Today, I had some free time so, I put this together. I got a Cooler Master Aquaminigate from my friend. I wanted to see what it looked like inside, so I opened it.
CPU WaterBlock+Tank+Pump( All in one)
Cooler Master warranty
Radiator Dimension: R120: 120 x 160 x 35 mm
Start kill it
Have 10 screw to turn.:P
Pump board.
The Pump same any FAN only different between Rotor and Stator
Under side
Stator
I took the Stator out.
Inside Pump
[/center]
I used MS Paint to show how the pump works.
This is block
Size 70 x 85 x 23 mm
This is the block, as you can see there are many copper sheets linked together.
I drew a flow of water, too
After re-install and run it with water.
The pump runs very strong with water jets.
Will be update Aqua mod, pump control...
__________________
Are you overclocker? Your PC fast? Join WCG to help community
Big thank to: heater918, DDT, Movieman, Mad mikee
Special thank to Centon
