XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme Teams > Xtreme 3D Team
Reply
Old 07-05-2006, 02:45 PM   #1
EnJoY
XIP
EnJoY's Avatar
Send a message via ICQ to EnJoY Send a message via AIM to EnJoY Send a message via MSN to EnJoY Send a message via Skype™ to EnJoY
X1600XT's, do they allow software volt mods?
As the title says, do X1600XT's allow their voltages to be modified in software (such as ATITool) like their X1800/X1900 brothers do?
EnJoY is offline   Reply With Quote
Old 07-05-2006, 02:57 PM   #2
NickS
I am Xtreme
NickS's Avatar
I know for sure that X1600 Pro's dont but I'm not sure about XT's. Did you try looking at some reviews of some, or googling it?
Nick
__________________
C2D E7200 @ 3.6GHz, 1.31v
Stock Q6600 HS/F
MSI P45 Neo3-FR
G.Skill 4GBPQ 8000's
Sapphire HD3870 Toxic 512MB
WD3200AAKS Single Platter
Enermax Liberty 500w
X-Fi XtremeMusic
CoolerMaster CM590
Vista Home Prem. X64 SP1
Westinghouse L2410NM
Logitech MX500, Saitek Eclipse, Logitech G25
NickS is offline   Reply With Quote
Old 07-05-2006, 10:31 PM   #3
EnJoY
XIP
EnJoY's Avatar
I'll just ask w1zzard I guess, don't know why I didnt do that in the first place.
Old 07-05-2006, 10:36 PM   #4
NickS
I am Xtreme
NickS's Avatar
Good point.. why bother anyway, I see in your sig you already have an X1800XL...
__________________
Stock Q6600 HS/F
MSI P45 Neo3-FR
X-Fi XtremeMusic
CoolerMaster CM590
Old 07-05-2006, 10:39 PM   #5
ZX7891
ZX7891's Avatar
Send a message via AIM to ZX7891
nearly 100% positive they dont
__________________
Q6700
MSI P35
8GB OCZ
2xHD 2900 XT
PCP&C 1kw
ZX7891 is offline   Reply With Quote
Old 07-06-2006, 12:45 PM   #6
EnJoY
XIP
EnJoY's Avatar
Eh, cause I am considering having some fun with a pair of powercolor's bravo edition cards in crossfire.
W1zzard says they don't support software vmods btw, but the hard vmods can be done with a pencil and are the same mods that are for the X1300.
Old 07-06-2006, 02:25 PM   #7
Winterwind
Winterwind's Avatar
no software voltmods for X1600.. non for PRO nor XT
__________________
CPU: AMD Phenom II X3 710 @ 3.25GHz / 1.265v
CPU COOLER: Xigmatek HDT-SD964
MB: Gigabyte GA-MA790GP-DS4H (HT 2500MHz / NB 2500MHz)
RAM: 2 x 2GB A-Data Over Clock Extreme 1066+
GFX: MSI Radeon HD4850 512MB @ 740/1075
HDD0: Western Digital Caviar GP WD10EADS 1TB
HDD1: Western Digital Caviar GP WD10EADS 1TB
PSU: Zalman 460W
Winterwind is offline   Reply With Quote
Old 07-06-2006, 07:28 PM   #8
STEvil
tl;dr
STEvil's Avatar
Send a message via ICQ to STEvil Send a message via MSN to STEvil
odd, my sapphire x1600xt's show option to change volts with atitool?
__________________
Heatware || 01.01.08; AND 110.9%
Dead Z7S-WS? Click!. || XS Z7S-WS Thread || Current Dead Asus Z7S-WS count: 14 of 16 (Thats nearly $10,000 in dead motherboards).
All along the watchtower the watchmen watch the eternal return.
Want to use my Anti-asus logo? Go ahead, but use this link please!: http://i853.photobucket.com/albums/a...sus/noasus.gif
LIST OF GAMES WITH ACTIVATION LIMITS/SONY SECUREROM 7: http://knowyourgame.reclaimyourgame....with+SecuROM+7
STEvil is offline   Reply With Quote
Old 07-06-2006, 07:39 PM   #9
NickS
I am Xtreme
NickS's Avatar
Time to upload your BIOS for EnJoY .
__________________
Stock Q6600 HS/F
MSI P45 Neo3-FR
X-Fi XtremeMusic
CoolerMaster CM590
Old 07-06-2006, 11:25 PM   #10
Winterwind
Winterwind's Avatar
and if you change them then you can oc higher?
__________________
PSU: Zalman 460W
Old 07-06-2006, 11:52 PM   #11
STEvil
tl;dr
STEvil's Avatar
they do 600/900 on stock volts (some artifacts) and 600/800 24/7.
I tried upping the volts back when I got the first one (couple months ago) but was met with crashes when using ATi Tool so I gave up.
I'll poke around with it tomarrow, maybe x1k overclocker will help.
__________________
Old 07-07-2006, 11:32 AM   #12
EnJoY
XIP
EnJoY's Avatar
W1zzard (ya know, the author of ATITool), has said himself that voltage changes do not work on the X1600 series of cards, they can only be hard modded at this time. The reasoning for this is that the bios of the cards only tells the cards to switch from pre-specified 2d voltages to pre-specified 3d voltages, and these cannot be changed.
Old 07-07-2006, 09:02 PM   #13
STEvil
tl;dr
STEvil's Avatar
yup, seems to just be phantom options.
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
