XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Vapor Phase Change Cooling
Reply
Old 08-22-2006, 01:53 PM   #1
piotres
-100c Club Member
piotres's Avatar
Send a message via ICQ to piotres Send a message via MSN to piotres
Alexio's 2 heads ;-D
Hi
Alexio ask me (BTW quite long time ago) to build a dual-evap cooler for Him. He don't want SLI/CF unit, but CPU + GPU cooler ...and He said he really don't want 2 compressors, but only one ...instead He wanted 2 CPEVs and good gases blend - quite high needs, isn't it ?
That is mine first dual-evap, and I think it's also first single-stage with 1 compressor, 2 evaps and 2 CPEVs .
Specs :
Compressor: Sanyo C-1RV137H11AA (rotary)
evaps : piotres's custom CPU (rev. 1.1) + custom made, big GPU evap from CPU rev. 1.0 evap 8)
Expansion valves: 2* FACH "PZ" CPEVs
condenser:1.9 kW with 30W EBM fan
Refrigerant : R410a & R507 blend
Case : Chipboard 50 x 40 cm baseplate, painted black
others: 2* Mastercool gauges, 1.3 l receiver
Alexio has also asked me about thermometers ..so I have bought for Him two brand new CHYs 700T ..unluckily they aren't tunned ideal , so real temps on evaps measured by them are let's say 1.5*C lower .
Parts (or course not all) .
Receiver is so big (1.3 l), because I can't bought smaller .
"T" for connect 2 suction-lines .
That was only first run, mine first frost on two evaps together .
Both evaps loaded with 115 W dummyloads (mine 115W dummyloads are same as eg. 100% stressed A64 Venice clocked to 3200 Mhz on 1.78 V) .
CPU evap on 215 W dummy and GPU evap 115 W = 330 W :mrgreen:
Both evaps went into small vaccum.
CPU evap went into deep vac ^) .
Ready (only GPU enclosure is left, but it's already going to me) .
I'll sent unit to Alexio in few next weeks ^) .
Regards
Peter
piotres is offline   Reply With Quote
Old 08-22-2006, 02:21 PM   #2
expansionvalve
Looks quiet an interesting build, well done, but I'd be asking myself how well the suction t-piece will stand up over time to the forces the suction lines will put on it when the heads are fitted, I think I'd be inclined to try incorporate a brace of some description.
expansionvalve is offline   Reply With Quote
Old 08-22-2006, 02:41 PM   #3
GOATSLAYER
very nice and clean.
__________________
[size=1][center]||DFI-NF4 ULTRA-D||Sapphire X800PRO VIVO PCI-E@570/570||AMD64 3200+ Venice@(250 x 10)@1.45v CIPW||Corsair Value Select 1GB(2x512)@216 2.5/3/3/7-1T||Antec SP 2.0 500W Dual 12vRails||XP PRO SVP 2||SONY DVD-RW||Lian Li PC-IIB |WD SATA 80GIG 7200RPM||
GOATSLAYER is offline   Reply With Quote
Old 08-22-2006, 02:57 PM   #4
Sneil
Sneil's Avatar
you mean this joint would hold up to those evaps? Looks fine to me, those flex hoses arn't that heavy that they would to cause this to bend.
__________________
Extreme Phase Builder/User
SLI Cascade in the works.
Sneil is offline   Reply With Quote
Old 08-22-2006, 03:03 PM   #5
Waus-mod
ln2nl
Waus-mod's Avatar
I now know how alexio feels
Superb building over there !
__________________
*EDITed by IFMU*
Signature Removed by XS Staff for not following XS Policies
Forum Policies
Waus-mod is offline   Reply With Quote
Old 08-23-2006, 02:50 AM   #6
ent
ent's Avatar
Good work piotres!
Alexio alreasy started a thread about this dual-head here:
http://www.xtremesystems.org/forums/...d.php?t=106435
__________________
ent is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
