XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme > Xtreme Overclocking
Reply
Old 11-29-2006, 01:06 PM   #1
before
reaching perihelion
before's Avatar
Send a message via MSN to before
QX6700ES @4836MHz under Cascade [4817MHz=Spi1M@10.469s]
System:
QX6700 Engineering Sample L633A723
Quent's Asus P5B-Deluxe (Vdroop by Quent; Vcore, Vdimm & Vmch mods by Before)
STT Before's Xtrem 2*512Mb
Windows 2k3 Server (tweaked by Before)
Western Digital IDE 80Gb
2-Stager Unit @ -100C
Vcore = ~1.70V (1.66 to 1.76V)
Vddr = 2.74V
Vmch = 1.87V
Very impressive chip in the beginning, this QX6700ES benched Super Pi 1M @4804MHz @1.66V (with 3 disable cores), but finally failed to scale over 4836MHz even with more voltage.
CPU-Z Suicide
http://valid.x86-secret.com/show_oc?id=142460
Check the reading of the temp... -9C is obviously wrong; it must be -70C or so (evaporator temp was about -85C; actually, it used to be -86C unloaded under Win 2k3 but -90C under Win XP... interesting to note )
Spi 1M @10.515s
Spi 32M @11m 18.172s
Didn't play with the timings for this 32M run. These are the SPD timings. Also, this might not be to highest Spi32M benchable operating frequency... just a run for fun.
3D Mark 2001 SE succeeded @4600MHz (all 4 cores enable), BTW with my 7600GS the results aren't very interesting. I hardly need a better graphic card in order to do 3D benchmarks.
Thx for reading!
__________________
Best Regards,
Xavier
"I prefer to fly alone... when alone, I perform those little coups of audacity which amuse me..." Col. René Fonck (1894-1953), the Ace of Aces.
before is offline   Reply With Quote
Old 11-29-2006, 01:23 PM   #2
loc.o
Xtremely Addicted
loc.o's Avatar
Send a message via MSN to loc.o
Very nice one again before!
__________________
loc.o is offline   Reply With Quote
Old 11-29-2006, 01:46 PM   #3
barzi
Send a message via MSN to barzi
nice oc!
barzi is offline   Reply With Quote
Old 11-29-2006, 01:47 PM   #4
rick_fx
rick_fx's Avatar
Very impressive quad-core speeds
__________________
Wolfdale e8400es @4.5Ghz / Ultra-120 Extreme
2GB Ballistix @ 589Mhz 4-4-4-x @ 2.5V - SPI 32M
*** Motherboards tested: DFI Blood Iron (current), Asus P5K3-dlx, DFI P965-S, P5B-Dlx, DFI RD600, Bad Axe 2, EVGA 680i, DS3 and P5W DH ***
Fan modded Zippy 850W, 500GB 7200.11 and EVGA 8800GTX @678/1062
rick_fx is offline   Reply With Quote
Old 11-29-2006, 03:22 PM   #5
LittleDevil
-100c Club Member
LittleDevil's Avatar
Send a message via ICQ to LittleDevil Send a message via MSN to LittleDevil
Great results...
Is that QX6700 much hotter than X6800?
regards
__________________
DFI LANPARTY UT P35-T2R, Q6600 @ 4200Mhz
2 x 2048Mb Crucial Ballistix @ 4.4.4.12
OCZ PowerStream 520W, Phase Change
Here are my units: LittleDevil's SS Cases, LittleDevil's SS Worklog, LD CPU-R1 Dice/LN² Pots, LD GFX-R1 Dice/LN² Pots
LittleDevil is offline   Reply With Quote
Old 11-29-2006, 04:06 PM   #6
before
reaching perihelion
before's Avatar
Thank you guys!
@LD: It doesn't look like significantly hotter than the X6800; actual evap temp is not really different.
Under Win XP running the QX6700 4600MHz@1.76V with 4 cores enable, the evap reads -90C which corresponds more or less to what can be expected from the X6800 under similar conditions.
__________________
Best Regards,
Xavier
Old 11-29-2006, 04:16 PM   #7
_CrAzY_BoY_
_CrAzY_BoY_'s Avatar
Nice results one more time
Very impressive overclock
Best regards
__________________
Intel 660 ---> 6308.04 MHz <--- E6700 ---> 5108 MHz <---
P4 524 WR ---> 6009.02 MHz <--- Cedar Mill 641 ---> 7069.31 <---
EVGA 680i SLI & Asus P5W-DH | X6800XE | EVGA 8800GTS | Cellshock 6400 | Solid Containers | Ln2
http://www.crazyboy-overclock.com | Team OCX Member
_CrAzY_BoY_ is offline   Reply With Quote
Old 11-29-2006, 05:36 PM   #8
Gautam
Captain Jinx
Gautam's Avatar
Send a message via AIM to Gautam Send a message via MSN to Gautam
You're unstoppable my friend. Perhaps the temp similarity between the X6800 and X6700 is due more to those dual 1HP rotaries and good tuning.
Btw, speedfan seems to read the internal diode, which doesn't seem to function below 0. On some CPU's it reads -9, sometimes +9, sometimes even +/- 15. Obviously it can be ignored. :S
When you compared temps between Win2K3 and WinXP, did WinXP also have LargeSystemCache enabled?
__________________
Originally Posted by FUGGER View Post
I put on my shoes before I put on my pants.
Gautam is offline   Reply With Quote
Old 11-29-2006, 07:29 PM   #9
ncsa
ncsa's Avatar
Once again excellent work !!!
__________________
VapoChill LS [AC] / QX9650 / X6800 / E8500 / Q6600 / CF-3870x2 / 8800 GTS G92 512 / XFX 7950GX2 (H20) / GeIL PC2-8500 C5 / PC2-6400 C4 / SilverStone OP1000 / ST75ZF
Abit IP35-Pro | 3DM06 - 18,264 | PCM05 - 23,577 | PCMVA 13,063
DFI 680i LT | 3DM06 - 24,602
Abit X38 QuadGT | 3DM03 - 120,337 | 3DM06 - 28,176
ncsa is offline   Reply With Quote
Old 11-30-2006, 12:51 AM   #10
Kabauterman
Kabauterman's Avatar
Send a message via ICQ to Kabauterman Send a message via MSN to Kabauterman
Want to see 3DMark06 CPU Score
Nice OC
__________________
Kabauterman is offline   Reply With Quote
Old 11-30-2006, 01:48 AM   #11
erwinz
Excellent Quad core OC..
__________________
Asus P5W64 WS Professional , DFI Infinity 965P-S (testing)
X6800 , E6750 es
Micron Fatbodies , Micron D9gkx oem, Crucial 8000, Crucial Tracer 8500 (incomming)
Ati FireGL V5100, Elsa FireGL V3100
water cooling setup (EK 775 cpu block, swiftech NB Block, Swiftech pump, BI dual pass dual 120mm)
Silverstone OP650
raptors, baracuda
erwinz is offline   Reply With Quote
Old 11-30-2006, 04:49 AM   #12
thenrz
4 cores at 4.6ghz :drool:
__________________
E8600
2x ASUS 4850
DFI X48 board
4 gb DDR2
650w FSP PSU
Working on some liquid cooling!
Desktop 2:
Opteron 165 @ 2.610 (1.425v)
- Prime Stable, Stock HSF
DFI LanParty UT Expert
2gb G. Skill Dual Channel Ram 2.5-3-3-6
7900gt CO SuperClocked
2x WD250gb SATA in RAID 0
FSP Epsilon 600W
thenrz is offline   Reply With Quote
Old 11-30-2006, 08:00 AM   #13
before
reaching perihelion
before's Avatar
@Gautam: Thx bro!
Actually, speedfan was somehow correct with other CPUs, reading -95C to -60C depending on load, operating frequency and vcore. It looks like the QX6700 internal diode is out of breath!
The only serious trouble so far was when using a E6600 on a Biostar TForce P965 Deluxe which seems to have its own sensor (showing -120C for -100C evap or something ).
LargeSystemCache is enable on my XP
@ncsa: Thank you my friend! It's nice to see here too.
@Kabauterman, erwinz & thenrz: Thx for these kind words
So, I've performed some more testing today. Let me share the stuff.
First of all, I've managed to improve the max frequency in order to bench Spi1M and of course getting a faster time...
[Super Pi 1M] 10.469s
Then, I've done 3DMark06 and AquaMark3 @stock...
[3DMark06 CPU] 4023pts
[AquaMark3] 15.831pts
... and @4608MHz for 3DMark and @4660MHz for AquaMark3
[3DMark06 CPU] 6705pts
[AquaMark3] 24.862pts
__________________
Best Regards,
Xavier
Old 11-30-2006, 02:09 PM   #14
Boble76
Boble76's Avatar
Haha! Little boost by CPU... Nice. When do we see that 9.xxx s from you ?
__________________
Finnish Overclocking Team
E6600 @ 100% OC with Co2 | FX57 SuperPi 8M @ 4min 5.281s
Abit IP35-Pro
E8500
XFX8800GTS (G92)
aXeRam 2Gb PC-6400
TT 750W
Auzen Prelude 7.1 X-Fi
TT Mozart |
Boble76 is offline   Reply With Quote
Old 11-30-2006, 02:43 PM   #15
MTP04
MTP04's Avatar
Nice chip!
Well done!
MTP04 is offline   Reply With Quote
Old 11-30-2006, 07:45 PM   #16
Celcius
Celcius's Avatar
Looks like its time for a videocard upgrade
Nice cpu
__________________
Intel Q9650 @ 3.906Ghz (9x434, 1.224v) w/ Tuniq Tower
Asus Maximus II Formula @ 1736 fsb (bios 1901)
4GB dual-channel Corsair Dominator pc8500 @ 1084Mhz & 5-5-5-15-2T 2.1v
EVGA GeForce GTX 285 @ 722/1476/1351 & 75% fan speed
PC Power & Cooling Turbo-Cool 1 Kilowatt psu
X-Fi Xtrememusic + Logitech X-530 + Audio Technica ATH M20
dual Seagate Barracuda SATA2 250GB 7200rpm 16MB buffers
Dual Lite-On LH-20A1S's
CoolerMaster Stacker 830 Evolution
Logitech MX518, Alienware keyboard, xbox 360 controller
Asus VH236H 23" widescreen lcd
Windows 7 Professional x64
Celcius is offline   Reply With Quote
Old 11-30-2006, 09:33 PM   #17
Boble76
Boble76's Avatar
I think that too. before, what is your videocard? X300SE?
__________________
Abit IP35-Pro
E8500
XFX8800GTS (G92)
aXeRam 2Gb PC-6400
TT 750W
TT Mozart |
Old 11-30-2006, 09:48 PM   #18
rjw
Xtreme 3DTeam Member
nice cpu, but what's up with the video card?
__________________
E6600 week 28, Asus P5B vanilla, 4.64Ghz,P5B vanilla w/ Vmods, vapochill and other stuff, Super Pi 1M = 11.0000s
QX6700 on EVGA 680i w/ twin 8800 GTX's SLI
Second Place hwbot 3DMark06 Sli 20999 (12/2/06 till ...???)
rjw is offline   Reply With Quote
Old 12-01-2006, 02:06 AM   #19
before
reaching perihelion
before's Avatar
I'm definitely not a 3D freak BTW I may have a 8800 in few weeks in order to do some 3D stuff.
__________________
Best Regards,
Xavier
Old 12-01-2006, 06:45 AM   #20
TaPaKaH
Banned
TaPaKaH's Avatar
Send a message via ICQ to TaPaKaH
me =
You did not mount cascade on the mobo - you mounter the mobo to the cascade
TaPaKaH is offline   Reply With Quote
Old 12-01-2006, 10:37 AM   #21
before
reaching perihelion
before's Avatar
Don't you like it that way? Believe me, it'll become fashionable!
__________________
Best Regards,
Xavier
Old 12-01-2006, 10:51 AM   #22
quent
quent's Avatar
No.. You WILL !
__________________
Cooling : Waterchiller, Cascade and ~100L LN²
Hardware : Many things !
quent is offline   Reply With Quote
Old 12-01-2006, 03:39 PM   #23
before
reaching perihelion
before's Avatar
It'll be great bro!
__________________
Best Regards,
Xavier
Old 12-01-2006, 03:49 PM   #24
Nazu
Nazu's Avatar
Looks very good Seems like these quad core's are oc'ing pretty nicely.
__________________
C2Q Q6600@3.6GHz
Asus P5Q Pro
Kingston Valueram 2x2GB PC6400 CAS6
Club 3D GTX295
Benq G2400W
WD 6400AAKS & 3200AAKS & 2x 2500JS & 10EADS
Coolermaster HAF932 + Chieftec CFT-1000G-DF
Nazu is offline   Reply With Quote
Old 12-01-2006, 07:43 PM   #25
hicookie
hicookie's Avatar
ur sick,bro
hicookie is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
