09-24-2006, 09:10 AM
#1
-100c club
Converting a phase cooled mobo to air cooling
I need to cleanup a P5W Deluxe to get it ready for air.
I have the mobo on phase so my socket is full of dialectic grease and I also need to clean the perimeter of neoprene gasket residue and seal string residue...to add to the difficulty the pins are fragile and easy to bend so how do i rinse the grease out without bending a pin?
09-24-2006, 09:21 AM
#2
Simon says EnJoYs a nub
For the grease I would try a hair dryer and use a paper towel very lightly. As for the residue maybe some rubbing alcohol?
09-24-2006, 09:28 AM
#3
I am Xtreme
Nah theres some spray compound that will remove most of that crap. Someone should post it in a few moment's.
__________________
NoL: gom gom gom
Gomeler: om nom nom nom
09-24-2006, 09:39 AM
#4
-100c club
like QD Electronic cleaner by CRC?
Will it damage anything else?
09-24-2006, 09:50 AM
#5
I am Xtreme
I can't see why leaving it can hurt.
__________________
http://xtremespeakfreely.com/forum/
Register today .
The Laws of Thermodynamics say:
Zeroth Law: "You must play the game."
First Law: "You can't win."
Second Law: "You can't break even."
Third Law: "You can't quit the game."
Do you wanna Play Thermodynamics ????????  I forgot "you must"
09-24-2006, 10:08 AM
#6
-100c club
Im selling the mobo and the grease increases the heat by several degrees.
I want to return the board back to pristine condition for the new owner.
09-24-2006, 08:27 PM
#7
I would just use alcohol that is what i always use and it works good for me just takes time.
09-24-2006, 09:31 PM
#8
I am Xtreme
I fiqured that, you answered honestly  so I have no reason to think otherwise ,but be sure to be honest in your for sale ad and with the new owner about the history of the board and chip if you sell that also..
__________________
Register today .
09-24-2006, 10:30 PM
#9
You could use a toothbrust with some alcohol to clean the socket.
09-24-2006, 10:43 PM
#10
The un-extreme XIP
your best bet is to dissolve it with an appropiate solvent, so you don't bend the pins. acetone might be too harsh, try alcohol first.
__________________
Q6600@3.6ghz 1.45V ----- 8gb ocz ddr2-1000
XFX 5850@900/1200 1.15V
1TB hitachi+2x30gb OCZ Vertex v1.41 raid 0
520HX corsair power supply ----- half-size shuttle!!
30" 3007wfp-hc 2560*1600 lcd
unicomp clicky keyboard+logitech trackball
09-24-2006, 11:44 PM
#11
Member
Also please test the board works after you have cleaned it.
Such cleaning can kill boards if your unlucky or use the wrong solvent (static being the main issue)
__________________
Back in the UK and bored
09-25-2006, 03:52 AM
#12
what about Liquid electrical tape? any ideal how to clean that up? sorry for jacking your thread
09-30-2006, 02:05 PM
#13
CRC electronics cleaner will clean anything from dielectric grease to bead seal used on mach II units. It disolves without a residue and is completely safe.
__________________
Core 2 Duo E6400 l EVGA 680i A1 l Crucial Ballistix Tracer PC8500 l XFX 8800GTS l WD Caviar SE16 500gb l Tagen Turbojet U96 900w
10-02-2006, 06:10 AM
#14
-100c club
Worked perfectly that stuff is absolutely incredible...thanks for the Tip...toaster...
10-02-2006, 09:29 AM
#15
-100c Club Member
and it also can be used to keep your memory stick clean, etc
__________________
Single Stage Work Logs
Originally Posted by killermiller
Those ccb's will die if you look at them wrong.
heatware: jinu117
10-02-2006, 10:25 AM
#16
I was just amazed it ate sealstring lol. Any cleans any contact perfect
__________________
10-02-2006, 11:12 AM
#17
-100c club
Nice tip thanks...
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
