XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Vapor Phase Change Cooling
Reply
Old 07-11-2006, 02:39 PM   #1
[XC] gomeler
Diablo 3! Who's Excited?
[XC] gomeler's Avatar
Send a message via AIM to [XC] gomeler
Condenser Source
Besides Undertheice are there any other sources for condensers for our applications? I talked to the ceo/president of a coil producer and he quoted me $375 to tool a factory and then I think ~$30 for each condenser I just need something that'll work for an autocascade and I am worried that the little 6x6 inch condensers would be too smal. If you know of a source on this planet, please PM/Link.
__________________
Team PURE is about kickass pirates and unicorns defeating ninjas.
[XC] gomeler is offline   Reply With Quote
Old 07-11-2006, 02:46 PM   #2
jinu117
-100c Club Member
Unfortunately, we are stuck between rock and ground on this. Reason I had to get that custom condenser made in first place. I wouldn't mind producing larger one but unless I have reason to use 100+ of those big sizes... it just is too much dead weight inventory in my end. I do know that some other countries are cheaper (china? :P) and willing to work with you for small quantities too. But don't expect miracle. I suggest just eating it up and getting some blissfield from local refrigeration shop for time being or go look for surplus coil shops around and counting on your luck.
Good luck and let me know if you find one
__________________
http://www.vapoli.com/Images/Forum/vapoli.jpg
Single Stage Work Logs
Originally Posted by killermiller View Post
Those ccb's will die if you look at them wrong.
heatware: jinu117
jinu117 is offline   Reply With Quote
Old 07-11-2006, 02:51 PM   #3
n00b 0f l337
I am Xtreme
n00b 0f l337's Avatar
Send a message via MSN to n00b 0f l337
Ebay blissfield condensers are cheap if your okay with steel.
__________________
NoL: gom gom gom
Gomeler: om nom nom nom
n00b 0f l337 is offline   Reply With Quote
Old 07-11-2006, 02:57 PM   #4
Blaster
-100c Club Member
Blaster's Avatar
Send a message via MSN to Blaster
go to a refrigeration store and and ask for a 1/4 hp condenser for low temp
Blaster is offline   Reply With Quote
Old 07-11-2006, 03:36 PM   #5
[XC] gomeler
I went to my local United Refrigeration and they reccomended me to www.boisdarccoils.com. I'm talking to them to see how much limited production runs of condensers would be, if I can get the cost down cheap enough I might buy a dozen or so and sell them to various builders. Looking into blissfield condensers, steel wouldn't be an issue.
__________________
Old 07-11-2006, 03:38 PM   #6
[XC] gomeler
Whew those blissfield condensers are cheap, how well do they handle dissipating heat when compared to a similar sized copper/aluminum condenser?
__________________
Old 07-11-2006, 08:13 PM   #7
[486]
Xtreme Cruncher
[486]'s Avatar
just found thisand it looks a lot like vapo condensors and to get a lower price just google it and find a different site that sells them
EDIT: found them for $36 here
[486] is offline   Reply With Quote
Old 07-11-2006, 09:36 PM   #8
Ssilencer
Ssilencer's Avatar
Send a message via ICQ to Ssilencer Send a message via MSN to Ssilencer
That is meant to be used with watercooling, I'm not sure if it can witstand the pressures.
I can source condensors of any size and design, as I already told to Jinu, and also cheaper and better quality than that, the problem is I'm far away from the states, and also that I can't keep asking my dealer for just one condensor or they will kill me, or what is worse, not selling me anymore.
Ssilencer is offline   Reply With Quote
Old 07-11-2006, 09:53 PM   #9
n00b 0f l337
I am Xtreme
That radiator isnt brazed together but the ends are simply glued in.
__________________
NoL: gom gom gom
Old 07-12-2006, 06:13 AM   #10
Moc
Moc's Avatar
You can get very nice and i think cheap condensors from cold_ice but he lives in Austria .
http://www.extremecooling.net/random...uessiger/5.jpg
http://112233445566.free.fr/Phase%20...s%20summum.jpg
Moc is offline   Reply With Quote
Old 07-12-2006, 09:13 AM   #11
[486]
Xtreme Cruncher
[486]'s Avatar
fck i almost bought one!!!, sorry if andyone bought one
Old 07-12-2006, 10:00 AM   #12
Dimas
Dimas's Avatar
Send a message via MSN to Dimas
where are you located?
__________________
DIMASTECH Official Support
Extreme Cooling BLOG
BENCH TABLES REV2.5 LINK
Dimas is offline   Reply With Quote
Old 07-14-2006, 04:01 PM   #13
[486]
Xtreme Cruncher
[486]'s Avatar
with the one i found is it the u bends or the inlet/outlet that are glued on?
Old 07-14-2006, 05:28 PM   #14
LostInSpace278
LostInSpace278's Avatar
Try this website. http://usamfg.net/
LostInSpace278 is offline   Reply With Quote
Old 07-14-2006, 06:05 PM   #15
n00b 0f l337
I am Xtreme
The ubends are glued in.
__________________
NoL: gom gom gom
Old 07-17-2006, 07:49 AM   #16
aussie_guy00000
aussie_guy00000's Avatar
It all depends on what capacity you're after mate. I sell the STVF range of Lu-ve condensors, and they are rated at 470w up tp 2000w @ delta 15k and come in various sizes with a 240v fan, info sheet here http://www.advancedpccooling.com.au/Pictures/STVF.pdf. Although the 240v fan is probably not suitable for 110v, i'm sure they sell a 110v version in the states. Kayl is using one in his latest cascade that he's building http://www.xtremesystems.org/forums/...ad.php?t=97321 although that's the STVF100, the smallest one would be ideal for a single stage. Oh and the prices on that info sheet aren't mine, their recommended retail, I sell them for cheaper . So do a search near you and see if any of the refrigeration places stock em .
aussie_guy00000 is offline   Reply With Quote
Old 07-17-2006, 10:35 PM   #17
Athens[2004]
Athens[2004]'s Avatar
Technical data:
Material: pipes copper (outer diameter 8mm), lamellas aluminium, side screens stainless steel.
Measures outside (L x W x H): 167 x 134 x 57.5mm
Weight: approx. 840g
Mounting options: 4x bores at the top (for 1 x 120mm fan)
Pressure tested: 30 b
Surface: powder coated black, stainless steel grinded
Connections: 2x threads G 1/4 inch (in angle of 90ø)
Price: 33,50 EUR
link
__________________
Post Qu1ck d1e Young.
Athens[2004] is offline   Reply With Quote
Old 07-19-2006, 06:25 PM   #18
tnk45
Send a message via AIM to tnk45 Send a message via Yahoo to tnk45
Ebay Heat Exchanger
I bought this from an ebay seller. http://cgi.ebay.com/500-PSIG-Heat-Ex...QQcmdZViewItem
*Dimensions are 8"x10"x2"
*Possible Uses:
*AC Evaporator
*Transmission cooler
*Hydraulic cooler
*Cab Heater
*Etc.
*The ID is 1/4" and the OD is 5/16" and the tubing is copper.
It's $10 + 10 for regular shipping or 15 for priority shipping. I opted for priority and it came pretty quick. It's quite big and I think it's an overkill for my single stage.
If you want to buy it now, either email him directly asking for $20 shipped or he has a buy it now option in another listing for $23+10 shipping. He has many of these units, so you buy a whole bunch if you like. Hopes this help someone.
tnk45 is offline   Reply With Quote
Old 07-19-2006, 09:08 PM   #19
[XC] gomeler
Wow what a beast, I might have to snag one just for the hell of it. Thanks for the great links guys.
__________________
Old 07-19-2006, 09:16 PM   #20
n00b 0f l337
I am Xtreme
Make sure you pressure test that.
__________________
NoL: gom gom gom
Old 07-19-2006, 09:34 PM   #21
jinu117
-100c Club Member
Says 500 PSIG which is good Other than copper bit oxidized, it looks good
__________________
heatware: jinu117
Old 07-19-2006, 10:18 PM   #22
n00b 0f l337
I am Xtreme
How would you mount that to a board or case and also make a shroud?
__________________
NoL: gom gom gom
Old 07-20-2006, 04:55 PM   #23
[XC] gomeler
With some creative welding or well placed screws. Welding + condenser = swiss cheese if not careful though :-\
__________________
Old 07-20-2006, 05:05 PM   #24
n00b 0f l337
I am Xtreme
I just noticed it had feet for mounting to a board, that makes it alot easier. I bid on 2 last night and only got one, but oh well.
That and I have two h-50's on the way! :P
__________________
NoL: gom gom gom
Old 07-21-2006, 01:58 PM   #25
ICE COOL
pm me dude for dimensions and how many you need.
ICE COOL
__________________
visite my new site for all stuff what you get http://members.lycos.nl/icecoldcpu/
ICE COOL is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
