XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > General Computer Hardware
Reply
Old 08-07-2006, 09:07 PM   #1
bigKr33
high system temps?
I know smart guardian is not real accurate as i hear, but how do people keep such low system temps? In a 85f room my pwmic loads as high as 65c and my chipset 54c. Even my cpu i think gets a little too high, up to 44c load in dual prime. I saw a couple of forums and they say you should keep both the pwmic and chipset under 50c. Then again there were some other forums that pwmic can easily exceed 70c without issues, and chipset temps are fine if they're under <60c.
When i primed this stable overclock for 24hrs, the temps were the same that i just posted above.
__________________
Gaming PC
In planning stages...
Living Room
46" Sony Bravia XBR4 | Xbox 360 Elite | Arcam AVR-600 rcvr | Paradigm studio 60's v.5 (fronts) bi-amp'd | Paradigm studio cc-590 v.5 (center) bi-wired | Paradigm studio 10's v.5 (rear) | Velodyne optimum-12" sub | Richard Gray 400 pro power conditioner | Analysis oval-12 speaker cable
Heatware
bigKr33 is offline   Reply With Quote
Old 08-08-2006, 08:10 AM   #2
ripken204
ripken204's Avatar
Send a message via AIM to ripken204 Send a message via MSN to ripken204 Send a message via Yahoo to ripken204 Send a message via Skype™ to ripken204
well ill give you my opinion. you said those are your load temps, and im going to say thats yours seem fine considering that you have watercoolin, therefore your cpu fan wont be cooling your mobo as much as it would with air cooling. that pwmic load seems fine to me, thats load remember. if you feel uncomfterable with that then try to mount a fan in that areas b/c the top of the case by drive bays is a big time deadspot for hot air. your cpu temp is fine for load, mine seems to get about that temp for load with air cooling. and wtf is up with ur chipset. whats the idle temp. i have the evercool vc-re too and i rarely see my chipset above 40C and thats including my load time. maybe try remounting it?
__________________
Desktop
|| lappped Q6700 w/ lapped TRUE || ASUS P5Q Deluxe|| Sapphire 4870 1GB || Mushkin Ascent XP2-8500 (2x2GB) ||
|| 2 x WD6400AAKS || Corsair HX620W || Lian-Li PC-60FB || 2 x BenQ G2400WD || Vista Ultimate 64bit ||
|| Samsung SH-S223Q || Logitech MX518 || Logitech Ultra-X || SteelSeries SX || Klipsch ProMedia Ultra 5.1 || ATI TV Wonder 650 PCIe ||
Server
|| E5200 w/ XIGMATEK HDT-S1283 || ASUS P5Q-EM || EVGA 8800GTS G92 w/ Accelero S1 R2 || G.SKILL 6400 2x2GB ||
|| 1 x WD6400AAKS || 4 x 1TB Samsung F1 || SeaSonic M12II SS-500GM || Antec Three Hundred || Samsung SH-203BL || Ubuntu 8.10 ||
ripken204 is online now   Reply With Quote
Old 08-08-2006, 02:22 PM   #3
bigKr33
I don't know whats up with my chipset, you really can't mess up the mount because it uses push pins. But i guess i could mess with it a little. Oh and 54c on the chipset is like the absolute maximum on a hot day in my room (around 85f give or take)
__________________
Gaming PC
Living Room
Heatware
Old 08-08-2006, 02:35 PM   #4
bigKr33
Hey thanks ripken for the idea!! My temps for my for my chipset are now 43-44c, and its 82f in my room right now. All i did was just re-pushed the pins in and and felt them go in a little deeper.
__________________
Gaming PC
Living Room
Heatware
Old 08-08-2006, 05:18 PM   #5
ripken204
ripken204's Avatar
haha, so it wasnt in all the way? oh well, good to hear your happy now. those temps are just about right.
__________________
Desktop
Server
Old 08-08-2006, 06:57 PM   #6
Serra
Xtreme CCIE
Serra's Avatar
As far as the chipset goes, I know ripken already suggested a product... but I might add the Vanteq Iceberq (non-Pro) because I know for sure that will fit properly on your motherboard without interfering with your video card. I use one myself and have as yet to see temps ever rise over 36 degrees celcius. Newer alternatives that we don't yet see much here at XS include the "Jing Ting" heatpipe cooler, and ThermalTake also has a heatpipe NB cooler that looks like a decent contender.
For your PWM's; I've used about 5 DFI boards from that same line (or similar) and they all go about that high without any airflow specifically on them when loaded, and even when they're unloaded I find it takes them a good while to go down. You might try what I did then and just internally mount a 120mm fan pointed at them. For me it regularly took my PWM's from the mid- to high-60's on load down to mid- to high-30's... quite the difference.
__________________
CPU: Dual Xeon E5520
MB: Supermicro X8DTi
Mem: 12GB (6x 2GB) Corsair ECC DDR3-13333
Storage: 4x WD640AALS on PERC 6/i
Case: Sitting on top of motherboard box.
PSU: Cooler Master UPS900
OS: VMWare ESXi 4.0... so... "various"
GPU: N/A
Display: N/A - Accessed via network
Serra is offline   Reply With Quote
Old 08-08-2006, 07:55 PM   #7
bigKr33
My pwmic is sensitive to room temps..example, whenever its around 80f i get rediculous temps of 61c while playing games. When its below 80f my pwmic only hits 52c. I don't know why its like that, but i've noticed that its like that really for all my temps. Its like as if 80f is a threshold for high temps
__________________
Gaming PC
Living Room
Heatware
Old 08-10-2006, 11:24 AM   #8
bigKr33
OMG i cannot believe this, my temps went down even more. Turns out only 1 of the rad fans was on, i must of accidently unpluged it a few weeks ago. My cpu now idles at 31-33c in a 80f room compared to 34-36c like it used to in the same temp room, and my chipset is only at 36c now. Jeeze some many little things can make stupid problems,.
__________________
Gaming PC
Living Room
Heatware
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
