XtremeSystems Forums
Reply
Old 06-28-2006, 12:48 PM   #1
bigKr33
leaking radiator
My computer is done, but whenever i'm leak testing (which i'm still doing by the way) My fitting keeps leaking. The past 4 days i've been trying every means necessary to stop it leaking, but have failed everytime.
My first attempt was 5 layers of teflon tap, it started leaking so i tryied super glue and it still leaked, so i tried putting some silicon cauk over that and still failed. At that point i said screw it i'll dismantel the radiator and redo the fittings. So fir this attempt i tried liquid teflon and sealed the outside of the fittings with silicon cauk. I was pretty confident it was going to seal, but nop inevitably it leaked again. I've pretty much have given up, i don't know what to do. I'm pretty dissapointed in thermochill, they make these expensive radiators that took me over a week and a half to clean, and still all those tin particles arent out, and they give the most ****y fittings on the planet. I'd rather spend an extra $100 for the damn thing to come clean out of the factory with fittings that actually work.
Anyone at all have any suggestions. I'm pretty bumbed out at the moment, i've been working on this water cooling project for too long, and now i'm not even sure if its worth to water cool, its just been way too tedious.
__________________
Gaming PC
In planning stages...
Living Room
46" Sony Bravia XBR4 | Xbox 360 Elite | Arcam AVR-600 rcvr | Paradigm studio 60's v.5 (fronts) bi-amp'd | Paradigm studio cc-590 v.5 (center) bi-wired | Paradigm studio 10's v.5 (rear) | Velodyne optimum-12" sub | Richard Gray 400 pro power conditioner | Analysis oval-12 speaker cable
Heatware
bigKr33 is offline   Reply With Quote
Old 06-28-2006, 12:53 PM   #2
Trice
Send a message via AIM to Trice
Where is it leaking? The actual threading portion of the rad?
__________________
Desktop
intel Conroe Q6600 L727B 3.4GHz 1.35v (425x8)
ASUS Maximus Formula (Rampage BIOS)
eVGA 9800 GTX 760/1900/1150
4GB Crucial PC2-6400 DDR2 1000MHz 5-5-5-18 2.2v
(1) 150GB Raptor
(1) 300GB Seagate 7200.9
Sound Blaster X-Fi Xtreme Music
PC Power and Cooling 510 SLI
Water Cooled (Storm, PA 120.2, DDC-1+ with XSPC ResTop, MP-1)
Notebook
Dell Inspiron 9300
intel Pentium-M Dothan 2.133 GHz (1.246v at 2.133 .700 at 800 Mhz)
nVidia GeForce 6800 GO 350/755
2GB 4-4-4-12 DDR-2 677
NEC DVD-R/W Dual Layer
80 GB 7200 RPM Hitachi
intel Pro Wireless 2200 b/g
Trice is offline   Reply With Quote
Old 06-28-2006, 01:19 PM   #3
bigKr33
I know its coming from the fitting. And yes its leaking from the threads. I'd rather just find some fittings that use rubber seals, because that would honestly work a whole lot better.
__________________
Gaming PC
Living Room
Heatware
Old 06-28-2006, 01:20 PM   #4
Trice
I didnt really like their barbs either, but I never had any leaking issues with them.
Order the Cooltechnica Barbs.
__________________
Desktop
(1) 150GB Raptor
Notebook
Dell Inspiron 9300
Old 06-28-2006, 01:42 PM   #5
tdunks
tdunks's Avatar
Send a message via MSN to tdunks
are you wrapping the teflon right? It should be wraped tightly nd that alont should make it not leak..takes 5-10 layers though but if it still leaks after that there is either a crack or the barb is a bit too small.
tdunks is offline   Reply With Quote
Old 06-28-2006, 01:46 PM   #6
bigKr33
of course i was wraping the teflon right, but as of now i'm using teflon paste which molds better, and its still leaking. The barbs that the radiator come with are just to soft, and don't seal properly. I'm gonna buy some new barbs, so now i just need to know what size threads the radiator uses.
And trice what barbs did you buy, i see barbs on their page, but i don't know what size the rad uses, fittings that use a rubber seal is prefered. Thanks in advance.
__________________
Gaming PC
Living Room
Heatware
Old 06-28-2006, 01:51 PM   #7
andersson.j
Send a message via MSN to andersson.j
ThermoChill use 3/8 barbs.
andersson.j is offline   Reply With Quote
Old 06-28-2006, 01:52 PM   #8
bigKr33
npt, npsm? need to know what type
__________________
Gaming PC
Living Room
Heatware
Old 06-28-2006, 01:57 PM   #9
andersson.j
G3/8 BSPP
Old 06-29-2006, 03:24 AM   #10
Marci
XIP - thisoneisonus.org
Marci's Avatar
Our rads don't include fittings. You are left to choose from a range when purchasing from us, so ultimately the choice of fittings is yours.
If you didn't purchase the rad from us, then the fittings are what the reseller chose to bundle with it - nothing to do with us. They have the choice of buying whatever fittings they choose from us - most resellers choose not to and source their own fittings - nothing to do with us.
3/8" BSP fittings, metal, with 5/6 wraps of PTFE tape WILL seal EVERY time if done right. I know this as I've built well over 1000 rigs with every one done the same way, with the same fittings, and the same PTFE tape.
You'll find the correct fitting thread type for EVERY rad produced by us listed in it's description at www.thermochill.com - tis easy enough to find.
We make radiators the same price as everyone else in this country. It's YOUR exchange rate and economy that makes it so expensive in your country. Again, nothing to do with us. If you want them cleaning further, then price will go up further. Whilst everyone is content to sit and moan about the price, we aren't going to make them cost more by putting them thru a lengthy cleaning process.
Marci is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
