XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > General Computer Hardware
Reply
Old 07-12-2006, 09:23 PM   #1
bigKr33
desperate help with a64 tweaker 0.60v beta
Okay so i was fittling with the timings, and they were working great, but once i was satisfied i decided to go to "file" and set settings to boot up. Something terrible happened. When i rebooted my computer everything loaded great until i got back on to my desktop, the computer would just restart. This has nothing to do with the timings thats causing the restart because everytime i go back into the bios, the timings were unchanged.
I have no idea what to do, and i think its bad enough to the point that i can't get rid of it unless i reformate because my my computer won't stay on long enough for me to delete a64 tweaker. I'm really confused and very pissed off (we've all been there)
Any ideas?'
__________________
Gaming PC
In planning stages...
Living Room
46" Sony Bravia XBR4 | Xbox 360 Elite | Arcam AVR-600 rcvr | Paradigm studio 60's v.5 (fronts) bi-amp'd | Paradigm studio cc-590 v.5 (center) bi-wired | Paradigm studio 10's v.5 (rear) | Velodyne optimum-12" sub | Richard Gray 400 pro power conditioner | Analysis oval-12 speaker cable
Heatware
bigKr33 is offline   Reply With Quote
Old 07-12-2006, 09:39 PM   #2
bachus_anonym
Corsair Engineering
bachus_anonym's Avatar
Send a message via MSN to bachus_anonym
Boot to Windows in Safe Mode - press F8 before your systems starts booting from your hard-drive and choose Safe Mode. Actually, on DFI you can hold that F8 already during POST. This will load Windows without any Startup items, including A64Tweaker. Then you'd be able to either remove A64Tweaker altogether or delete the apprioprate registry key. After you're done with it, just restart like you normally do...
Changes done with A64Tweaker "don't stick" so after restarting your machine your BIOS will not have any memory timmings/settings changed. It will revert to whatever you set in BIOS.
EDIT: Just for your reference... A64Tweaker stores those startup settings in an .ini file of its folder. To avoid loading A64Tweaker on startup, you either need to delete this file or use Regedit to find A64Tweaker key in HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run and then delete that key.
__________________
3ch 3x2GB WR - Dominator 2000C7GT @ DDR3-2560 7-8-7-20
bachus_anonym is offline   Reply With Quote
Old 07-12-2006, 09:45 PM   #3
bigKr33
You have no idea how much i love you right now , j/k, but seriously that you. I'll try that right away, lets hope it works ::crosses fingers::
__________________
Gaming PC
Living Room
Heatware
Old 07-12-2006, 09:55 PM   #4
bigKr33
IT WORKED!!! thank you thank you!!
__________________
Gaming PC
Living Room
Heatware
Old 07-12-2006, 09:56 PM   #5
bachus_anonym
Corsair Engineering
No problem
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
