07-2006, 03:30 PM   #11
SparkyJJO
SparkyJJO's Avatar
An adapter off an old external HD or optical drive would work. I use a ghetto-rigged one for testing out fans and such.
__________________
Old 12-07-2006, 03:37 PM   #12
lawrywild
Xtreme Cruncher
lawrywild's Avatar
1600 rpm is hardly silent though, pretty noisey if you ask me..
__________________
Old 12-07-2006, 03:45 PM   #13
Vapor
Admin
Vapor's Avatar
Fine, knock down all the ratings 1RPM
<800RPM: Dead silent
800-1199RPM: Ultra-silent
1200-1599RPM: Silent
1600-1999RPM: Quiet
2000-2399RPM: Medium
2400-2799RPM: Loud
>2799RPM: Xtreme
Here's the kind of PSU I was talking about: http://www.shopneo.co.uk/product.php...=16458&cat=358
Anybody know where to find one in the USA? All my external kits are 5V only (2.5in HDDs)
__________________
Vapor is offline
Old 12-07-2006, 03:52 PM   #14
SparkyJJO
SparkyJJO's Avatar
If you don't mind soldering some wires...
This should have plenty of power
Also has 5V as well in case you want to see how well fans undervolt to 5V or 7V.
__________________
Old 12-07-2006, 03:54 PM   #15
lawrywild
Xtreme Cruncher
lawrywild's Avatar
Well, really anything above 1000rpm can't be called "silent" and there's also not ranges of "silent" it's either silent or it's not lol
anything above 2000rpm is loud.. (120mm)
__________________
Old 12-07-2006, 03:59 PM   #16
Vapor
Admin
Vapor's Avatar
Hmmmm, soldering's not an issue, thanks for the suggestion....I also found some inexpensive 12V laptop PSUs I'll decide between the two tonight probably I'll be using a fully adjustable rheobus (necessary for minimum voltage testing), so no need for the 5V supply.
PSU: check
dB meter: the one at Radioshack okay? Seems fine to me...Anybody have any other recommendations?
I think I'll start a poll for figuring out which category(s) to test first
And those are just names for categories since I don't think strings of adjectives and adverbs do any good for this....I might do comparitives though.....lol, still playing with ideas here
Remember, word-ratings are subjective
Okay, new hierarchy:
Silent: <800
Quieter: 800-1199
Quiet: 1200-1599
Medium: 1600-1999
Loud: 2000-2399
Very loud: 2400-2799
Xtreme: >2800
__________________
Vapor is offline
Old 12-07-2006, 06:25 PM   #17
Vapor
Admin
Vapor's Avatar
Okay, right now I'm thinking of doing the "Quiet" category first....seems to be quite a few fans that fit into that category, including the famous YLSL
I'll be doing every fan that I can find that fits the category from Performance-PCs, which is 12 fans. I'd love to review the Noctuas, but I can't find them......looked at Performance-PCs, Jab-Tech, Petras, Frozen CPU, Newegg.
Is there another brand for the Noctuas? Anybody know where I can get them?
__________________
Vapor is offline
Old 12-07-2006, 06:34 PM   #18
nn_step
YouTube Addict
nn_step's Avatar
try to get some CFM reading along with decibel reading
__________________
Impossible is not a fact; it is an opinion. Impossible is not a declaration; it is a dare.
It's hardware that makes a machine fast. It's software that makes a fast machine slow.
Fast computers breed slow, lazy programmers
Algorithms + Data Structures = Programs
And all of that source is portable, except for this tiny kernel that you can (provably: I did it) re-write totally from scratch in less than a year without having /any/ prior knowledge.
-Linus Torvalds
http://www.youtube.com/watch?v=ANtpsunRYIs
http://www.youtube.com/view_play_lis...23537556D7AADB
http://www.youtube.com/watch?v=QTcFLp1uVZ4
Science is simply common sense at its best that is, rigidly accurate in observation, and merciless to fallacy in logic.
http://pix.motivatedphotos.com/2009/...raindamage.jpg
nn_step is offline
Old 12-07-2006, 06:42 PM   #19
Vapor
Admin
Vapor's Avatar
Yeah, I'm thinking how to do that objectively (for not too much money).....kinda drawing a blank
EDIT: I may splurge and buy a Mannix CFM meter....
Yeah, I will....make it even better that way. The Mannix is sensitive between 5-245 CFM to within 3% accuracy.
__________________
Vapor is offline
Old 12-07-2006, 07:47 PM   #20
Ender17
I think you may be in over your head, especially on the dBA testing
read SPCR's Fan Testing Methodology
http://www.silentpcreview.com/article687-page1.html
__________________
Ender17 is offline
Old 12-07-2006, 08:26 PM   #21
Vapor
Admin
Vapor's Avatar
Hmmm, we'll see....they do go very in depth for noise though, that's for sure....as for in over my head, hmmmm, I can get accurate data.
For CFM, I'd be using an identical technique. I'd also be doing real-world numbers, but for time and consistency constraints, I only see it being done on one radiator (a plugged Big Typhoon)....still better than nothing.
Above all that, I'll do one thing they won't do: test fans that you can hear from another room
__________________
Vapor is offline
Old 12-07-2006, 08:52 PM   #22
Ender17
What about a big typhoon?
Good luck
__________________
Ender17 is offline
Old 12-07-2006, 09:20 PM   #23
Vapor
Admin
Vapor's Avatar
Good luck
Yup, I'm planning to use a modified Big Typhoon for the real-world tests....it's very accomodating to all fan depths, works with silent fans, and scales with fannage very well
SPCR has given me some ideas for voltage testing....didn't think of testing at increments.....hmmm, I like that, and it's easy enough to do
For noise, recordings....next obstacle, though a mic and recording software should suffice
Oh man, the more I think about it, the more fun I think it'll be....I'm convinced
__________________
Vapor is offline
Old 12-07-2006, 09:22 PM   #24
CLEANER
CLEANER's Avatar
Being in the market for some fan's, i have been looking for some decent round-ups. Not easy to find. In addition, the manufacturers keep coming out with new fans (duh), and nobody wants to keep doing the tests over again. If you had an ongoing "never ending" list that you could keep adding fans to that you run new fans through the same tests, that would be very cool! Of course that would imply your going to have to buy every new model that comes out, and ... that you don’t have a life. lol
Here is a link to a fairly recent (march 06) 120mm 17 fan round-up you can use as a guide to see what… or what not to do.
http://www.madshrimps.be/?action=getarticle&articID=421
I liked the way he addressed the CFM issue. Just have each fan blow on the same CPU heat sink (one at a time obviously) and measure CPU temp, at idle and load, and at various voltages (rpm's). Graph these against each other and you can see which cool better (i.e. move more air "CFM") relative to others. The lower the temp the more air the fan is moving right? The graphs get interesting as you reduce voltage (rpm) that's when you can see which cool better at lower rpm's and which aren’t doing diddly at lower rpm's. Also, check out page 7, alternative data presentation.. pictures or in this case a graph is worth a thousand words! Just shows how the same data can show you something entirely new from a different angle, depending on how you graph it.
Good luck!
__________________
"no women ... no children" - Leon
CLEANER is offline
Old 12-07-2006, 09:23 PM   #25
serialk11r
Xtreme Cruncher
serialk11r's Avatar
Theres these SilenX fans. They're rated at just 14 dba and push a decent amount of air. However, watch out for the noise levels. Sometimes they're not exactly correct... My thermaltake fans are supposed to be 17dba, but they sure dont sound like it. I wonder if anyone's done an actual test on the silenx fan's noise levels...
serialk11r is offline
Closed Thread
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
