XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Air Cooling
Reply
Old 05-24-2006, 12:36 PM   #1
Vapor
Admin
Vapor's Avatar
Push/pull with two (very) different fans?
Technically this is a watercooling question, but it mostly deals with fans, so I figured I'd ask here.
Wondering if a push/pull design with two very different fans would be worth anything...the fan I'm planning to push with has more CFM out through the rad than the pull fan has total (I put my face on the rad and measure that way, much more accurate than hands it seems).
The push fan would be ~100CFM (at peak, it won't always run that fast) and the pulls are around 60CFM if I had to guess (unrated, came with my PC-7B+).
I have these fans lying around and I'm really not sure what to do with them
__________________
Current Waterblock Testing
Roundup #2: Overall Comparison Thread, Alphacool Livingstone, Alphacool Niagara, Alphacool Yellowstone, D-Tek Fuzion V2, EK Supreme, EK Supreme LT, Enzotech Sapphire Rev A., Heatkiller 3.0 LC, Heatkiller 3.0 LT, Koolance CPU-345, Koolance CPU-350, Phobya, Swiftech Apogee GTZ, Swiftech Apogee GTZ SE, Swiftech Apogee XT
Vapor is offline   Reply With Quote
Old 05-24-2006, 02:08 PM   #2
WASD
WASD's Avatar
Send a message via MSN to WASD
So these fans would be on opposite sides or the same rad? If that's what you meant, I wouldn't do it. Having an extra fan will cause more interference than anything else, especially with the fast one blowing into the slow one.
WASD is offline   Reply With Quote
Old 05-24-2006, 02:26 PM   #3
Vapor
Admin
Vapor's Avatar
Alright, that's what I thought...now to figure out what to do with these fans though
__________________
Old 05-24-2006, 03:02 PM   #4
WASD
WASD's Avatar
Send them to meeeeeee!
Old 05-24-2006, 05:29 PM   #5
ken
ken's Avatar
let the 60cfm push and use the 100cfm to pull, IIRC its better that way (from my Shuttle day)
__________________
E3110@3.6Ghz || Gigabyte P45-DS3 || 2GB Cellshock 6400 || Asus HD4850||
ken is offline   Reply With Quote
Old 05-24-2006, 06:14 PM   #6
Serra
Xtreme CCIE
Serra's Avatar
Yes, smaller to push, larger to pull.
__________________
CPU: Dual Xeon E5520
MB: Supermicro X8DTi
Mem: 12GB (6x 2GB) Corsair ECC DDR3-13333
Storage: 4x WD640AALS on PERC 6/i
Case: Sitting on top of motherboard box.
PSU: Cooler Master UPS900
OS: VMWare ESXi 4.0... so... "various"
GPU: N/A
Display: N/A - Accessed via network
Serra is offline   Reply With Quote
Old 05-25-2006, 03:20 AM   #7
cromwello
will get better air speed and latent pressure with it small to big so i wud go for it that way.
__________________
athlon 64 4000,2x1gb XMS 4000@250mhz-2.5,3,3,7,leadtek 7800gtx extreme @550/1.39 stock volts,hiper type R 520W,400gb HD's.
cromwello is offline   Reply With Quote
Old 05-25-2006, 04:47 AM   #8
Mr. Tinker
Mr. Tinker's Avatar
Gosh, it'd be hard to calculate what cfm a pulling fan needs to move to be worth it. It'd have to be moving air better than with no fan. If it actually moves less air than what is coming out of the rad with only one fan, it's not worth it.
__________________
ebay under aws983s, heatware under Mr. Tinker.
Mr. Tinker is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
