XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Vapor Phase Change Cooling
Reply
Old 08-26-2006, 01:00 AM   #1
CedricFP
CedricFP's Avatar
International Shipping + tropical climate
I have to ask, would it not be prudent to request a pre-made unit from one of the skilled builders here on XS, and have it shipped to Hong Kong?
I've heard that international shipping does hell for a SS unit, and we all know how rough the post people can be.
Also, here in Hong Kong, the room routinely heats up to about 30-35 degrees celcius. Would it severely hamper the SS unit's performance? When the AC is on, cools down to about 24 which is a nice temperature.
Thanks in advance.
__________________
"Language cuts the grooves in which our thoughts must move" | Frank Herbert, The Santaroga Barrier
i7 920 3924A 205x21 / 4315 | 4870x2 | EVGA M-ATX X58 | 6GB Corsair Dominator | Corsair HX1000 | Intel X25-M 160 G2 | OCZ Vertex 60 | WD 320 || Apogee XT - XSPC FC | (2)DDC3.2 | (2)PA 120.2 | (2)BI SR-1 120 || MM H2G0
CedricFP is offline   Reply With Quote
Old 08-26-2006, 02:49 AM   #2
LukeXE
-130C Club Member
Send a message via AIM to LukeXE Send a message via MSN to LukeXE
I think that you won`t have problems with shipping to Hong Kong, someone here at XS made unit for someone from vietnam I think, there wasn`t any problems.
LukeXE is offline   Reply With Quote
Old 08-26-2006, 03:04 AM   #3
CedricFP
CedricFP's Avatar
I see. That is good to hear.
The temperature here isn't that bad if you use the airconditioner, but if not, it gets pretty hot and it's always humid. But if someone can use a unit in Vietnam, the climate is very similar to Hong Kong's.
__________________
Old 08-26-2006, 03:11 AM   #4
Jort
Jort's Avatar
Ron aka runmc made 2 unit's for guys in vietnam, ban and lin or something
edit: i found the topic but it's on TP
http://www.teampuss.com/forums/viewt...&highlight=ban
__________________
fill in yourself
Jort is offline   Reply With Quote
Old 08-26-2006, 03:13 AM   #5
CedricFP
CedricFP's Avatar
So I take it the shipping went alright.
I am just worried that if some post worker having a bad day decides to chuck my parcel, that the unit breaks and I have to ship it all the way back for repair.
That would be an incredibly hassle.
I am looking forward to diving into the world of phase change (been a bit of a water-whore for a while) and do not have the money to invest in the proper and correct tools in order to make one, nor do I have the "know-how" with the tools. Only thing I can use is a drill, saw (mechanical or not) and dremel... heh.
Any other thoughts / opinions?
__________________
Old 08-26-2006, 04:36 AM   #6
epion2985
Xtreme Mentor
epion2985's Avatar
The humidity is very high in tropical climates. You will need to insulate the living daylights out of the system in order to prevent condensation.
__________________
French Duron Poof
Every time you lap a swiftech block a kitten dies
"Extreme Systems, yes. But it could also mean Extremely creative, Extremely resourceful and on and on. Please don't use the name of this site as an excuse to do stupid things" -situman
HEAT
epion2985 is offline   Reply With Quote
Old 08-26-2006, 06:37 AM   #7
CedricFP
CedricFP's Avatar
That certainly is an issue, one I've been wondering about for a while.
Aside from insulation, are there many methods of preventing condensation?
__________________
Old 08-26-2006, 06:58 AM   #8
Ssilencer
Ssilencer's Avatar
Send a message via ICQ to Ssilencer Send a message via MSN to Ssilencer
Yes, get a unit and specificy that you want to use a vapochill enclosure system, or the one from cooler master, you will need all the help you can get, and this two enclosure systems has electric heaters included (Vapochill one is better IMO).
Ssilencer is offline   Reply With Quote
Old 08-27-2006, 02:03 AM   #9
CedricFP
CedricFP's Avatar
Vapochill enclosure system? No hits off google image search. Can anybody elaborate?
Humidity is often up in the 90's here.
__________________
Old 08-27-2006, 02:22 AM   #10
Clint
Go ahead punk...
Clint's Avatar
Simply make sure you keep that AC running and the humidity shouldn't be a issue. I lived in Indonesia for quite some years and did never work the box without the AC on.
__________________
MSI X58M @222BCLK
920 3942A @4.22GHz (1.32v)
Sapphire HD 5850 @1GHz/1.3GHz (1.2v)
Mushkin Blackline 12GB PC3-12800 @1.33GHz 6-6-6-16 (1.64v)
Clint is offline   Reply With Quote
Old 08-27-2006, 02:24 AM   #11
CedricFP
CedricFP's Avatar
That's not possible. I don't have the money for the electricity bill to keep the ac on all day.
I could run a dehumidifier.
Is this a CPU enclosure?
http://www.phase-change.com/index.ph...s&id=25&page=3
Bottom pic.
__________________
Old 08-27-2006, 03:25 AM   #12
jinu117
-100c Club Member
Bottom pic.
http://www.frozencpu.com/ex-vap-09.html
would be it.
The only thing builder has to do is test the unit under 35c ambient to simulate what you have (oh lord.. it isn't fun in builders end... it's quite hot).
Most custom unit will consume 180w idle to 240w fully loaded. It isn't too little but it isn't too much either
__________________
http://www.vapoli.com/Images/Forum/vapoli.jpg
Single Stage Work Logs
Originally Posted by killermiller View Post
Those ccb's will die if you look at them wrong.
heatware: jinu117
jinu117 is offline   Reply With Quote
Old 08-27-2006, 12:11 PM   #13
Xeon th MG Pony
Xtreme Mentor
Xeon th MG Pony's Avatar
Send a message via Yahoo to Xeon th MG Pony Send a message via Skype™ to Xeon th MG Pony
Just use a slightely bigger condencer for the unit. If you use an open loop water system through an old fridge evap you can use the cold main water to dehumidify the place. I've don that here a fiew times
__________________
Bring back natural selection! No more warning lables!
The one and Only MG Pony
Today's Fortune Cookie:
- Imbesi's Law with Freeman's Extension: In order for something to become clean, something else must become dirty; but you can get everything dirty without getting anything clean.
- Life can be so tragic -- you're here today and here tomorrow.
- The chief danger in life is that you may take too many precautions.-- Alfred Adler
- Those who are too smart to engage in politics are punished by being governed by those who are dumb. - Plato
- Gunter's Airborne Discoveries: (1) When you are served a meal aboard an aircraft, the aircraft will encounter turbulence. (2) The strength of the turbulence is directly proportional to the temperature of your coffee.
- A wise man can see more from the bottom of a well than a fool can from a mountain top.
Xeon th MG Pony is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
