XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > Computer Cases
Reply
Old 12-05-2006, 04:42 PM   #1
CedricFP
CedricFP's Avatar
Small, Water-Cooled Cases
Does anybody here own any small (very small) water cooled cases?
I am thinking of picking myself up a Lian Li PCV600 (it's tiny) and finding some way to mod it for my water system. The hardest thing is rad placement (MCR220) and I am looking for some inspiration.
Here are some pics:
Now, if I mount the rad on the top, it could get in the way of the GFX card, and it would make tubing a real pain in the arse, particularly for the GFX>RAD part.
If I mount it on the bottom, I possibly get in the way of my CPU block, as well as the power supply being a major limiter, along with the HD RACK for space.
That pretty much leaves the top. I might mount outside the case, but that looks really ugly. I might try make myself a little ALU enclosure, sort of like what Koolance does in it's pre-built systems.
Another idea is to put the case on high stand-offs, and mount the rad below the case on the outside. That would make it very easy to clean but it would mean the case would look strange with very high legs. Also, I would have to cut some crazy holes in my case (which I am prepared to do anyways).
Anyhow, if anybody has any small, water cooled cases or small cases (in tune with this size) regardless, please post pics. I am dying to see the case insides with hardware installed so I can guage space measurements.
Thanks.
__________________
"Language cuts the grooves in which our thoughts must move" | Frank Herbert, The Santaroga Barrier
i7 920 3924A 205x21 / 4315 | 4870x2 | EVGA M-ATX X58 | 6GB Corsair Dominator | Corsair HX1000 | Intel X25-M 160 G2 | OCZ Vertex 60 | WD 320 || Apogee XT - XSPC FC | (2)DDC3.2 | (2)PA 120.2 | (2)BI SR-1 120 || MM H2G0
CedricFP is offline   Reply With Quote
Old 12-05-2006, 04:48 PM   #2
p0tter
p0tter's Avatar
wow, that is a really nice case. Maybe a stealth GTS vertically replacing the lower fan and blocking 3 bays ?
__________________
Asus P7P55D Pro
•Intel i5 750 @ 3.8 (181x21 @ 1.35v)
•G.Skill 12800CL7D-4GBRH²
•XFX HD-587A-ZNF9 Radeon HD 5870
•Windows 7 64 Ultimate
•Dell 3007WFP
p0tter is offline   Reply With Quote
Old 12-05-2006, 04:57 PM   #3
CedricFP
CedricFP's Avatar
Tell me about it. I was instantly drawn to it when I saw it. Very nice indeed. It'd be great to watercool it as well. It's just the PSU placement poses a very difficult problem with regards to a waterblock, particularly a block like the STORM which is thick and barbs stick straight up. Tubing clearance and kinking is a major concern.
For now, it may simply remain a dream.
I am also thinking about a small icute, or perhaps trying to watercool HTPC.
I am still unsure about all this though. Ideas in the making.
__________________
Old 12-05-2006, 05:24 PM   #4
p0tter
p0tter's Avatar
__________________
Asus P7P55D Pro
•Dell 3007WFP
Old 12-05-2006, 05:51 PM   #5
Shift
Send a message via AIM to Shift
WHy would you water cool in that case? It doesn't make any SENSE. There isn't even any room for a PSU.
W/e, check out [H], some guy there mounted a tri rad I believe iat the top of the case.
__________________
Watch 24!
Q6600 G0 w/ Scythe Zipang
A Data 2x2gb DDR2-800
Corsair 750w PSU
8800GTX
320gb Maxtor HDD
Audigy 2 ZS
RocketFish case
Shift is offline   Reply With Quote
Old 12-05-2006, 06:23 PM   #6
CedricFP
CedricFP's Avatar
I want to water cool that case because I don't want a full tower sitting on my desk. It's very possible, though very hard. I don't think I'd do it, but imagine yourself a top of the line system, water cooled in that case just sitting on your desk. It's like a lego toy. It's tiny. And sleek.
I want to water cool a small mid tower case just because I am sick of this damn stacker i have lying around. It's too damn big for it's own good and I've already cut it up and modded it so I can't exactly return it and selling it is a real pain in the backside.
I've come to the conclusion I hate big cases. I'm pressed enough for space in my cramped place as it is.
__________________
Old 12-05-2006, 07:03 PM   #7
AzraelDarkangel
AzraelDarkangel's Avatar
Send a message via Yahoo to AzraelDarkangel
It looks like there might be enough space to fit a single 120mm rad on the side of the case above the PSU, of course you would need to mod the case to let airflow in. If you need more than one 120mm rad you could mount another one to the 120mm fan on the underside of the PSU. I've been playing with ideas for watercooling extremely small cases, much smaller than this one. Many people think I'm nuts for thinking about watercooling a mATX case/motherboard. Now I have an idea for watercooling a mini-ITX case/mobo/7950GT, which would probably be the smallest watercooled gaming system in the world. I'm not going to bother posting details here until/unless I build it.
__________________
DistroWatch - find your flavor of Linux
Petra's Tech Shop - for all your watercooling needs
AzraelDarkangel is offline   Reply With Quote
Old 12-05-2006, 07:20 PM   #8
p0tter
p0tter's Avatar
answered your own question.
__________________
Asus P7P55D Pro
•Dell 3007WFP
Old 12-05-2006, 07:31 PM   #9
SparkyJJO
Xtremely High Voltage
SparkyJJO's Avatar
Send a message via AIM to SparkyJJO
I might get flamed for this but....
The apogee 1U waterblock has right angle barbs on it, might help deal with the space constraints.
__________________
This forum requires that you wait 70 seconds between posts. Please try again in 1 seconds.
SparkyJJO is online now   Reply With Quote
Old 12-05-2006, 07:42 PM   #10
n00b 0f l337
I am Xtreme
n00b 0f l337's Avatar
Send a message via MSN to n00b 0f l337
I was actually going to get one to just put the watercooling itself in... Would make a great box for that.
__________________
NoL: gom gom gom
Gomeler: om nom nom nom
n00b 0f l337 is offline   Reply With Quote
Old 12-05-2006, 08:49 PM   #11
en4cer
en4cer's Avatar
Send a message via MSN to en4cer
thats actually a good idea man makes sense anyway.
If I had that case I would put a single 120 rad at the top right above the first 5.25" drive bay.... I'm still looking for a place to put a 2nd one.
__________________
en4cer's system!
DFI LANPARTY DK 790FX-M2RS
AMD Phenom 9850 BE @ 3.4Ghz 1.35v
4GB Corsair Dominator @ 1066MHz 5-5-5 2.2v
Visiontek ATI Radeon HD4870
Creative X-Fi Xtreme Gamer
2x Western Digital 320GB SATA-II
Lian-Li PC-A17B Case
Corsair 750TX 750W Power Supply
Klipsch Promedia Ultra 5.1 Speakers
Windows Vista Ultimate x64
HEAT
en4cer is offline   Reply With Quote
Old 12-05-2006, 10:28 PM   #12
hewi
There are plenty of liquidcooled V600's out there, mostly german tho, lol. Most are done with a Black Ice GT 240/360 on the top of the case, which leaves clearance for ur PCI cards etc. but u'll obviosly have to lay ur dremel upon it. As for the blocks a Storm or an Apogee wont fit easily since theres only 6,4cm between the mobo surface and PSU, so ur tubing is gonna get kinked. Performance wise i'd go for the Xeon version of the Apogee which has vertical barbs making tubing alot easier.
Personally I like this dudes setup the most, even tho he's on quite small tubing etc. but nice and clean. *courtesy of Lian Li modding*
http://www.lianlimodding.com/forum/s...ead.php?t=1336
I'm in loove with my V600B simply the best looking and most solid litte case i've owned, and i've owned 5 Lian Li's so far
__________________
Intel Q6600 @ 3.6Ghz
Maximus Formula X38
4gb Corsair Dominator DHX
4870X2
Intel X-25M 80gb + 300gb VR
Corsair HX1000w
Samsung 305T+
hewi is offline   Reply With Quote
Old 12-05-2006, 11:29 PM   #13
JPeitzman
JPeitzman's Avatar
http://www.hardforum.com/showthread....highlight=V600
__________________
Fold for life, Fold for a better tomarrow.
WorldCommunity Grid
XtremeSystems WCG Section
JPeitzman is offline   Reply With Quote
Old 12-05-2006, 11:40 PM   #14
Timmay
Timmay's Avatar
God damn a 360!!
__________________
AMD Opteron 165 CCBBE 0615DPMW 2.8Ghz 1.48v || DFI LanParty SLi-DR Expert || Patriot PC3200LLK 2x 1024MB 2-3-2-5
MSI 7900GT || 2x Seagate 80GB in RAID 0 + 320GB 7200.10 || Sound Blaster Audigy 2 ZS || SilverStone ST60F
LiteOn DVD RW +- || Logitech G15 || Razor CopperHead || CMV 19" Wide-Screen
Cooled By: TDX - BIX360 - MCP655 - Maze 4 - Stacker - Tygon
Timmay is offline   Reply With Quote
Old 12-06-2006, 12:07 AM   #15
xVeinx
Xtreme Cruncher
xVeinx's Avatar
That's pretty amazing. With little space, you have to design this thing to perfection almost...
__________________
Core i7 920
EVGA x58 sli x3 (758)
OCZ DDR3 1600 cas 8 (6 gb)
WD Velociraptor
Seagate 1 TB 7200.12
Seagate 1.5 TB 7200.11
Asus Xonar DX2
Corsair HX620
Dtek Fuzion v2
HWL stealth 240
xVeinx is offline   Reply With Quote
Old 12-06-2006, 05:21 AM   #16
bullit
Send a message via MSN to bullit
check this out...
http://www.coldzero-forum.com/showthread.php?t=198
__________________
Intel C2D 8400
Asus P5K/e wifi
GSkill 8000PQ 4GB
Corsair 620
ATI HD4850
WD 250 & 160 Hitachi SataII
bullit is offline   Reply With Quote
Old 12-06-2006, 05:45 AM   #17
CedricFP
CedricFP's Avatar
I currently own an Apogee anyways. I'm not going to shell out for a storm no matter what case I get, but an Apogee 1-U does sound interesting, particularly with regards to the much easier tubing management.
That was actually a really good idea Sparky. Thanks, you've given me something to mull over.
__________________
Old 12-06-2006, 01:03 PM   #18
Got Chow
I think a GT Stealth single 120mm can be made to fit where the GPU fan blows out the side. I've considered putting a watercooled PC into that case as well, and I would still do it.
Yeah, it's tiny, and it's a challenge, but so what. It's a nice case and I wouldn't mind a change and have a small case to jam pack everything into.
__________________
XS lurker, posting newbie.
Got Chow is offline   Reply With Quote
Old 12-06-2006, 01:33 PM   #19
Anavel0
Originally Posted by bullit
This is close to what I was going to suggest, but I think I'd try to get the 360 in there. That was awesome!
__________________
God's in his heaven, all's right with the world.
AMD Athlon 64 4000+, ASUS A8R32-MVP Deluxe, eVGA GeForce 8800 GTX, 1Gb OCZ RAM, WD 10k RPM Raptor and 7.2k RPM Caviar, Thermalright SI-128 ,Lian-Li PC-V1000 Plus II
Anavel0 is offline   Reply With Quote
Old 12-06-2006, 05:00 PM   #20
CedricFP
CedricFP's Avatar
Bah, the V6 presents far too much of a challenge for me. I am quite handy with a dremel (i've mutilated my stacker to mount my rad up top) but I've decided that with such limited space, particularly with the positioning of the PSU, I am going for a different case.
The Lian-Li PC-007 - it's exactly like the PC60 except with no removeable tray (bummer) but 2x120mm fans (awesome), and I have enough room for a triple down bottom.
It's also not BTX (thank god) meaning the PSU goes at the top, the rad goes on the floor and I don't have trouble with bleeding.
__________________
Old 12-06-2006, 06:57 PM   #21
Anavel0
Where do you find the PC-007. I've never seen it anywhere and the Lian-Li site says it's OEM only. Also Lian-Li doesn't have BTX cases, they are inverted ATX. BTX was a bad idea from Intel, that has, for the most part, gone the way of the doodoo bird.
__________________
Old 12-06-2006, 10:28 PM   #22
badhabit
badhabit's Avatar
Performance PCs has it in silver and black, and so does Newegg, in silver and black.
badhabit is offline   Reply With Quote
Old 12-06-2006, 11:22 PM   #23
Asky
Asky's Avatar
How Tiny is the Lian Li PCV600? compared to my Wavemaster?
Asky is offline   Reply With Quote
Old 12-07-2006, 12:11 AM   #24
alucasa
Rack Freak
alucasa's Avatar
About 2/3 of wavemaster. Full ATX cases can't go very small.
__________________
PhII-720-Eos : PhII 720BE / Gigabyte MA790XT-UD4P / 6.00 RAM / HD 4850 / Vista x64 ultimate
======WCG rigs (on 24/7)================= ==========
i7-920-Sarah : i7 920 / Gigabyte GA-EX58-UD3R / 6.0GB RAM / HD3850 / Vista x64 Home
NAS-Apathy: Celeron M550 / Gigabyte GA-6KIEH-RH / 2.0GB RAM / Onboard X3100 IGP / 3.5TB storage
alucasa is offline   Reply With Quote
Old 12-07-2006, 03:19 AM   #25
thespeakerbox
thespeakerbox's Avatar
with a rad mod on top , that lian li would be sick. Just be sure not to ruin the sleek look
thespeakerbox is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
