XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme > Xtreme Mods
Reply
Old 06-24-2006, 08:02 AM   #1
SSJ5
The Tools of the Trade
What someone should have in his workshop when doing mods? I know that the basic tool is the soldering iron but are there any other tools to help (especially when you have to solder tiny joints...)
SSJ5 is offline   Reply With Quote
Old 06-24-2006, 09:33 PM   #2
sluggo
Most useful is an illuminator with a magnifying lens. Something like http://www.dickblick.com/zz551/29/. Very handy for close work. You will also want a "thirrd hand", which is basically a pair of clamps attached toa weighted base. this helds keep your board in a good working position.
sluggo is offline   Reply With Quote
Old 06-25-2006, 12:09 PM   #3
Asazman
Send a message via AIM to Asazman
one word: dremel. a wide variety of screwdrivers and random comp parts definetly helps.
Asazman is offline   Reply With Quote
Old 06-25-2006, 12:11 PM   #4
hixie
Where's me Beer?
hixie's Avatar
A PCB holder will also come in handy.
hixie is offline   Reply With Quote
Old 06-25-2006, 12:13 PM   #5
K404
Xtreme Mentor
K404's Avatar
DMM
Some way of keeping the board still is VERY helpful, as is a positionable "3rd hand" as suggested above to keep the component being soldered in place
__________________
Proudly using
Crucial Ballistix
Xigmatek air
watercooling by XSPC
Originally Posted by T_M View Post
Originally Posted by soundood View Post
you sigged that?
why?
K404 is offline   Reply With Quote
Old 07-01-2006, 03:49 PM   #6
InSanCen
My own little world
InSanCen's Avatar
Dead parts to strip for spares... essential. Have re-capped everal boards cannibalising dead boards with decent caps.
Modding cases? Bondo or Milliput (I prefer the latter, cheaper and (for me at least) easier to work with).
Dremel has already been mentioned, but I think that a Standard drill and Jigsaw is essential (Wore out 6 dremel bits cutting a 92mm fan hole before I used Jigsaw & 36TPI Metal blade, was like a knife through butter)
Workbench. Cannot overstate this. preferably at a decent height (I'm 6foot3, so most people hate mine). to do good work, you have to be relaxed & Comfortable.
__________________
CPU:6400BE RAM:6GB, MB:GA-M57SLI-S4, GPU:512MB HD3870, CASE:Stacker STC-T01,
COOLING:XSPC 120.3, XSPC Delta, Eheim 1250, MC Micro. KB:IBM M13, RODENT:Logitech MX518 + I-One Lynx R-15
InSanCen is offline   Reply With Quote
Old 07-02-2006, 12:48 AM   #7
tennvols_69
Send a message via MSN to tennvols_69 Send a message via Yahoo to tennvols_69
if your gonna do circuit mods the basic tools i would recommend is a good iron... by good i mean a weller or better. a set of dental picks and some trace kits.some good wire and good strippers. a set of jewlers screwdrivers. a mini drilbit(useful when making your own boards) some quality flux.(i perfer liquid flux). several tips for your weller, they make smd tips that work well for replacing smd componets.
__________________
DFI NF4 Ultra D/3800 x2 @ 2.5ghz/2x512 BH-5/ EVGA 7800 GT /OCZ 600W PowerStream
tennvols_69 is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
