XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Vapor Phase Change Cooling
Reply
Old 09-12-2006, 01:44 PM   #1
sdumper
-100c club
sdumper's Avatar
Retention clip removal for Mach II and P5W/P5B
I just purchased a Mach II gt and have heard that the shape of the retention clip can be a mounting problem for the P5B Deluxe and the P5W deluxe. Does anyone know of a safe way to remove the mounting clip and a safe way to insure the CPU doesnt become misaligned when seating a Mach II gt head?
__________________
http://valid.canardpc.com/show_oc.php?id=606830
Seller/Buyer Reputation:
Heatware: http://www.heatware.com/eval.php?id=50905
Ebay: {Family Account} Kasyg3 http://myworld.ebay.com/kasyg3/
Ebay: {My personal Account} Sdumper http://myworld.ebay.com/sdumper/
iTrader: http://www.blazingpc.com/forum/itrader.php?u=28
sdumper is online now   Reply With Quote
Old 09-13-2006, 07:26 AM   #2
sdumper
-100c club
sdumper's Avatar
Ok maybe I should rephrase the question:
Has anyone used a Mach II gt with a P5B or P5W mobo? If so how did you get a flush mount of the evap head to the CPU?
My Chilly head works perfectly for my e6700 and my P5W but I just purchased a second Phase unit (Mach II) and an e6400/P5B combo and when the gear arrives I wanted to get it up and running quickly.
--edit-- e6400 and P5B Deluxe have arrived and I am not impressed. I will be selling the mobo and chip and purchasing an e6600 for this phase unit.
__________________
Old 09-13-2006, 07:37 AM   #3
Blaster
-100c Club Member
Blaster's Avatar
Send a message via MSN to Blaster
the best thing would be to swap the evap for much easier to mount and insulate... that would require gassing so you would have a much better unit
im sure you can find some1 here that can "mod" your prommy
Blaster is offline   Reply With Quote
Old 09-22-2006, 04:21 PM   #4
sdumper
-100c club
sdumper's Avatar
Yep jinu117 is taking good care of me...no complaints
__________________
Old 09-22-2006, 04:54 PM   #5
Blaster
-100c Club Member
Blaster's Avatar
then ur unit will be in very good hands
Congratz ! You will have a superb cooler!
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
