XtremeSystems Forums
Reply
Old 09-24-2006, 11:55 AM   #1
adamant415
adamant415's Avatar
Air bubble
I keep on getting an air bubble in the same spot at the plug on my pump. I have been running for about a week and cannot find any leaks. I have bled the radiator and have bled the loop. It takes about 8 hours for an air bubble like this to show up. I usually tilt the case to make the air bubble go away but it always comes back.
Is this normal for this pump? If not where is the air bubble most likely coming from? Right at that plug or somewhere else in the loop?
I hope you can see what I am talking about in the pic. It is right at what would be the pumps inlet but I have a plug in that hole and am using the top inlet.
__________________
P182
E6400 @ stock
Asus P5B Deluxe
8800 GTS 320 mb
G.skill PC6400 2x2 gigs
CL x-fi xtreme music
PCP&C Silencer 750
3 x 160 gb 16 mb cache WD r.e. hard drives (raid 0)
Dual Layer burner
Ultima 90
Vista 32
Coming soon: 4x4 or penryn, another 4 gb's of memory, and Vista 64
adamant415 is offline   Reply With Quote
Old 09-24-2006, 12:54 PM   #2
tw33ter
if it keeps forming in that same spot, then that means your plug isn't making a complete seal somehow
tw33ter is offline   Reply With Quote
Old 09-24-2006, 03:20 PM   #3
adamant415
adamant415's Avatar
I loosened up the plug till the point that water started to leak out and then tightened it a little trying to not overtighten and deform the o-ring and I'm still getting air bubbles there. I guess I'll end up having to drain the loop and maybe using another o-ring there and using something else for the threads.
__________________
P182
E6400 @ stock
Asus P5B Deluxe
8800 GTS 320 mb
PCP&C Silencer 750
Dual Layer burner
Ultima 90
Vista 32
Old 09-24-2006, 03:30 PM   #4
SiGfever
Hamster Powered
SiGfever's Avatar
Send a message via MSN to SiGfever
I don't think that your o-ring is allowing air into your system. It is just a good place for air to pocket as it passes through the pump. Shim the pump so that the oultlet is slightly down and see if that cures your problem.
__________________
XSWCG Disclaimer:
We are not responsible for the large sums of money that you WILL want to spend to upgrade and add additional equipment. This is an addiction and the forum takes no responsibility morally or financially for the equipment and therapy cost. Thank you and have a great day.
Sigmund Freud said... "Failure to CRUNCH is a sign of Sexual Inadequacies".
SiGfever is offline   Reply With Quote
Old 09-24-2006, 04:37 PM   #5
KaptCrunch
Banned
Toss the "T" an remove plug from pump an add hose barb for the remaining T-line tube. for column of water @ inlet is lower then pumps output.
Question is the pump on the bottom or top of case ? hard to tell from avitar
KaptCrunch is offline   Reply With Quote
Old 09-24-2006, 04:48 PM   #6
nealh
why is this air bubble even a concern...it is not part of the loop seems to be a good place for trapped air, so long as no leak is present I cant see this is much of an issue
But if I am wrong, which is likely please correct me
__________________
My Heat
L629F221 e6600 @3600 1.4v D-Tek Fuzion
Badaxe2 bios 2747 rev 505 1.3v vFSB/1.575v MCH
2 x 2GB Corsair XMS@DDR 800 5-5-5-5-18@1.85
x1900xt MCW60
Rad: PA120.3 3YL SL/ Pump: DDC2 w/ Petra's top 7/16in ID masterkleer
Seagate 320gb 7200.10/ 200gb 7200.8 SATA
X-Fi music/SH-203B/H62L/LH-20A1L
Corsair HX620w /Acer AL2223W/modded TJ07
nealh is offline   Reply With Quote
Old 09-24-2006, 04:50 PM   #7
adamant415
adamant415's Avatar
Are you saying to get rid of my "T" and use one of the two inlets for fill tube?
Yes the pump is at the bottom of the case. Here is a pic to show how everything is set up.
__________________
P182
E6400 @ stock
Asus P5B Deluxe
8800 GTS 320 mb
PCP&C Silencer 750
Dual Layer burner
Ultima 90
Vista 32
Old 09-24-2006, 04:55 PM   #8
septim
Banned
Send a message via Yahoo to septim
i agree with Sig, put a wedge on one side to tilt pump.
maybe on a new revision of said alphacool top, they'd just remove the side inlet to avoid these air pockets...
septim is offline   Reply With Quote
Old 09-24-2006, 04:58 PM   #9
adamant415
adamant415's Avatar
I may redo my loop like that if it will work. Instead of having the "T" I can have the fillport going straight to the top inlet of the pump and the outlet of the water block going to the inlet that has the plug in it correct? Please let me know if I can set it up like that. Thanks.
__________________
P182
E6400 @ stock
Asus P5B Deluxe
8800 GTS 320 mb
PCP&C Silencer 750
Dual Layer burner
Ultima 90
Vista 32
Old 09-24-2006, 05:00 PM   #10
tw33ter
What about putting a Y connector after the T, so you can feed both inlets of the alphacool top instead of just the one?
Old 09-24-2006, 05:06 PM   #11
adamant415
adamant415's Avatar
If I set it up with the top inlet going straight to the fill port and the side inlet coming from the water block both inlets would be fed. without the need of a "Y" or a "T".
__________________
P182
E6400 @ stock
Asus P5B Deluxe
8800 GTS 320 mb
PCP&C Silencer 750
Dual Layer burner
Ultima 90
Vista 32
Old 09-24-2006, 06:17 PM   #12
tw33ter
That'd work but I'd do it the other way around, so the incoming water won't be affected by that 90 degree angle by using the side inlet. It might take longer to bleed that way though.
Old 09-24-2006, 06:38 PM   #13
SiGfever
Hamster Powered
SiGfever's Avatar
No, it will be too restrictive. Just shim the bottom left side of the pump and leave your loop intact. JMO
__________________
XSWCG Disclaimer:
Old 09-25-2006, 04:54 AM   #14
Stigma
Stigma's Avatar
I have to agree with the person who said its no problem. As long as there is only a small airbubble like this in a place where it does not affect the cooling of the block even, then it dosn't matter at all.
-Stigma
Stigma is offline   Reply With Quote
Old 09-25-2006, 01:31 PM   #15
adamant415
adamant415's Avatar
I figured I would try sitting my case up at an angle to simulate shimming the pump. Air bubbles are still forming in the same location so it has to be sucking air in thru that plug. I guess the good news is petra is coming out with his own top that dosen't have that second inlet on it. Soon it will be time to break out the credit card again.
__________________
P182
E6400 @ stock
Asus P5B Deluxe
8800 GTS 320 mb
PCP&C Silencer 750
Dual Layer burner
Ultima 90
Vista 32
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
