XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Vapor Phase Change Cooling
Reply
Old 11-19-2006, 04:16 AM   #1
sdumper
-100c club
sdumper's Avatar
Cap removal
Can someone tell me how to remove this retainer cap?
I had a mishap and need to replace the cap.
__________________
http://valid.canardpc.com/show_oc.php?id=606830
Seller/Buyer Reputation:
Heatware: http://www.heatware.com/eval.php?id=50905
Ebay: {Family Account} Kasyg3 http://myworld.ebay.com/kasyg3/
Ebay: {My personal Account} Sdumper http://myworld.ebay.com/sdumper/
iTrader: http://www.blazingpc.com/forum/itrader.php?u=28
sdumper is offline   Reply With Quote
Old 11-19-2006, 04:19 AM   #2
Pete
Banned
Pete's Avatar
Send a message via MSN to Pete
A set of cirrclips is the proper tool, ones that would open out as you squeze the handle. A set of needle nose plyers would work too
Pete is offline   Reply With Quote
Old 11-19-2006, 04:24 AM   #3
sdumper
-100c club
sdumper's Avatar
So just insert it in the open space and let it release. Can the Oring be reused?
__________________
Old 11-19-2006, 04:29 AM   #4
Pete
Banned
Pete's Avatar
Yeah pretty much, you just need to prise it open and slide it off.
It should be.
I have the same on some Hybrid Rocket motors i use! They hold back soemthing silly like 500PSI of nitros oxide and burn in .5 to 8 seconds pedning motor i used! Good stuff.
Guess just don't bend it too far
Old 11-19-2006, 04:59 AM   #5
sdumper
-100c club
sdumper's Avatar
Cool man thanks!!
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
