The last pot I made a while ago had a 8mm base, and was about 350mm high. I liked to make the pots short because they are essier to work with. a 10mm base is fine for an Al pot. It isn't difficult to make. It's just hard work getting the measurements right.
__________________
PC Lab Qmicra V2 Case SFF
i7 950 4.4GHz 200 x 22 1.35 volts | Cooled by Swiftech GTZ - CPX-Pro - MCR320+MCR220 | Completely Silent loads at 66c
GTX 260 EVGA SuperClocked Plain stock
12 Gigs OCZ Reaper DDR3 1600MHz) 8-8-8-24
ASUS Rampage Gene II | Xigmatek Northbridge cooler mounted to the stock system.
OCZ Vertex RAID-0(60Gig x 2) | WD 1000Gig Storage
Enermax Liberty 620| With a low speed yate, the stock ball bearing fan crapped out after 1 year of service.
