I've been interested in this DDC2 ultra top pump which everyone was raving about a little while back. I was just wondering how quiet it is? Is it any good for a super-silent system? If not, what is?
Been wc'ing for several years now and the best solution IME for super silent is a submerged pump res combo as these can be truly dead silent. Placing a pump inside a sealed box surrounded by water provides for rather effective noise dampening! Since these are AC based solutions should be partnered with a low res block such as Apogee etc.
As far as DC pump solutions the DDC2 Ultra is very good. Especially with one of the aftermarket tops fitted, however, as I find the pump to be somewhat whiny in its stock configuration. I cant speak for the new Petra top as have not tried one (but should offer a similar benefit I would imagine) but fastening an Alphacool top to one of these pumps I found definitely lowered its noise footprint. Whether or not it meets your definition of super silent cannot say, but it is very quiet.
And assumes a good quality mounting pad to eliminate case resonances - also very important for quiet operation.
my 2 ddcs with petra tops(EK) mounted on the gel pads that Petra sells are prety much silent. less noise than low cfm fans on 7V. the way to go if you need complete silence.
I'm running an AquaXtreme 50z at the mo, I was just wondering if there is anything even quieter.
I'm a little dubious over this Petra top; I don't quite understand why it makes such a large difference. I have had a read through that relevant test thread. If someone could explain what it is about the top that makes the pump perform better I'd appreciate it
Flow and head are even and what's better stuited for us and 90% of the block out there. I use the 50Z my self, silent once air is out and on some foam. If thats ones going spear let me know Stocky!
I wonder if I have a defective pump...everyone keeps going on about the Ultra being silent; it's far from silent...it's "quiet" and with my fans at 5-7V, NB/SB down to inaudible, it's still not bad, but it's definitely not silent...
(fully bled, directly from DD, sitting on a gel pad).
From the Swiftech site:
"A Note of Caution! the MCP355 generates higher audible noise than the MCP350 and MCP655 pumps. This product is not recomended for users seeking silent operations."
but then again, most people here are probably half-deaf from loud rock music or from sitting within a close proximity to a multitude of Delta fans for an extended period of time...
__________________
BFG 7900 GTX
Seagate 7200.10 320GB SATA2
Samsung SP2004C 200GB SATA2
Samsung SH-W162C
OCZ Powerstream 520W SLI
Intel Pentium D 930
ASUS P5WD2
G.Skill 2GB DDR2-800 something or other
The D5 Vario (MCP655), at setting "5", is not quieter than the DDC-2 (MCP355) at 12V, regardless of what Swiftech claims.
The problem here is that "silent" and "quiet" are very relative terms... What is quiet/silent to one person may not be even close to that for someone else. Sound quality also plays a pretty big role--see here for some audio clips and dB measurements: http://www.cooling-masters.com/articles-33-14.html
My personal (subjective) observations are as follows (in order from quietest to loudest):
DDC-1 (MCP350) < DDC-2 (MCP355) < D5 Vario (MCP655 - setting 5) < 50Z-DC12
As for the performance gain from the custom DDC tops, the increase in flow is the result of removing the 90-degree bend before the pump's inlet and increasing the diameter of said inlet. The rest of top design focuses on minimizing max head pressure loss as a result of the increased inlet size and simplification of the impeller housing (really, there's only so much you can do with a CNC mill without making the part unrealistically expensive).
__________________
I'm doing science and I'm still alive...
