06-15-2006, 10:36 AM
#1
preping pa120.2
How long did it take to prep yours? The first day i did about 3-4 of distilled water, I would fill it half way and just shack the crap out of it for 30 secs, repeated that 2-3 more times till i finally filled it up with distilled vinegar w/5% acidic and had it sit for 20hrs.
Then i did like 5 passes of shacking and flushing the rad with distilled water. Filled up again with vinegar and had it sit for 20hrs.
Then i did another 5 passes of shacking and flushing with distilled water. Filled it up with vinegar had it sit for 4 hrs.
Flushed it out with 6 passes of distilled water. Filled it back up with vinegar and had it sit for 15hrs. And as of right now i'm doing my passes with distilled water.
And still the radiator still has these black looking particles coming out of it. I'm not sure if its actually coming out of the rad, or if its just the paint on the threads for the fittings. Because i've notice that everytime after i flush the rad, theres less paint showing on the threads and more brass color.
I just wanted to know if you guys were having the same problem when you were preping.
__________________
Gaming PC
In planning stages...
Living Room
46" Sony Bravia XBR4 | Xbox 360 Elite | Arcam AVR-600 rcvr | Paradigm studio 60's v.5 (fronts) bi-amp'd | Paradigm studio cc-590 v.5 (center) bi-wired | Paradigm studio 10's v.5 (rear) | Velodyne optimum-12" sub | Richard Gray 400 pro power conditioner | Analysis oval-12 speaker cable
Heatware
06-15-2006, 10:55 AM
#2
Egyptian OverClocker
why nto do the shaing with vnegar and nto distilled water
__________________
DFI Ultra-D, Opteron 165, G.Zkill ZX 2GB, Gigabyte 8800GT
Married since 26/12/08 and still enjoying my honeymoon
06-15-2006, 10:56 AM
#3
don't mean to be rude, but i have no idea what you just typed
__________________
Gaming PC
Living Room
Heatware
06-15-2006, 10:58 AM
#4
he said why not do the shaking with vinegar and not distilled water?
__________________
I had the fastest 32M Opteron time for about 1/2 day, and I'm damn proud of it
06-15-2006, 11:13 AM
#5
oic, thanks. I guess i'll try that
__________________
Gaming PC
Living Room
Heatware
06-15-2006, 11:29 AM
#6
LOL
sorry for that
__________________
06-15-2006, 12:17 PM
#7
no problem
__________________
Gaming PC
Living Room
Heatware
06-15-2006, 08:26 PM
#8
XS_THE_MACHINE
That sig quote would go so good with nn_step's "dont do smack"
__________________
Asus P5B-Deluxe 0614
Conroe E6400 @ 2.56ghz
Team Xtreem DDR2 2x1GB @ 900
ATI X1900XTX // MC14 Ramsinks -DEAD- Using spare 7900gt now
Hitachi 80gb | Hitachi 80gb | Seagate 320gb
Mountainmods U2-UFO Original Black \\ BenQ DVD-RAM
Corsair Hx620
Swiftech Storm r2 \\ Swiftech MCW60 \\ Swiftech MCW30 \\ Thermochill PA120.3 \\ Swiftech MCRES Micro \\ DDC+ Plexi Top
Heatware | Guide To Current WaterCooling Components | Guide To WaterCooling and Leak Testing
06-16-2006, 08:15 AM
#9
LOL
i am sure i wasn't drunk when i wrote that
__________________
06-16-2006, 08:25 PM
#10
How long does it usually take you guys to clean your radiator out? Mine still has those black particles coming out  . I'm on day 4 now.
Also does it really matter what order i have my loop? I'm using a storm which is a pretty retrictive block from what i hear and a swiftech mcw60 (going to sell maze4 gpu block), and a thermochill pa120.2.
My flow plan was to have it go from pump>rad>cpu>gpu>pump. This setup for my case would be more logical because tubing would be a much cleaner setup, and a more logical layout, but would it affect temps?
And another question. What could i use to clean the white resedue on my radiator fins?
Sorry for all the questions, but help a brotha out.
__________________
Gaming PC
Living Room
Heatware
06-17-2006, 02:54 PM
#11
Xtreme Mentor
I just flushed a dirty GT240 with half a gallon of distilled water to get it clean. I guess it depends on the rad. Flush till clear would be a safe bet.
__________________
Q9550 @ 4.105 Ghz
Gigabyte P45 UD3P F9
G.Skill PC2-8800 DDR2-1100 8GB Memory
1/2" ID Masterkleer, Swiftech MCP-655, Thermochill PA120.3 Rad, D-Tek FuZion pro mounted, FuZion GFX 2
Cooler Master UCP 1100 Watt PSU
MSI HD5870 1Ghz (1.16v), 1300Mhz
Lian Li PC V-2000
Acer X222Wbd 22" LCD
3 x WD 640GB WD6400AAKS HD
Pic of my watercooled rig
06-18-2006, 06:06 PM
#12
Okay something new just happened. Two days ago when i made my last reply, i said those black were coming out, well that night 3:15am to be exact i manage to completely flush them all out. And since everything elso about the radiator was clean i concluded that it was finished. Aparently i was wrong, just for the hell of it, i decided to mock my rad up to see how it would look in my case. It fits fine, but i heard some left over distilled water sloshing around so i figured "what the hell lets open it up". A whole **** load of these white particles came out that glimer when sunlight passes through.
I was pretty pissed when i saw this. I spent hrs a day cleaning this rad, thought it was finished and this happens. I don't know what these particles are and i've done about 4 passes so far of just poring and draining distilled water and it just keeps coming. Does anyone have any idea of what these particles are? When i first started cleaning the rad when i received it up until i got done cleaning it i never saw any of these particles. When i first poured the left over water today, it had a hint of vinegar smell in the water, but after that it was odorless. Do you think maybe when i thought i was cleaning the rad., that i didn't completely get all the vinegar out, and it started to possibly eat its way through the rad?
I have know idea what is going on, and i'll continue cleaning the rad i guess till i can figure it out.
__________________
Gaming PC
Living Room
Heatware
06-18-2006, 06:59 PM
#13
XS_THE_MACHINE
i dont think that copper is edible by vinegar....
__________________
Corsair Hx620
06-18-2006, 07:18 PM
#14
Well i was thinking about it earlier and well i think its vinegar that sits for awhile, in this case a couple of days. I noticed before when i had the vinegar sit over night, and then the next day when i flushed it then cleaned with distilled water, that i would get the same crap, but only a small margin. So i guess the best thing to do, is to get as much of the old vinegar out that i can possibly get out before installation.
Just a thought, but who knows
__________________
Gaming PC
Living Room
Heatware
06-18-2006, 07:30 PM
#15
Xtreme X.I.P.
bigKr33, I get the same thing after cleaning the rad.. its POSSIBLE that it is the tin that the vinegar is eating, but its not too likely that it eats it in such way that it flakes like that..
I found that the flakes are just annoying and dont hurt the system.. if u want to get rid of them i suggest you run your radiator in a loop with just it, a pump (obviously) and a filter. The filter will pick up all of those particles. Let it run for 1 or 2 days.. by the end of that time it should be free of those nasty particles.
06-18-2006, 08:58 PM
#16
I have the same problem as bigKr33 with my black ice xtreme 2, I've spent two days flushing with distilled water, vinegar and so forth and when I look at the water its still small white particles in it. I don't want those dim-tubes AGAIN ( happened to me twice before ) so I want to make shure everything is perfect beforce I assemble it yet again.
06-18-2006, 09:31 PM
#17
XS_THE_MACHINE
ive redone my loop 3 times... this time i flushed with alot of hot tapwater (faucet) and then just let it dry out
__________________
Corsair Hx620
06-18-2006, 09:55 PM
#18
The ultimate question is however, are these particles that maxxxRacer is talking about a problem in a water loop? In all honesty if they don't do anything, then i won't worry about it. I've spent a total of probably 12-15hrs over the course of 5 days cleaning this rad its very tideous and time consuming. This is the only problem thats holding me back from continuing my first water cooled system, and in all honesty i just want to get it over with.
__________________
Gaming PC
Living Room
Heatware
06-19-2006, 04:59 PM
#19
Hey maxxxracer, i was browsing over your water loop testing guide and that filter that you recommend from mcmaster is just what i need. It uses mpt 3/8 fittings, but i need it to support 1/2in tubing. I'm having trouble trying to find an adapter for a 3/8 male fitting that uses a 1/2 barb for my 1/2 tygon tubing, can you help me out?
If not i guess i could just buy some cheap 3/8 tubing just for the cleaning process and just run that pump>filter>rad>pump procedure for 2 days. Either way it has to be done.
__________________
Gaming PC
Living Room
Heatware
06-21-2006, 08:59 PM
#20
Okay i finally got my filtration loop setup pump>rad>filter>pump. I'm confused though because now i have the loop to the point to where its almost full, but it got to a point that i know its not full but wouldn't continue to fill. So i tried pressing that little red button in on top of the filter (the filter from maxxxracers leak test guide) to see if anything would happen, and water slowly started coming out of the top of the filter as i hold it in.
I don't know if thats a good sign or a bad one, but it doesn't seem to do me any good. Am i doing anything wrong? I desperately need help, i've been working on this water cooling project for over a month and i just want to get it done, but i can't until this rad is fully cleaned.
__________________
Gaming PC
Living Room
Heatware
06-21-2006, 09:01 PM
#21
XS_THE_MACHINE
*wakes up from suicudal deppresion*
yay XS is alive!!!!!!
__________________
Corsair Hx620
06-21-2006, 10:19 PM
#22
I have some white crap in my rad as well, and it starts to stain my loop so I just bought a new one lol
__________________
Desktop
intel Conroe Q6600 L727B 3.4GHz 1.35v (425x8)
ASUS Maximus Formula (Rampage BIOS)
eVGA 9800 GTX 760/1900/1150
4GB Crucial PC2-6400 DDR2 1000MHz 5-5-5-18 2.2v
(1) 150GB Raptor
(1) 300GB Seagate 7200.9
Sound Blaster X-Fi Xtreme Music
PC Power and Cooling 510 SLI
Water Cooled (Storm, PA 120.2, DDC-1+ with XSPC ResTop, MP-1)
Notebook
Dell Inspiron 9300
intel Pentium-M Dothan 2.133 GHz (1.246v at 2.133 .700 at 800 Mhz)
nVidia GeForce 6800 GO 350/755
2GB 4-4-4-12 DDR-2 677
NEC DVD-R/W Dual Layer
80 GB 7200 RPM Hitachi
intel Pro Wireless 2200 b/g
06-21-2006, 10:27 PM
#23
Wtf? Are you kidding me? Geeze, how about you buy me some new watercooling stuff then.
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
