XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > Intel > Intel Info And Support
Reply
Old 11-14-2006, 01:32 AM   #1
Snowman89
Biostar tforce 965 deluxe VS biostar tforce 965 PT
Just found out that there is 2 diffrent mbs with almost same name.
So whats the changes?
Snowman89 is offline   Reply With Quote
Old 11-14-2006, 07:14 AM   #2
DaWaN
DaWaN's Avatar
Send a message via MSN to DaWaN
The deluxe features ICH8R and the PT the ICH8, so the deluxe has RAID and 6 S-ata ports while the PT only has 4 S-ata ports and no RAID.
When using the same bios overclocking shouldn't be different. The PCB is exactly the same
__________________
My Rig:
Intel Core 2 Duo E6400
2x512mb Micron PC3200 OEM D9DQW "Fatbody"
Biostar TForce P965 Deluxe
MSI/Medion GeForce 6700XL (Cheap )
Chieftec 360W (in search for someting better)
WD 160GB S-ATA
DaWaN is offline   Reply With Quote
Old 11-14-2006, 08:39 AM   #3
Lestat
I am Xtreme
Lestat's Avatar
Send a message via AIM to Lestat Send a message via MSN to Lestat
yeah they are the exact same board with the exception of what Dawan mentioned.
you can also flash the PT with the Deluxe bios
i had horrible luck with mine though but i have seen others have more luck with 6300 and 6400 cpu's.
__________________
no more computer......
Heat Ebay XB360 GamerTag VvvlestatvvV
Lestat is offline   Reply With Quote
Old 11-14-2006, 09:56 AM   #4
uclajd
uclajd's Avatar
Question
Since this question was ignored in the other Biostar thread, does the non-deluxe version allow CPU multiplier adjustment? I wouldn't mind trying this board, and since the Deluxe is vaporware in the USA, I'd have to try the PT...
__________________
<----- REST IN PEACE, KIT. 1993-2007.
uclajd is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
