XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > General Computer Hardware
Reply
Old 10-23-2006, 05:06 PM   #1
Vapor
Admin
Vapor's Avatar
Mouse pad, time for a change
What're some of your recommendations? Currently have the fUnc 1030, and like the fast surface....wish it were faster, actually.
Looking to change cause I want a 1-piece and maybe slightly larger (space is an issue )....and just a new one in general, this one's served me well for a few years but has a few gashes in it. Also looking for it to be a quiet pad, very fast (I don't think I can reiterate this enough)....for example, on the smooth/slow side of the fUnc, things can get pretty loud. Asthetically, the less bling, the better....simple and understated
__________________
Current Waterblock Testing
Roundup #2: Overall Comparison Thread, Alphacool Livingstone, Alphacool Niagara, Alphacool Yellowstone, D-Tek Fuzion V2, EK Supreme, EK Supreme LT, Enzotech Sapphire Rev A., Heatkiller 3.0 LC, Heatkiller 3.0 LT, Koolance CPU-345, Koolance CPU-350, Phobya, Swiftech Apogee GTZ, Swiftech Apogee GTZ SE, Swiftech Apogee XT
Vapor is offline   Reply With Quote
Old 10-23-2006, 05:29 PM   #2
illmatik
I was actually looking at one of these (they also have the gamer model Victory)
http://www.corepad.com/index.php?pagina=artikel&id=34
I'm not really a gamer, but I've always got several machines around being worked on (either constantly changing my configs or building/fixing friend&family boxes) so theres usually a number of mice in various places on my desk which also happens to suck as a mousing surface and the keyboard tends to slide/fall more than I care for, and I wont even mention ashtrays and beverages :0 I hear the surface material is pretty quick too
edit: corepad also offer a 'wax' to improve performance
__________________
illmatik is offline   Reply With Quote
Old 10-23-2006, 05:51 PM   #3
skuliaxe
The Ulti-mat is my favorite now.
Bottom site is all rubber, then a thin slice of stainless steel coated with teflon. And the teflon pads under my Logitech G5 are great on the surface. (Teflon tape is included also).
It's not cheap, but I tried like 3 other mouse pads before this one (ones that were supposed to be good) and they don't come near this one.
It's also very durable.
Price is from $31.95 - $41 (both black and white version)
I bought my black version from Sidewindercompuers.
skuliaxe is offline   Reply With Quote
Old 10-23-2006, 06:03 PM   #4
afireinside
I am Xtreme
afireinside's Avatar
Send a message via AIM to afireinside Send a message via MSN to afireinside
Well I usually recommend the steelpad Qck+ but it's cloth. Slower but more accurate, worth switching IMO. Lower sensitivity means more room though. steel S&S is the best hard surface but very loud, at least with my MX510. Not as loud with my copperhead. Stick with func I guess, get the rough surface one that's not double sided.
__________________
Phenom II 940 BE / ASUS M4A79 / HD5770
3808mhz CPU 2720mhz NB | DDR1088 5-5-5-15 | 975/1300
afireinside is offline   Reply With Quote
Old 10-23-2006, 06:22 PM   #5
Vapor
Admin
Vapor's Avatar
Hmmmm, thanks for the recs, but I think AFI's right.....gotta stick with the fUnc pad. Though I've never seen the non-double sided one?
Steel is too loud....the Corepad is WAAAAYYYYY too slow (an air-hockey table [turned on] would be ideal).
AFI, is the non-double sided one a 1-piece?
__________________
Old 10-23-2006, 09:41 PM   #6
flavoraid
mod a air hocket table into a computer desk?
flavoraid is offline   Reply With Quote
Old 10-23-2006, 09:46 PM   #7
afireinside
I am Xtreme
http://www.frozencpu.com/products/30...?tl=g39c51s379
14" wide, and that's the small version. My brother has one and it's insanely fast with his diamondback.
Also, look into hyperglide mouse feet. They slide quite well I need to order a new set. Used some on my old copperhead before I RMA'd it and I had the mobility of a hard pad with the control and size of a cloth.
http://www.hyperglide.net/
__________________
Old 10-23-2006, 09:48 PM   #8
illmatik
What about Razer's dual surface pad?
http://www.compusa.com/products/prod..._Gaming_Bundle
obviously cheaper elsewhere
__________________
Old 10-24-2006, 02:07 PM   #9
JoeBar
Xtreme Mentor
JoeBar's Avatar
What's wrong with dual surface pads? In my opinion it's a very nice feature.
I have a dual surface SteelPad 4D and been really satisfied with it. The included teflon tapes reduce noise in the "hard" surface by a great margin also.
I have also a SteelPad QcK at my second rig and it's very nice for a cloth pad.
__________________
Asus Rampage II Extreme
Intel I7 920 D0 3930A @ 4.35GHz (20 X 217mhz) WC'ed
3 x 2GB G.Skill Trident 1600 @ 1740MHz (7-8-7-20-1T)
Asus 4870X2 @ 850/950MHz WC'ed
150gb Western Digital Velociraptor | 2 x 320gb Western Digital Caviar SE16 Raid0 | Seagate FreeAgent XTreme 1.5TB esata
Logitech Z-5500 | LG W2600HP 26" S-IPS LCD
MountainMods UFO | Zalman ZM-850HP psu
Watercooling setup:
1st loop -> Radiator: ThermoChill PA 120.3 | Pump: Laing DDC Ultra with Alphacool top | CPU: Swiftech Apogee XT |Chipset: Swiftech MCW-NBMAX | Tubing: PrimoFlex 1/2" Pro LRT
2nd loop -> Radiator: XSPC RX240 | Pump: Laing DDC Pro with Alphacool top |GPU: EK FC-4870X2| Tubing: PrimoFlex 1/2" Pro LRT
JoeBar is offline   Reply With Quote
Old 10-24-2006, 05:15 PM   #10
TV Addict#2
TV Addict#2's Avatar
I liked the func surface than a x-pad thunder 8,I have the corepad cloth pad,the 18"x16" one,works nice
__________________
BigTyphoon/Q9450@3.4...AsusP5EWSPRO...8G/Gskill(953)...XFX5970...75Graptor...X-FI/680z...Corsair1000w...thermaltakex3...HP LP-3065...7 x64
TRU/I7920...AsusP6TWSPRO...12G/OCZ...HD3870...2x64GSamSungSLC/Areca1110 raid0...2.8TB storage...Seasonic700wM-12...CoolerMaster810...HP LP-3065...7 x64
TV Addict#2 is offline   Reply With Quote
Old 10-24-2006, 05:34 PM   #11
Quest_7F
Quest_7F's Avatar
Send a message via AIM to Quest_7F Send a message via MSN to Quest_7F
the qcksteel pad is pretty good
Quest_7F is offline   Reply With Quote
Old 10-25-2006, 01:08 AM   #12
inntruzion
Steelpad 5L, although I haven't had any experience with it, apparently it's dead fast with the Razer CH in particular, but has no problem with accuracy. Best used for laser mice though...if that's a problem.
EDIT: Yeah, it's really huge aswel. Look.
That's the Razer and the func mainstream mats behind. It's big.
inntruzion is offline   Reply With Quote
Old 10-25-2006, 06:47 PM   #13
Vapor
Admin
Vapor's Avatar
That one looks good AFI....thanks for the link
14" is a little wide, but I can rotate it if it's too wide. The weird shape isn't too extreme either, still fairly square, which is good.
As for a custom air hockey table for mousing.....hmmm, maybe actually, not for school though, it'd be something I do just for kicks, but I definitely like the idea.
Dual surface isn't a bad thing if one surface is rediculously fast and other surface is meant to grip the table The problem with dual surface is that it means you need a 2nd grip piece, and two pieces isn't something I want, nor is a flexible pad.
Anyway, that pad looks perfect (other than the size/irregular shape, but those are no biggies) AFI, thanks.
__________________
Old 10-27-2006, 10:46 AM   #14
Nazu
Nazu's Avatar
Get the Steelpad S&S. I have it and it's very good
__________________
C2Q Q6600@3.6GHz
Asus P5Q Pro
Kingston Valueram 2x2GB PC6400 CAS6
Club 3D GTX295
Benq G2400W
WD 6400AAKS & 3200AAKS & 2x 2500JS & 10EADS
Coolermaster HAF932 + Chieftec CFT-1000G-DF
Nazu is offline   Reply With Quote
Old 10-27-2006, 10:58 AM   #15
Maviryk
Send a message via AIM to Maviryk Send a message via MSN to Maviryk Send a message via Yahoo to Maviryk
Hmm... I just use a large WoWpad from Office Depot... a mousepad is a mousepad?
Do you notice that much of a difference between pads? What do you guys look for in them anyhow? What differenciates a good one from a bad one?
Maviryk is offline   Reply With Quote
Old 10-27-2006, 11:11 AM   #16
Nazu
Nazu's Avatar
There are lots of differences between cheap and expensive mousepads. When comparing my previous mousepad the Alsop steelpad it was ok but the mouse doesn't glide as well it does with my S&S. Also this S&S is more accurate and its slimmer so it doesn't strain your hand as much as a thicker mousepad would. Other small bonuses are included glidepads for the mouse so there are minimum restriction between the mouse and the pad and these better mousepads tend to be bigger so you have more room to move your mouse.
__________________
C2Q Q6600@3.6GHz
Asus P5Q Pro
Club 3D GTX295
Benq G2400W
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
