XtremeSystems Forums
Reply
Old 06-13-2006, 11:26 PM   #1
Vapor
Admin
Vapor's Avatar
Black water
Okay...the theme of my new case is all black....and the tubing is sticking out a bit more than I'd like.
Anyway to make the water black and not have it be a cesspool? I could just sleeve the tubes, I know...but that's a last choice if possible (but, fwiw, I really haven't been able to think of anything to even make the water black safely, let alone still have it be good performing )
__________________
Current Waterblock Testing
Roundup #2: Overall Comparison Thread, Alphacool Livingstone, Alphacool Niagara, Alphacool Yellowstone, D-Tek Fuzion V2, EK Supreme, EK Supreme LT, Enzotech Sapphire Rev A., Heatkiller 3.0 LC, Heatkiller 3.0 LT, Koolance CPU-345, Koolance CPU-350, Phobya, Swiftech Apogee GTZ, Swiftech Apogee GTZ SE, Swiftech Apogee XT
Vapor is offline   Reply With Quote
Old 06-13-2006, 11:40 PM   #2
dastt
dastt's Avatar
i would say add a whole lot of darkblue/red/darkgreen food coloring to you water, it would more than likely dye/stain everything though.
dastt is offline   Reply With Quote
Old 06-13-2006, 11:46 PM   #3
Vapor
Admin
Vapor's Avatar
Yeah, that's what I thought :-/
Sleeving is looking more and more attractive, lol.
__________________
Old 06-13-2006, 11:50 PM   #4
jellybeard999
you can get black tygon...
http://www.ocforums.com/showthread.php?t=355118
not sure where stocks it though
jellybeard999 is offline   Reply With Quote
Old 06-13-2006, 11:55 PM   #5
Vapor
Admin
Vapor's Avatar
Hmmmm, I can get that from McMaster....that's certainly an option (and has looks to kill).
Anything I can just add to water though? That'd add a good 4 more days to my build time, which I don't really have
__________________
Old 06-14-2006, 12:11 AM   #6
dnottis
Xtreme Mentor
dnottis's Avatar
Originally Posted by phelan1777
I know you said you want black,
but think about this?
Black every thing, and a deep purple liquid.
Like blood in a creature.
Just an odd thought.
Good luck with the all black, and I saw an image somewhere with black tubing, cant remember off hand sorry :-(
hahah - what is with you and blood lately!!!
__________________
Q9550 @ 4.105 Ghz
Gigabyte P45 UD3P F9
G.Skill PC2-8800 DDR2-1100 8GB Memory
1/2" ID Masterkleer, Swiftech MCP-655, Thermochill PA120.3 Rad, D-Tek FuZion pro mounted, FuZion GFX 2
Cooler Master UCP 1100 Watt PSU
MSI HD5870 1Ghz (1.16v), 1300Mhz
Lian Li PC V-2000
Acer X222Wbd 22" LCD
3 x WD 640GB WD6400AAKS HD
Pic of my watercooled rig
dnottis is offline   Reply With Quote
Old 06-14-2006, 12:23 AM   #7
TSXmike
TSXmike's Avatar
Send a message via AIM to TSXmike
thats what im thinking... but i do like the idea...
__________________
*running*
Abit AN8 32x
Opteron 170 @2700
G.skill DDR400 1GBx2
eVGA 7900gto x2
Corsair HX620w
CM RC-690
BenQ FP222W
TSXmike is offline   Reply With Quote
Old 06-14-2006, 12:31 AM   #8
ReD.SkY
XS_THE_MACHINE
ReD.SkY's Avatar
Send a message via ICQ to ReD.SkY Send a message via AIM to ReD.SkY Send a message via MSN to ReD.SkY Send a message via Yahoo to ReD.SkY
or you could go realistic and actually try the blood
but yah, the deep puple would be teh pwnage
__________________
Asus P5B-Deluxe 0614
Conroe E6400 @ 2.56ghz
Team Xtreem DDR2 2x1GB @ 900
ATI X1900XTX // MC14 Ramsinks -DEAD- Using spare 7900gt now
Hitachi 80gb | Hitachi 80gb | Seagate 320gb
Mountainmods U2-UFO Original Black \\ BenQ DVD-RAM
Corsair Hx620
Swiftech Storm r2 \\ Swiftech MCW60 \\ Swiftech MCW30 \\ Thermochill PA120.3 \\ Swiftech MCRES Micro \\ DDC+ Plexi Top
Heatware | Guide To Current WaterCooling Components | Guide To WaterCooling and Leak Testing
ReD.SkY is offline   Reply With Quote
Old 06-14-2006, 12:33 AM   #9
Vapor
Admin
Vapor's Avatar
Deep purple.....hmmm, maybe, might be too light though (no joke).
__________________
Old 06-14-2006, 12:41 AM   #10
ReD.SkY
XS_THE_MACHINE
ReD.SkY's Avatar
is there going to be a window?
i really have no idea how to get it *black* maybe try using a sharpie or a marker with a reservoir in it and pour it in... tubing will stain, but the Delrin on a WB wont matter, and copper can be cleaned
__________________
Corsair Hx620
Old 06-14-2006, 12:43 AM   #11
Vapor
Admin
Vapor's Avatar
I care more about the pump's internals.
...but the sharpie ink is a good idea if it's not ionic in any way
__________________
Old 06-14-2006, 03:33 AM   #12
javascripterror
Black Tygon looks the part and stops any fungus or algae from growing. It cuts out the light they require.
javascripterror is offline   Reply With Quote
Old 06-14-2006, 05:14 AM   #13
Vapor
Admin
Vapor's Avatar
It just stops that kind of algae (and likely not fungus)....and algae growth isn't a concern to me. Introducing an ionic fluid (or ionizing the water that's there) is my big concern.
I've also had to rule out the black Tygon, definitely not worth the effort and system downtime required to redo my loop when I could very easily sleeve over and have it truly match everything (including my sleeved SATA cables). Unless someone knows a way to actually make the water black, I think I may just sleeve
__________________
Old 06-14-2006, 06:01 AM   #14
Deathknight
I think you have the theme for your next rig. Some nice horns on top, maybe DVD drive could have a mouth painted around it? Nothing better looking than a furry case!
On a more serious note, I am not sure I would want to fill a loop with black tubing anyway. I would like a little more warning that it was about full than I would get from the coolant shooting back out my T-Line as I filled it!
Deathknight is offline   Reply With Quote
Old 06-14-2006, 06:10 AM   #15
dnottis
Xtreme Mentor
dnottis's Avatar
Originally Posted by Deathknight
I think you have the theme for your next rig. Some nice horns on top, maybe DVD drive could have a mouth painted around it? Nothing better looking than a furry case!!
Already been done - called the Diabolic.
__________________
Q9550 @ 4.105 Ghz
Lian Li PC V-2000
Old 06-14-2006, 07:30 AM   #16
Vapor
Admin
Vapor's Avatar
Fuzzy Wuzzy was a bear....
__________________
Old 06-14-2006, 07:53 AM   #17
Deathknight
Hmm when I envisoned this rig for phelan1777 it had bits of gore hanging out of the mouth, and maybe a few wounds, like it just got back from the hunt
Old 06-14-2006, 08:32 AM   #18
Slayer2k3
Slayer2k3's Avatar
VW and Audi antifreeze, is a deep purple color, pricey, but dark.
Add that, and some red watter wetter, and you should have a very dark mix.
__________________
Slayer2k3 is offline   Reply With Quote
Old 06-14-2006, 09:18 AM   #19
Deathknight
I am using Pentosin (VW and Audi antifreeze). It is dark undiluted, but mixed with distilled water it comes out a nice light blue color. You would need to run pure antifreeze for that affect I think.
Example:
Fuzzy Wuzzy had no hair.
Fuzzy Wuzzy wasn't very fuzzy was he?
Old 06-14-2006, 09:30 AM   #20
Ominous Gamer
Ominous Gamer's Avatar
Send a message via AIM to Ominous Gamer Send a message via MSN to Ominous Gamer Send a message via Yahoo to Ominous Gamer
Big thanks for posting that black tygon!
I'm current planning / building a MM UFO mirror case, with black acrylic windows and highlights. This tubing will go with it perfectly!
(Now to find a place that stocks and sells it a few feet at a time.)
Ominous Gamer is offline   Reply With Quote
Old 06-14-2006, 01:40 PM   #21
cirthix
The un-extreme XIP
cirthix's Avatar
Send a message via AIM to cirthix
home depot has black tubing
__________________
Q6600@3.6ghz 1.45V ----- 8gb ocz ddr2-1000
XFX 5850@900/1200 1.15V
1TB hitachi+2x30gb OCZ Vertex v1.41 raid 0
520HX corsair power supply ----- half-size shuttle!!
30" 3007wfp-hc 2560*1600 lcd
unicomp clicky keyboard+logitech trackball
cirthix is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
