Problem with a chilly 1 SS
I got the unti 4 months ago from chilly1 himself and today it started giving me a really odd problem. I woke to my room beign 10C today versus the usual 22C. So I went to turn my computer on and everything worked fine for a bit but then the unit turned itself off saying it reached critical temps. Critical temp being -70C. Its actually not really tclose to that temp at all, its tempsa re really in the usual range (-40s) when i look at cpu temps but for some reason it started showing way lower then it really is and shuts itself off... Can I turn off that safety feature somehow? I am using a gfroster XE v 1,2 controller.
ok WTF now it says it reaches critical tems at -26c, right after it boots... Again nothing wrong with the unit itself its the controller thats shutting it down and showing ridiculous temps. So at this point I can't even reflash the firmware because it wont turn on for long enough to do that.
