XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Vapor Phase Change Cooling
Reply
Old 05-27-2006, 11:07 PM   #1
Gray Mole
Gray Mole's Avatar
New Chilly 'Duo' for Meta-Morphis
I've been working slowly away at the dual evap rotary project for someone from O-CuK forums, and thought I'd post pics of how it's coming along
I've been slowed down on my work lately, but I've developed some severe Carpal Tunnel in my wrists and it's agony just to type at the moment. Hopefully the British Medical system helps me out with that soon but for now it just makes the work go a little slower. Losing feeling in 4 out of 5 fingers on each hand sure makes it hard to 'feel' what you're doing
Anyways, the controller will be coming from Ssilencer and Golden Eagle when the K-probe system is ready for the 'X' based controllers and will have all of the needed safeties and such.
The spec currently on it...
3/4HP Carrier Mitsubishi Electric rotary compressor
2 previous revision Chilly1 heads
3m of .031" captube per head
Common suction and short flexi per head
6 row condensor
90cfm condensor fan
65cfm exhaust fans x 2
Custom Dimas 'Tall Boy' case
Full 'R-Blox' (tm) sound insulation
Gas currrently for testing has been 404a, but will very likely be 402a in the final step.
The wiring is just there for testing that will all be redone to my satisfaction later on as well.
The older Chilly heads were used for a reason. The capacitor clearance...well every bit of clearance is incredibly tight on this motherboard, so the extra couple of mm you get makes all the difference in ensuring the mount is good.
The line is a full 1/2" bore flex, but there's a 2.5" per head short flexi line to the solid tubing that goes into the flexi to the compressor. That is just enough to allow the heads to very easily flex into position when mounting.
That lineset was a real challenge to make, not just for the intricacies of a common suction, but getting the dimensions 'just right' was harder than it looks Wish I'd gotten pre-insulation pics, but I may be stripping it down fully when I redo it for it's final setup and if I do, will get pics of the 'naked' line then.
Sound insulation. Rotaries are notoriously loud, but this will ensure reasonable noise levels. Only a 'boot' for the suction line to keep the noise from getting out of the top hole, and a 'baffle plate' for the rear to allow airflow, but very little noise, is still being made.
The backplates I'm using for testing with 150w load resistors. The system will have a full single backplate for the install, only the heads will remain independant for best contact.
you know what 'big hands' means
The intended 'victim'
Edit, just a quick 'frosty' shot
That motherboard will have a couple of self adhesive 'seal pads' made for it, and the foam rings made from slightly smaller, and shorter foam and the insulation from the board will 'reach up' to the rings. That's mainly due to the capacitor clearance. I've got loads of self adhesive 6mm neoprene, and will do a couple of extra pads for him if he needed to replace the mobo later or anything like that
And that's about it for now.
I didn't get pics of the temp and load testing out in the shed, but that can wait for now. It's a little cramped in my little shed with all the work lately
Temps are currently about -65 idle and -44 load per head. The balance is amazing and I'd recommend a common suction to anyone for better balance on dual head if it's at all possible as I think that's really helping. With 402a and a little more playing with it, I'm pretty sure that -50 per head shoudl be about right.
I don't like the configuration of the filter, I tried that to get a strong liquid backpressure going but it's a little more than I was after and it's easy enough to play on that part of it. The insulation and heatshrink will be redone nicer later on, was just having a play to see how difficult it would be to 'pretty that up' a little
My wife won't let me do any temp or load testing in the house until the sound insulation is done though doesn't like my 'noise'. Silly woman
So yeah, will update this post with more later on as I get more done, and the controller arrives
Cheers
Gray
__________________
Nearly back from the dead.
Gray Mole is offline   Reply With Quote
Old 05-27-2006, 11:14 PM   #2
martinjon666
martinjon666's Avatar
my wife is like that too, i spend a lot of time on my unit and all she says si "oooohhh it has frost!"
but what can you do?
martinjon666 is offline   Reply With Quote
Old 05-27-2006, 11:21 PM   #3
bazx
-100c Club Member
bazx's Avatar
there will be some good reading over @ocuk when this lands
hope ya fingers get better
baz
bazx is offline   Reply With Quote
Old 05-27-2006, 11:28 PM   #4
4Qman
-100C Club
4Qman's Avatar
Send a message via MSN to 4Qman
Dude looks awsome,
I go with the Cold is more important approach when it comes to noise, girls ay.Lol
Rest ya hands gray as you work to hard, Altho i wasnt saying that when i wanted my Unit built.lol
Anyway CLass yet again.
ResPect...
4Qman is offline   Reply With Quote
Old 05-28-2006, 12:21 AM   #5
twisted5
Nice work there Gray. I wish I could do something that nice
__________________
DFI NF4 SLI-DR Expert Venus #s 909, 917, 924 w/ FragTek Sysxtreme Mosfet/Ram Cooling Bracket
Opteron170 CCBWE 0550 UPMW Testing
2GB G.SKILL DDR500 @3-4-7-3 1T
7900GTX SLI (650/1600)
PC POWER AND COOLING 1KW
2x74gb Raptor Raid 0
2xSeagate 7200.9 300gb
NEC 3550A x2
Heat:twisted5
twisted5 is offline   Reply With Quote
Old 05-28-2006, 01:09 AM   #6
Unseen
insomnia...
Unseen's Avatar
Send a message via MSN to Unseen
nice dual head there
Unseen is offline   Reply With Quote
Old 05-28-2006, 01:56 AM   #7
SoddemFX
SoddemFX's Avatar
Very nice Gray
Those Rotaries are loud little hummers
Would love to see some pictures of the line assembly without insulation.
Great work dude,
Tom
__________________
"What will become of us, will we evolve"
SoddemFX is offline   Reply With Quote
Old 05-28-2006, 02:15 AM   #8
maverik-sg1
Gray mate,
Fantastic job, looks like my CPC records could be tumbling shortly - watch out PCMark also.
The sound proofing looks almost a necessity with rotary comp's - probs need some sort of anti vibration mounts between the bottom of the case and the floor.
Carpal tunnel mate - not good that, the ops are 80%+ successfull, but the recovery period is about 6 weeks mate, it's worth giving it the full 6-8 weeks too as the chances of a full recovery are much improved.
Mav
maverik-sg1 is offline   Reply With Quote
Old 05-28-2006, 02:22 PM   #9
ludeboy12
ludeboy12's Avatar
dude that looks awesome. great job.
__________________
C2Q Rig.... C2Q Q6600 @ 3.6ghz | Abit IP35 Pro | 2 x 1gb G.Skill DDR2 PC6400 | eVGA 8800gts 320 x 2 | Silverstone TJ-09
i7 Rig.... i7 920 @ --ghz | eVGA x58 | 3 x 1gb G.Skill DDR3 1600 | eVGA -------- | Caseless
FAH Quad / GPU Farm....To be continued....
My Folding Stats...
ludeboy12 is offline   Reply With Quote
Old 05-28-2006, 02:43 PM   #10
FragTek
Banned
FragTek's Avatar
Send a message via ICQ to FragTek Send a message via AIM to FragTek Send a message via MSN to FragTek Send a message via Yahoo to FragTek
Wow man, you've done great! A dual head for a dual proc mobo, that's so awesome.
Can't wait to see some pix of everything together with some temp readings on both procs!!
FragTek is offline   Reply With Quote
Old 05-28-2006, 06:36 PM   #11
Gray Mole
Gray Mole's Avatar
Thanks everyone
It's great to see positive feedback on the project for sure.
I haven't actually heard back from Meta-Morphis about how it's coming along and all that, but hopefully he likes how it's coming together.
Sound proofing of some kind is totally essential with rotaries if you want something reasonable for noise.
I tested this with the panels on and it's livable really. The fan in the front is a bit noisy too though, so really it's never going to be a 'quiet' solution but that wasn't really the idea. He wants it to be a powerful 24/7 cooling solution and that's exactly what he's going to have. The sound deadener and all that, it was my idea He's always said from the start that it being noisy wasn't much of an issue. It's definitely NOT louder than the 4 or 5 Delta focussed flow fans in his other rigs
Anyways, cheers guys
Gray
__________________
Old 05-29-2006, 08:40 AM   #12
yngndrw
yngndrw's Avatar
Send a message via MSN to yngndrw
That's really great Mr Mole. Having the common suction line saves a lot of space over having two suction lines.
Keep it up.
__________________
yngndrw is offline   Reply With Quote
Old 05-29-2006, 08:46 AM   #13
Big SturL
HVAC/R student
Big SturL's Avatar
Send a message via ICQ to Big SturL Send a message via MSN to Big SturL
Yeah, might wanna fix the pix.
__________________
...is no longer working as an assistant HVAC/R-installer...
But, is still blasting 20000 songs of real Rap
Big SturL is offline   Reply With Quote
Old 05-29-2006, 08:51 AM   #14
twisted5
What's wrong with them? Nothing I can tell....
__________________
NEC 3550A x2
Heat:twisted5
Old 05-29-2006, 08:55 AM   #15
yngndrw
yngndrw's Avatar
The pics are fine for me also .. I think it's a problem at your end Big SturL.
__________________
Old 05-29-2006, 11:35 AM   #17
404Power
404Power's Avatar
Location: Universe #1 --> Earth --> Europe --> Austria --> 120km NW of Vienna :D
Send a message via ICQ to 404Power Send a message via MSN to 404Power
HOLY *biieeeeep* ... this unit looks damn nice!
RLY nice work there Gray!
Keep it up!
btw.: no probs. here with pics @ Firefox 1.5! ^^
__________________
404Power is offline   Reply With Quote
Old 05-29-2006, 12:09 PM   #18
Blaster
-100c Club Member
Blaster's Avatar
Send a message via MSN to Blaster
looks good !
Does the sound insulation works?
Blaster is offline   Reply With Quote
Old 05-29-2006, 12:13 PM   #19
[XC] MarioMaster
Xtreme Cruncher
[XC] MarioMaster's Avatar
Send a message via AIM to [XC] MarioMaster
looks good, i'd be afraid to pay for the power bill for something like that though, be like adding a room air conditioner. i had a large recip for my chiller (maybe 1/3hp) and it made the lights in my garage dim when it started
__________________
|Rig: AMD Athlon64 X2 6000+ Windsor|6gb DDR2 800|Dual 250gb Western Digital RAID0|8600GT|
(12:16:17 AM) OC3D NoL: NOL EAT ANNOYING NOOBIE
(12:16:19 AM) OC3D NoL: RAWRRRR
[XC] MarioMaster is offline   Reply With Quote
Old 05-29-2006, 12:41 PM   #20
Gray Mole
Gray Mole's Avatar
Of course the power to run it will be more than for a small system but I'm pretty sure it's less than running 2 mach units.
Would have to check that on a meter to see for sure, but I'd be surprised if it was much more.
The sound insulation would be even better if it was a 'foam' type, but I was quite impressed with how much it did for the noise. It was a little louder than a Vapo would be of course, but the front fan was louder than the compressor noise so I'm pretty happy with how that worked out.
Once the 'boot' is made to block the top hole, and the baffle plate is done to minimize the rear exiting noise, it should be very reasonable
Cheers
Gray
__________________
Old 05-29-2006, 01:16 PM   #21
Suffocation
Suffocation's Avatar
looking very nice ! keep up the good work
Suffocation is offline   Reply With Quote
Old 05-29-2006, 07:48 PM   #22
C-BuZz
C-BuZz's Avatar
Really nice work there Gray. Very professional finish!
Keep up the good work.
C-BuZz
C-BuZz is offline   Reply With Quote
Old 05-30-2006, 09:41 PM   #23
johann
johann's Avatar
I missed this one somehow, was thinking of exactly the same thing lately for My PC-DL but my cpus are clocked so high already I keep putting it off.
Very nice idea gray with the common suction line, must have been quite the challenge to build up.. I was thinking the same but then started thinking towards a dual line again to make it compatible with other and maybe newer xeon solutions where cpus ae placed differently.
All in all amazing unit Send it to me Ill test it
__________________
My Phase change builds thread
johann is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
