Is any of you guy`s with this setup having problems with the ati x800 series ?
Its my secound x800 card and the fist card iv had to reboot many times to enter windows.
The secound card can not inter windows at all.
In another computer there is no problems with the ati cards !
and in my computer there is no ploblems at all when ousing another gfx than the x800 series.
Plz help
__________________
OCTeamDenmark.Com Crew sponsored by Coolerkit.dk
Cpu: E8600 Q820A599
Mainboard: Ga-ep45t-extreme
Ram: Kingston1440 cas 8 /Ocz 1280 cas7/ Crucial ballistix 1280 cas 8
Gfx: Hd3870X2
Hd: RaptorX 150Gb
Case: Lian li pc61
What is your Bios/OC settings?
I've had the same setup as you with no problem.
There is an issue with ATI cards. PCI/AGP lock will *not* work if you boot at 200 and OC using Clockgen.
But I cannot see that this is the problem in your case...
I dont have the P4C, but I have the P4P800 SE and an x850xt, and I had similiar problems too.
I never found out what the fix was but everything is fine now.
Are you having a problem where everything boots and seems to be working fine but the monitor doesnt get a signal?
Oh yea, with PCI locks, I havent completly figured it out, but I think you should try different DRAM ratios.
Because, again, I had the same problem and playing with the DRAM ratios seemed to help but Im not 100%.
I sold my x800 xt pe cards.
I`v never found the problem, but there are working fine in other machines, and my computer is working fine with other gfx`s
__________________
Cpu: E8600 Q820A599
Gfx: Hd3870X2
Hd: RaptorX 150Gb
Case: Lian li pc61
