XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > Intel > Intel Info And Support
Reply
Old 08-18-2006, 06:22 PM   #1
CedricFP
CedricFP's Avatar
Merom T7600
This will be the 2.33 ghz 4MB L2 part, right?
I don't own a Conroe system, but how does it shape up against an Opteron 165 @ 2.8?
I am looking to upgrade my laptop - I got the 1.66 Yonah so I could upgrade to 2.33 Merom when they came out, and am wondering how it compares to my sister's desktop.
Cedric
__________________
"Language cuts the grooves in which our thoughts must move" | Frank Herbert, The Santaroga Barrier
i7 920 3924A 205x21 / 4315 | 4870x2 | EVGA M-ATX X58 | 6GB Corsair Dominator | Corsair HX1000 | Intel X25-M 160 G2 | OCZ Vertex 60 | WD 320 || Apogee XT - XSPC FC | (2)DDC3.2 | (2)PA 120.2 | (2)BI SR-1 120 || MM H2G0
CedricFP is offline   Reply With Quote
Old 08-18-2006, 06:50 PM   #2
mitftw
It will destroy that Opteron.
mitftw is offline   Reply With Quote
Old 08-18-2006, 07:26 PM   #3
CedricFP
CedricFP's Avatar
Just hearing that has me giddy for an early Merom release.
__________________
Old 08-18-2006, 07:57 PM   #4
CPLB
CPLB's Avatar
Anandtech has a nice review on the Memron CPUs, though the gaming tests seem GPU limited:
http://anandtech.com/cpuchipsets/showdoc.aspx?i=2808
__________________
AMD Athlon 64 X2 3600+ @ 3.0GHz||Biostar TF560 A2+||4x1GB Team Xtreem D9s||Visiontek HD3870||WD 250GB||Seasonic SS-600HT
AMD Athlon 64 X2 3800+ @ 2.6GHz||DFI NF4 Ultra-D||OCZ VX 4000 2-2-2-5||ATI X1900XT||Seagate 320GB||Seasonic S12 600
CPLB is offline   Reply With Quote
Old 08-18-2006, 08:00 PM   #5
grimREEFER
grimREEFER's Avatar
the 7600 has a 14x multi....happy overclocking lol
__________________
DFI P965-S/core 2 quad q6600@3.2ghz/4gb gskill ddr2 @ 800mhz cas 4/xfx gtx 260/ silverstone op650/thermaltake xaser 3 case/razer lachesis
grimREEFER is offline   Reply With Quote
Old 08-18-2006, 08:43 PM   #6
Miwo
Miwo's Avatar
Send a message via AIM to Miwo
too bad Merom/Yonah hit a FSB wall
__________________
AMD Rig
720BE @ 3.65GHz 1.43v / MSI GD70 / 4GB OCZ Animal DDR3 / vModded 4850 @ 800/1050
Coolermaster CM690 + Z600 Cooler / Corsair 620HX / Dell Perc 5i + 4x32GB JMicron MLC SSD / 1TB WD Black
Intel Rig
E8300 / DX38BT / 4GB DDR3 / HD3850 / 3x 7200.10 Matrix Raid / Sonata III / Earthwatts 500W
Audio / Video
Samsung 37" 1080p LN37A550
Source: HT Omega Claro, Coax out to Denon (multichannel), SPDIF to Zero DAC (stereo)
Receivers: Denon AVR-788, Sony STR-GX900ES
Speakers: KEF IQ3s + KEF Q8S(surround duty)
LFE: Energy S10.3, 2x Aura Pro Bass Shakers mounted on my office chair
Miwo is offline   Reply With Quote
Old 08-18-2006, 09:27 PM   #7
dominos789
While I've lurked quite a bit around the XS forums, I've found almost no information at all on Merom for the laptop.
From what I'm seeing, some ES of Merom are currently available to certain people and may be for sale to those with 100+ posts?
If one was planning to buy a laptop, would it be very possible to buy a barebones (such as the Asus S96j) and stick the Merom in it? How would its performance differ from that of say an e6600?
Is it possible to overclock on a laptop?
Seems to me that although it wouldn't be able to match a Conroe, it would still stay very competitive?
Any help would be appreciated.
dominos789 is offline   Reply With Quote
Old 08-18-2006, 09:44 PM   #8
CedricFP
CedricFP's Avatar
Well I don't plan to overclock too much because I am putting it in my lappy. Just going to swap it with my Yonah.
__________________
Old 08-19-2006, 12:05 AM   #9
Lyshen
Once in a while you will see a Merom on sale on ebay but its rare to see them.
Also I've wondered if part of the reason people hit the FSB wall on Yonah/Merom may be due to straps. I don't know, just I read an article about the different fsb straps that Intel chipsets have. Seeing that the Aopen board can only work at 166 setting clockable up to 199 FSB before you need to remove the two pins to have it work at 200+ FSB, made me wonder if there were only two strap modes available on the Aopen board. Which would eventually hit a limit for the chipset (where the strap modes are controlled) due to being chipset being too overclocked. (But somehow this might not be the case since I remember reading about people putting more volts for the chipset but it did not help)
Granted I don't know a whole lot about straps, but its just something I wonder about. As for the straps article its on OCZ's forums, makes a good read.
Lyshen is offline   Reply With Quote
Old 08-19-2006, 01:54 AM   #10
fhpchris
fhpchris's Avatar
I think the reason is the lower power transistors, my Yonah only does 238x13 on air, and I cant imagine that is limiting the chipset at all with it a 975.
fhpchris is offline   Reply With Quote
Old 08-19-2006, 02:14 AM   #11
xlink
xlink's Avatar
Send a message via AIM to xlink
if I am not mistaken, isn't merom on a diferent socket, socket P, or is that just the later renditions?
if merom is on s775... higher multi here i come...
also, make sure there is chipset support before anything.
to put this all into contrast, yonah is on par with k8 on clock/clock performance, maybe marginally behind, but nothing beyond negligeability. Merom is supposed to be about 20% mroe powerful perclock as comapred to yonah... 2.0GHz Merom therefore should be compareable to an x2 4600/4800+
__________________
PHENOM II x4 720 @3.5Ghz // GIGABYTE GA-MA790X-UD4P // 4GB DDR2-800 4-4-4 // hd4870 512mb // CORSAIR CMPSU-750TX // ZEROtherm Nirvana // Intel X25-M 80gb // 2 * WD 640GB
xlink is offline   Reply With Quote
Old 08-19-2006, 09:47 AM   #12
CedricFP
CedricFP's Avatar
The first generation (batch) of Meroms shall be compatible with current NAPA(sp?) platforms that are currently used by Core Duos (Yonahs) in notebooks. Therefore, theoretically, with a simple bios update, you should be able to simply take out the Yonah and drop the Merom in and have it run perfectly.
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
