I see you're using a DFI SLI-DR board. If you're worried about installing an operating system with an overclock (because really, even if your system seems stable, is it worth having to reformat because two bits in some random system file were corrupted as a result during install?) then I'd suggest using the CMOS Reloaded feature. Simply save your current BIOS settings into one of the available saved setting areas, then return your BIOS to default configurations. Once you've installed, simply load your BIOS from your saved file and voila: you're back to where you were.
__________________
CPU: Dual Xeon E5520
MB: Supermicro X8DTi
Mem: 12GB (6x 2GB) Corsair ECC DDR3-13333
Storage: 4x WD640AALS on PERC 6/i
Case: Sitting on top of motherboard box.
PSU: Cooler Master UPS900
OS: VMWare ESXi 4.0... so... "various"
GPU: N/A
Display: N/A - Accessed via network
