05-23-2006, 12:19 PM
#1
Xtreme Mentor
Water temp monitor.
I'm thinking of placing this temp monitor on the third 1/4 thread of my DDC Ultra's plexi top. What do guys think?
__________________
Asus Rampage II Extreme
Intel I7 920 D0 3930A @ 4.35GHz (20 X 217mhz) WC'ed
3 x 2GB G.Skill Trident 1600 @ 1740MHz (7-8-7-20-1T)
Asus 4870X2 @ 850/950MHz WC'ed
150gb Western Digital Velociraptor | 2 x 320gb Western Digital Caviar SE16 Raid0 | Seagate FreeAgent XTreme 1.5TB esata
Logitech Z-5500 | LG W2600HP 26" S-IPS LCD
MountainMods UFO | Zalman ZM-850HP psu
Watercooling setup:
1st loop -> Radiator: ThermoChill PA 120.3 | Pump: Laing DDC Ultra with Alphacool top | CPU: Swiftech Apogee XT |Chipset: Swiftech MCW-NBMAX | Tubing: PrimoFlex 1/2" Pro LRT
2nd loop -> Radiator: XSPC RX240 | Pump: Laing DDC Pro with Alphacool top |GPU: EK FC-4870X2| Tubing: PrimoFlex 1/2" Pro LRT
05-23-2006, 01:06 PM
#2
Xtreme Guru
youd be better off putting it in a t-piece, as water in the unused barb of the DDC will stagnate and thus the temps will not be indicative of actual water temps - keeping in mind that a deltaT accross radiator is often under 1c.
__________________
Originally Posted by Bloody_Sorcerer
flowrate is for losers!
Originally Posted by MaxxxRacer
Thermaltake is kind of like AIDS; it won't go away just by ignoring it.
05-23-2006, 01:09 PM
#3
Xtreme Mentor
So it would be better if i could get a res with more than 2 holes so as to plug it there?
__________________
Watercooling setup:
05-23-2006, 01:19 PM
#4
Xtreme Guru
That or use a t-piece like I did...
__________________
05-23-2006, 01:23 PM
#5
Xtreme Mentor
OK. Thnx m8.
__________________
Watercooling setup:
05-23-2006, 01:31 PM
#6
T-piece all the way
You could also use a free port on your res if you have one, still I like it to be close to the rad...
__________________
Intel Core 2 Duo E8500 | MSI P45 Neo2-FR | OCZ PC2-9200 Reaper HPC | Zotac GTX 285 | SilverStone TemJin TJ-03 Nimiz | Enermax Modu82+ 625W
EK Supreme | Watercool GPU-X² | Thermochill PA 120.2 | Petra's Tech DDCT-01 w/DDC-2
05-23-2006, 01:35 PM
#7
Xtreme Mentor
Right now i don't have on my res (DD single bay) but when i'll open my loop i may change the res with this one along with its bay...
If not i'll do the t-line thing.
__________________
Watercooling setup:
05-23-2006, 01:39 PM
#8
Xtreme Guru
*pokes radical for rad test results*
__________________
05-23-2006, 01:40 PM
#9
Xtreme Mentor
__________________
Watercooling setup:
05-23-2006, 05:12 PM
#10
In my rads case thats .6-.8c idle and 1.2c-1.3c load. THe delta T that is.
__________________
My pc: |||Abit AL8-V||| P4 631@4.6ghz||| 4x512 PDP pc2-4200@4-4-4-12 2.0v|||1x250gb WD 16mb sata||| 6600gt 500/1000@ 610/1240||| TDK dvd burner||| watercooled cpu and gpu and custom moded case.
Project Hard Lined
05-23-2006, 05:18 PM
#11
My solution to T line temp sensor.
My second sensor.
Get a really tiny fitting and bore it out to acept a temp sensor from a digidoc. Then solder in a copper core to cap the top. Then rebore it with a dull bit to get a round surface area at the tip. After all asembled put one row of electrical tape around the sensors wires to prevent shorts. Then put some non cunductive thermal paste (ceramique in my case) and insert sensor all the way. Add a cuple of drops of crazy glue to the tape and it will stick.
Simple as pie and in my case it works very well. Cheeper than those prefitting craps too.
__________________
Project Hard Lined
05-23-2006, 11:29 PM
#12
Well, got to work sometimes too you know?  They'll come.
__________________
05-24-2006, 12:27 PM
#13
t-line all the way
__________________
Apple Macbook Pro º 2.4GHz Intel Core 2 Duo º GeForce 8600M GT 256MB º 2GB 667MHz DDR2 º 15" TFT LED backlit display // Dell 2407WFPHC // Xbox360 // Ek + Swiftech blocks in storage
r3vo+PC Fall_06 Build
Spring Customer Build
05-24-2006, 12:40 PM
#14
Xtreme Mentor
Very nice el rolio.
__________________
Watercooling setup:
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
