Okay so i just got the bsod just recently. Since I've had my overclock this is the first. I've been playing far cry for the past week and every once in a while it would freeze, but it was not the sort of freeze that required a restart. Instead all i had to do was ctrl alt delete and switch to program and the game would run again. I did take a picture, but i'm out of town on my aunts computer thats on 26k dial-up
Instead i'll type it all out:
the problem seems to be caused by the following file: wpfb_nv4_disp
THe device driver got stuck in an infinite loop. This usually indicates
problem with the device itself or with the device driver programming the
hardware incorrectly.
technical information:
*** STOP: 0x000000EA (0x897D7BA0, 0x891CB8A8, 0xBACEBCBC, 0x00000001)
I'm really not sure what the problem is, but i did download a beta 1.4 patch for far cry that i think might be the problem. I tried to find it and delete it, but couldn't find it so really i'm not sure or not if it really installed correctly or installed at all. It was a zip file that i had to extract the data from, but again i'm really not sure.
Hope this info i provided helps.
And for the record, this is the only program thats having problems, all my other games and programs run solid.
