XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Vapor Phase Change Cooling
Reply
Old 12-02-2006, 07:31 AM   #1
sdumper
-100c club
sdumper's Avatar
O-Ring and Pliers
I am replacing my evap cap and need to find a brass O-Ring and a pair of O-Ring pliers. I would think my local Ace hardware might have a suitable O-ring but I am not sure how to describe the O-ring to the parts guys over the phone. Also do I simply measure the diameter of the evap head and tell the hardware guys the diameter and say I need a spreadable O-ring that will fit this diameter? Also what about the thickness any thing special to tell them?
__________________
http://valid.canardpc.com/show_oc.php?id=606830
Seller/Buyer Reputation:
Heatware: http://www.heatware.com/eval.php?id=50905
Ebay: {Family Account} Kasyg3 http://myworld.ebay.com/kasyg3/
Ebay: {My personal Account} Sdumper http://myworld.ebay.com/sdumper/
iTrader: http://www.blazingpc.com/forum/itrader.php?u=28
sdumper is offline   Reply With Quote
Old 12-02-2006, 07:59 AM   #2
Marvin
Marvin's Avatar
I am not sure, but here in Brazil we call šexternal retention clipš . Just check if they have the plier too, you will need it.
__________________
Q9550 EO @ 4.1
Asus P5Q Deluxe
4 Gb DDR2 Gskill
2xVelociraptors 300 gb Raid 0
Sapphire Vapor 4870 1Gb
PCP&C 750w silencer psu
Marvin is offline   Reply With Quote
Old 12-02-2006, 08:54 AM   #3
Jack
Jack's Avatar
A seeger ring.
__________________
Intel Core2Duo E6600 ES | Asus P5WDH Deluxe | 4x 1GB TeamGroup PC5300 | Asus ATI X300SE | OCZ PowerStream 520
Intel Pentium 2160 | Gigabyte GA-P35-DS3P | 2x 1GB Crucial PC5300 | Diamond S3 Virge | Corsair 520HX
Jack is offline   Reply With Quote
Old 12-02-2006, 10:09 AM   #4
sdumper
-100c club
sdumper's Avatar
Cool guys thanks...I was able to get a snapring solid brass and some pliers at Ace hardware in the states for $12 and it worked perfectly.
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
