05-20-2006, 02:55 PM
#1
Why is my Opteron 165 faster at SuperPI when SP2004 is also running?
Hi!
I tested this many times and its weird. If I run SuperPI and assign one core to do it my best score was 28.282 after many tries. The funny thing is that if I run superpi core 0 (for example) and at the same time SP2004 to core 1, I will get better super pi times consistently! This is very weird. My best has been 28.141 and I am able to hit that mark consistently for as long as sp2004 is running.
Any thoughts? Perhaps sort of the same as assigning high priority?
__________________
Main PC
*CPU: i7 920 DO @ 4.1Ghz 1.35v HT On
*CPU Cooler: Noctua NH-D14 SanAce/Scythe/Delta
*Mobo: Evga X58 SLI
*RAM: 3x2GB OCZ DDR3 OCZ3P1600LV6GK 7-7-7-24 1.65v
*Video Cards:XFX GTS250 Physx card & Evga GTX 295 dual pcb
*Sound Card: X-Fi Prelude| Speakers: Strata Mini + ELT 525s (AV123)
*PSU: Corsair HX1000W
*Display:Samsung 2233RZ 3D Vision!!! | Mitsubishi 60" DLP (3D) 3D Glasses (stunning!)
*Windows 7 64Bit on GSkill Falcon V1 SSD 64GB
*Case: CoolerMaster HAF932
*Others: Logitech MX518 | SteelSeries Pad | Ratzpad GS | Logitech G15
HTPC Rig
*Case: Aspire X-Navigator
*CPU: Intel E8500 OCed 4.2Ghz (8.5x495) 1.35v bios
*Cooler: Scythe Ninja first edition with Yate Loon
*Mobo: Asus p5K-e Wifi bios 1202
*RAM: 2x1GB Crucial Tracer@495fsb(1:1) 4-4-4-12
*Video Cards: ATI HD2600 Pro
*Speakers: Rocket HT & MFW15 (AV123.com)
Cameras: Pentax K20D & K100D
05-20-2006, 03:11 PM
#2
Originally Posted by shaolin95
Hi!
lol, might wanna add this as a tweak in the extreme oc/pi section
__________________
Athlon XP-M 2500+ Barton 0343MPMW | 2938, 226x13, 2.000v vcore
Abit NF7-S 2.0 | Antec TruePower 480w | X800GTO 16pp 256mb, 398/493
2 x 256mb Corsair PC3500 | 2.0-2-2-11 1T 1:1 | 2.90v vdimm | 1.70v vdd
Intel vs. AMD can be described as this:
Long and thin gets it in, but, short and thick does the trick.
05-20-2006, 04:28 PM
#3
Did you try assigning SuperPi 32M to one core and 1M on the other?
__________________
ASRock 939Dual-SATA2 (04XX)
O165 CCBWE 0551 UPMW 1.8 GHz @ 2.6 GHz (9x289x4) 1.525V IHSless (SI-120 Bolt Modded)
Corsair XMS 2GB DDR-400 2-3-3-6 2.75V @ DDR-473 3-3-2-1 2.5V
ATi X800 Pro 475/450 @ 535/500
SB Audigy 4
Samsung 80GB 2MB PATA HDD
3DMark05: 6000
Ishkur's Guide To Electronic Music
05-20-2006, 05:11 PM
#4
Havent tried that yet. I know that running dual superpi doesnt make them faster though. I did try using realtime priority and it did help to hit the 28.141 so it seems to be creating the same effect that running sp2004 does. Kind of weird that it scores better when the other core is fully busy.
Can someone else try it just to validate this strange behavior.
__________________
Main PC
*Mobo: Evga X58 SLI
HTPC Rig
05-20-2006, 05:47 PM
#5
just tried that on my 170, and it scored aobut 2s slower with sp2004... could be that i dont have enough ram, as im currently playing with only 1 512 stick. nevermind, it was on blend, i set it to small ffts, it brought the superpi to the same level as with no sp2004, but not any lower.
05-20-2006, 06:15 PM
#6
Maybe you are ram limited who knows.
__________________
Main PC
*Mobo: Evga X58 SLI
HTPC Rig
05-20-2006, 08:40 PM
#7
That is really wild
__________________
Originally Posted by creidiki
Dont mind R.S kids, he's just bitter because Dell dont make their PCs in pink.
05-21-2006, 04:12 PM
#8
bench it with 3dmark or something and compare cpu scores with and without sp2004
05-21-2006, 04:32 PM
#9
How can you take the noise from that jet engine on you cpu
__________________
Opteron 165 0550 UPMW Reatil With Retail Heatsink
DFI Ultra - d
Enermax Liberty 500
2 GB GSkill UCCC
Leadtech 6800 GT
WD Sata2 250 GB KS
XP SP2
Stacker STC101
05-21-2006, 05:00 PM
#10
well, what do you know. i was ram limited. i put my 2gb kit back in, and running sp2004 does have the same effect as running real time. i ran superpi a few times in a row to establish a margin of error, it was ranging between 34.76 to 34.67. when i ran sp2004 on core 1, the score went down to 34.203, definetely out of the margin of error.
05-21-2006, 06:27 PM
#11
Honestly, you get used to it...besides I am a headphone gamer anyway and the benefits of not worrying about water leaks or dead pumps let me sleep better at night :-)
cky2k6, thanks for testing it. It only seems to work with some programs not all. I noticed that cause I was trying for a quick stability test and decided to try sp2004 and superpi 32mb. Previously my best time was 26mins + but that time I did 25mins so I was totally surprised.
Regards
__________________
Main PC
*Mobo: Evga X58 SLI
HTPC Rig
05-21-2006, 10:08 PM
#12
Xtreme Mentor
when running only SuperPI, did you actually assign it to core 0 or didn't you touch the affinity? If you didn't, windows would try to balance the load on both the cores, thus making it slower in these sort ot tests.
__________________
Platform: DFI CFX3200-DR; AMD Opteron 185 w/ TTBT
Memory: 2GB Mushkin Redline XP4000 @ 260MHz 3-3-2-8
Video: Jetway HD 4850 512MB @ 750/1125 w/ SI-128; Samsung 206BW
Audio: Creative X-Fi Fatal1ty; Logitech Z-5500; Sennheiser HD515
Storage: 4x Seagate ES.2 250GB on Adaptec 1430SA; 1x Seagate 7200.11 500GB
Power: Seasonic M12 700W
05-21-2006, 10:38 PM
#13
I use affinity all the time, thats why its weird at least imho.
__________________
Main PC
*Mobo: Evga X58 SLI
HTPC Rig
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
