11-06-2006, 03:08 AM
#1
4GHZ Dual Prime Stable under Air/Water/Phase?
Are there any peolpe here who can run 4GHZ dual prime stable (and who run it 24/7) either on water or air? How about phase?
When I finally reinvest in a desktop (broke down my 165/XTX a while ago) I am going to be on the hunt for a chip that can do that, but was wondering if anybody already has?
Or how about close, such as 3950 24/7?
Thanks in advance.
Cedric
EDIT: I understand there is a 4GHZ databse, but it doesn't specify if it's dual/quad prime stable (Conroe/ Kentsfield respectfully) - that's what I need to know - if it's possible. If it is, my hunt begins very soon.
__________________
"Language cuts the grooves in which our thoughts must move" | Frank Herbert, The Santaroga Barrier
i7 920 3924A 205x21 / 4315 | 4870x2 | EVGA M-ATX X58 | 6GB Corsair Dominator | Corsair HX1000 | Intel X25-M 160 G2 | OCZ Vertex 60 | WD 320 || Apogee XT - XSPC FC | (2)DDC3.2 | (2)PA 120.2 | (2)BI SR-1 120 || MM H2G0
11-06-2006, 03:11 AM
#2
Xtremely Addicted
Topic about prime & phase here.
__________________
11-06-2006, 03:56 AM
#3
Personally, I'm more interested in air/water results. In Hong Kong, humidity is a huge problem with regards to phase.
__________________
11-06-2006, 04:49 AM
#4
Your looking for a very special cpu, i havent seen any orthos stable 4ghz chips on air and even water for that matter.
There are alot that can hit 4ghz but orthos stability is tough. Which is the reason i started the 4ghz phase thread and even with phase there are some setups that arent dual prime stable.
__________________
Asus Commando 6600 week 28B @4.2 1.475v(1.475 in bios) 525x8 4-4-3-4 1150mhz 2.3v
2x1gb Patriot Pc-8000 Xbl | X1600 Pro | 2 Wd 36gb Raptors
Seagate 750gb | Vapoli V2000B SS | Pc p&c Black Silencer 750
Originally Posted by chron
Its DDR2 - doesn't it need to be ran with 2 sticks at a time?
11-06-2006, 05:56 AM
#5
Yeah, that was the information I was looking for.
Too bad eh? I was about ready to splash out as well... been saving up for a few months... planned to go with a bang.
Oh well. With phase it seems possible, though at very high voltages which I am a little aprehensive about.
So it seems that 3.6-3.8 seems about best on water dual prime stable. Oh well, it'll have to do.
If anybody else is running higher though, please do post your setup here, including week and batch number!
__________________
11-06-2006, 09:43 AM
#6
Xtreme Mentor
I have a very good 6600 and it "works" fine at 3900 MHz.
But all Core2 CPUs go a whole lot higher semi-stable and then take a huge step backwards when you want N-mprime stable clocks. I had to go to 3660 and then it was overall faster to go to the 1033 MHz strap and 3600 MHz.
The gap between "works" and "mprime-stable" is much higher with Core2 than it was with AMD64.
11-06-2006, 02:23 PM
#7
here's the best prime i have been able to do on water. I'm motherboard limited though. I need to find out what is getting hot and instable and sink it. Mosfets are sinked and no change in results. This is with cool air from outside though.
e6400 L628B194.
__________________
Current 24/7 settings
Delidded L628B e6400@ 3.6ghz 1.38v
3.9ghz 1.56v dual prime, 4ghz dual 32m pi stable on water and P5B Deluxe
Patriot 667 LLK @ 970 mhz 4-4-4-4 2.3v
x1900xt 690/780
11-09-2006, 12:07 PM
#8
Originally Posted by thunderstruck!
Some ES E6600s can do 3.95G prime stable without a problem.
On air?
__________________
Wolfdale e8400es @4.5Ghz / Ultra-120 Extreme
2GB Ballistix @ 589Mhz 4-4-4-x @ 2.5V - SPI 32M
*** Motherboards tested: DFI Blood Iron (current), Asus P5K3-dlx, DFI P965-S, P5B-Dlx, DFI RD600, Bad Axe 2, EVGA 680i, DS3 and P5W DH ***
Fan modded Zippy 850W, 500GB 7200.11 and EVGA 8800GTX @678/1062
11-09-2006, 12:21 PM
#9
Xtreme
My L629B will be 4ghz prime stable on air in winter when it is -20C outside and window opened :P
But 4ghz prime stable is rare
__________________
11-09-2006, 05:15 PM
#10
__________________
E6600 - Tuniq - P5K Deluxe
8800GTS 320
Dell 2407WFP
WRT54G Running the Awesome DD-WRT
Firmware
11-09-2006, 05:56 PM
#11
Originally Posted by rick_fx
On air?
My Xeon can prime 3925 on water, but im hitting a FSB wall there, so I cant even run 1m @ 4ghz
This is the highest prime Ive taken a SS of, call me lazy :|
11-10-2006, 04:19 AM
#12
Xtreme 3DTeam Member
Managed to run 4000MHz dual-Prime one time for about 17min, but with a ambient of 16°C and 1,58V. In germany there are a few guys with bought waterchillers, they can run +4000MHz with ~ 14-16°C watertemp. But with normal roomtemps i think there is close to zero cpus out there who can manage 4GHz primestable with plain water/air.
__________________
PC : Gigabyte EP45-Extreme + Intel Core 2 Quad Q9550 + Powercolor HD5770 + 2x2GB PC8500 Chaintech Apogee GT + Creative X-Fi Xtreme Music + Scythe Mugen 2.
Digicam : Pentax *istDL2 + Pentax smc DA 18-55mm F3.5-5.6 AL + Cosina F3.5/100mm Makro.
11-10-2006, 05:06 AM
#13
here is my 6700 es at 4 ghz 24/7 under phase :
__________________
11-10-2006, 06:41 AM
#14
Originally Posted by cupra
what vcore do u use?
__________________
my buddy, Lian Li A70:
* Asus P6T Deluxe & Intel Core i7 920 @ 4.2 + HT, stable @ 1.3875v & 6GB OCZ PC3-12800 Triple Channel Low Voltage & 1X Hitachi Deskstar 1TB
* DELL 30"WFP3007-HC & 2x 4850 CrossFire & X-Fi Fatal1ty Pro & Sennheiser HD595
* SilverStone Zeus 750W
my liquid setup:
*cpu EK Supreme Acrylic *rad TFC Xchanger 480QUAD *pump DDC-2 + XPSC reservoir top
*tubing Tygon B-44-4X 1/2"ID - 3/4"OD + all Feser compression fittings
MY LIAN-LI A70-480QUAD WORKLOG - KAOZZ.COM
11-10-2006, 08:35 AM
#15
Ive got a good chip, Step 5 b1.
My best is 3.94 Ghz for 13 hours on water with 1.56v in bios. This in the middle of a hot summer too
Though i also managed nearly 4 hours with 1.58v in bios. At the time I wasnt willing to goto 1.6v which im sure would have nailed it f0r 12+hours. i havent got that gem of a P5W Dh motherboard anymore to try it
11-10-2006, 07:28 PM
#16
That is a very impressive chip
11-10-2006, 10:43 PM
#17
Orthos blend is the toughest test in the prime series, my best results so far has been 3.825 ghz on water with a e6600 stepping 5 es. Using the Asus P5WDG2 Pro, phase 4ghz was no problem at all, apart from the mobo limit of 445fsb.
So small and large fft's should be possible up to 3.95ghz (on some steppings with water cooling for 24/7, vcore on a e6600 is generally around 1.53 to 1.58), running orthos blend for 8 hours, pegs you back a little. As uopt said there is a larger gap than Amd in what you can get away with fsb wise over the Orthos blend test with Conroe (on some boards at least).
On phase I have seen around 4.28ghz completely Orthos blend stable with a retail week 31 x6800 under phase, for 22 hours by my friend Diego (the cpu can bench with super pi single runs in the 4.5ghz region), again that was using the Asus P5WSG2 Pro, I'd like to see what the next gen of boards allows in comparison really, especially for the 4mb cache Conroe's.
regards
Raja
11-10-2006, 11:48 PM
#18
Indeed! Looks like the golden 6600 ES! I hear the cpu screaming for LN2!
__________________
11-27-2006, 08:25 PM
#19
As my friend Raja said, here is the screenshot.
Regards
Diego
PS: To Cedric...as for humidity...do you know Buenos Aires? ;-)
11-29-2006, 09:35 AM
#20
Retail E6600 L630A735 @ 1.500Vcore
Water temp under Orthos 26.8'C/80.24F
P5W64WS Pro BIOS 0301
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
