XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme Teams > Xtreme 3D Team
Reply
Old 11-21-2006, 11:51 AM   #1
piotres
-100c Club Member
piotres's Avatar
Send a message via ICQ to piotres Send a message via MSN to piotres
Cheap GF cards without coldbug at -100*C ?
Hi
I want to buy very cheap SLI config (around 350 $ max) , I'm thinking about 6600GT, 7300GT, 7600GS, maybe used 7800GT or GTX 256 MB. In future I have plans to test eg. cascade on them, so guys, please tell me which of those cards for sure will be working OK under -100-120*C cascade's evaps ??
Regards
Peter
piotres is offline   Reply With Quote
Old 11-21-2006, 12:25 PM   #2
afireinside
I am Xtreme
afireinside's Avatar
Send a message via AIM to afireinside Send a message via MSN to afireinside
My 7800GTs cold bugged in 2d with zalman coolers and cold air. When I made my WR runs I had to put the 120mm fan on a fan controller and turn it off when 3dmark ended or else I'd black screen.
__________________
Phenom II 940 BE / ASUS M4A79 / HD5770
3808mhz CPU 2720mhz NB | DDR1088 5-5-5-15 | 975/1300
afireinside is offline   Reply With Quote
Old 11-21-2006, 12:34 PM   #3
afireinside
I am Xtreme
Constant 3d always forced I tested it, watched temps as I turned fan on, as soon as they went lower than the minimum driver display (25c was it?) they black screened.
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
