08-18-2006, 05:28 AM
#1
Compact SC autocascade (my first)
hi
this is my next ss
compressor is SC18G (3/4hp)
case dimensions
lenght - 50cm
width - 23cm
height - 24cm
regards
08-18-2006, 08:11 AM
#2
Wow, SC18G is chill, first pic doesn't work for me... What refrigerant are you gonna charge with?
08-18-2006, 09:02 AM
#3
maybe r402a, maybe r404a, maybe cyclopropane  (~80 euro/kg)
08-18-2006, 09:14 AM
#4
Okay, Cyclopropane = -32,9 degs celsius boilong point? Isn't that a bit warm?
08-18-2006, 02:25 PM
#5
my fault
this isn't cyclopropane but this gas is condensing @ ~25bar @ 45*C
and vapor @ ~ -70*C @ 0 bar
I don't remember name this gas
08-18-2006, 02:29 PM
#6
Sounds good  How about load handling?
Edit: 80 euros/kg is pretty damn expensive right? Blend with r402a maybe?
08-21-2006, 08:32 AM
#7
boring front of case
in next ss I make another front if I buy dremel
10-01-2006, 04:45 AM
#8
project is alive
10-01-2006, 05:13 AM
#9
Banned
Condesnor is massive!!! Should be good for cooling it all down, no coil need then i guess.
10-01-2006, 09:22 AM
#10
I am Xtreme
He's also using a large copmressor, I'd still put in the coil for vibration dampening though.
__________________
NoL: gom gom gom
Gomeler: om nom nom nom
10-02-2006, 02:49 AM
#11
guys from polish forum suggested me, in order to I make a autocascade.
hmmm, OK
parts for phase separator, interstage hx, slhx, I will use cpev for both stages
10-02-2006, 03:45 AM
#12
looks sweet, willing to see more
__________________
Gaming/benchmarking rig - Intel Core 2 Duo E6600 ES || Asus p5b deluxe vcore, vdroop, vmch and vdimm mods || ATi x1900xtx + ATi x1900 CF edition || 2x1024 Team Xtreem 667 3-3-3-8 || SilverStone 650w || 2x EK blocks for VGA's + D5 + BIX2 || LittleDevil Single Stage
PIC 1 - PIC 2 - PIC 3
10-02-2006, 04:15 AM
#13
-130C Club Member
I would suggest to not use cpev in first autocascade, even for both stages.
What gas you gonna use ? If CO2 as low stage gas, cpev is really bad choice.
I think you should start with captubes, too much load changes for cpev...of course I`m suggesting you, you will do what you want
10-02-2006, 05:00 AM
#14
gas will be r404a/r23
i use cpev for 2 stage
for 1 stage i will use txv or cpev
10-20-2006, 08:12 AM
#15
little update
evap
42mm plugs
brazed phase separator
10-20-2006, 05:13 PM
#16
OCTeamDenmark Staff
Subscribed.
__________________
OCTeamDenmark.com Staff
Cooled and sponsored by Coolerkit.dk
Gigabyte EP45 Extreme | QX9770
2x1 Gb G.skill DDR3 PC3-16000
2xFoxconn 3870, Vcore,Vmem,OCP,Cap mods.
22" Samsung 225BW | Antec 1000 Watt
Mach 2 GT (moddet by t!m) | MX510 - Func F10s
10-20-2006, 05:26 PM
#17
I am Xtreme
Awesome duniek, but your already going to have large problems with your gas selection, I hope you can figure it out from this comment.
__________________
NoL: gom gom gom
10-20-2006, 08:48 PM
#18
-100C Club Member
good luck with the auto-C.
like the 42mm plugs, i had some similar done once.
did you put some copper wool in the seperator?
10-20-2006, 08:52 PM
#19
Why copper?
Whats wrong with basic (cheap) steel wool?
10-20-2006, 09:00 PM
#20
I am Xtreme
Steel wool is very hard to keep from bursting into flames or oxidizing.
ALSO: CPEV may not work the way your wanting it to, it sets the suction pressure, and therefore you'll get an average between the two CPEV's when you don't want that.
__________________
NoL: gom gom gom
10-20-2006, 10:23 PM
#21
-130C Club Member
don`t use R4xx gas, as I talked with NoL, it will separate...
10-21-2006, 05:36 AM
#22
Even with R170 gaz? That's the question I was asking to myself...
10-21-2006, 08:52 AM
#23
-130C Club Member
Even with R170 gas...
R402/R404a or other R4xx gases are mix of two or more gasses, with different P/T charts...
So, there is possibility, that in phase separator R4xx will separate, half of it will go to evap, and second half to HX
10-21-2006, 09:44 AM
#24
I am Xtreme
And since r404a is r507 and r134a, whichever is lighter is most likely to seperate out.
__________________
NoL: gom gom gom
10-29-2006, 07:15 AM
#25
hello
updates
yesterday night I brazed evap
and
cleaned
with insiluation (horrible looking holldown is temporary of course  )
and I make 2 in 1 HX
suction acumulator (42mm pipe) with discharge acumulators (2x15mm pipe inside 42mm)
regards
EDIT:
I used bigger evap than I show in #15 post
It's on right on photo
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
