05-19-2006, 01:16 PM
#1
Xtreme Mentor
VGA cooling.
Is there a slot fan similar to this that suck air from the outside and will blow it on the vga?
__________________
Asus Rampage II Extreme
Intel I7 920 D0 3930A @ 4.35GHz (20 X 217mhz) WC'ed
3 x 2GB G.Skill Trident 1600 @ 1740MHz (7-8-7-20-1T)
Asus 4870X2 @ 850/950MHz WC'ed
150gb Western Digital Velociraptor | 2 x 320gb Western Digital Caviar SE16 Raid0 | Seagate FreeAgent XTreme 1.5TB esata
Logitech Z-5500 | LG W2600HP 26" S-IPS LCD
MountainMods UFO | Zalman ZM-850HP psu
Watercooling setup:
1st loop -> Radiator: ThermoChill PA 120.3 | Pump: Laing DDC Ultra with Alphacool top | CPU: Swiftech Apogee XT |Chipset: Swiftech MCW-NBMAX | Tubing: PrimoFlex 1/2" Pro LRT
2nd loop -> Radiator: XSPC RX240 | Pump: Laing DDC Pro with Alphacool top |GPU: EK FC-4870X2| Tubing: PrimoFlex 1/2" Pro LRT
05-19-2006, 01:19 PM
#2
Banned
I've never seen one that sucks air from outside and blows onto the card
05-19-2006, 01:43 PM
#3
Jupp.... that's just stupid.
05-19-2006, 02:24 PM
#4
I wanted to do that so i swapped the power round but it didnt work  i dont think you can..
05-19-2006, 02:29 PM
#5
I don't know if it qualifies as stupid, but i've never seen one.
__________________
Core 2 Duo E6400 (Scythe Infinity) @3.2ghz, 1.3v
Asus P5B Deluxe | 2gb G.Skill HZ DDR800
PNY 9600GT (Zalman VF900CU)
OCZ GameXStream 700w | 2x320GB Seagate 7200.10
X-FI XtremeMusic | Antec P180 | Logitech G5
New Build Starting Soon! Input Requested!
05-19-2006, 02:33 PM
#6
Yes there are 1, I need try find it as shop no longer has in stock, it was blue and read with red LED 2 fans 1 fan sucked in from outside case other only mixed up air in xase and you could swivels its direction, It may have been gigabyte.
05-20-2006, 08:55 AM
#7
Xtreme Mentor
No it's not, if u're running your vga wc'ed...
__________________
Watercooling setup:
05-21-2006, 04:22 AM
#8
the diode in side most of the expensive ones wont let u reverse the dirrection but if u buy an ell cheapo one fomr ebay they normally dont contain diodes so will reverse. problem solved. dropped my 66gt load temps buy 11 degrees by doing this.
__________________
athlon 64 4000,2x1gb XMS 4000@250mhz-2.5,3,3,7,leadtek 7800gtx extreme @550/1.39 stock volts,hiper type R 520W,400gb HD's.
05-21-2006, 12:40 PM
#9
Xtreme Cruncher
most pc fans are brushless and can't work in reverse from like you said a diode, they are contolled by a small chip and hooking it backwards would break it so they include the diode to protect it, and i think if you have a fan with a brush motor it's probably noisy
__________________
|Rig: AMD Athlon64 X2 6000+ Windsor|6gb DDR2 800|Dual 250gb Western Digital RAID0|8600GT|
(12:16:17 AM) OC3D NoL: NOL EAT ANNOYING NOOBIE
(12:16:19 AM) OC3D NoL: RAWRRRR
05-21-2006, 12:59 PM
#10
Steak for Breakfast
For low profile side blowers, they will not work even if you reverse it. If, however, you use a regular fan, it'll work, but won't suck air from the outside. Most PC-used fans are designed to spin one way, the other way generally won't work and won't be efficient due to the blade design.
05-21-2006, 01:02 PM
#11
check out the antec vcool
05-21-2006, 01:31 PM
#12
Steak for Breakfast
Yep, that's a traditional fan mounted inside a fan guide, that's why it requires 2 slots to get to something like 70% efficiency.
05-21-2006, 02:30 PM
#13
I am Xtreme
Antec V-Cool does iirc.
Nick
__________________
C2D E7200 @ 3.6GHz, 1.31v
Stock Q6600 HS/F
MSI P45 Neo3-FR
G.Skill 4GBPQ 8000's
Sapphire HD3870 Toxic 512MB
WD3200AAKS Single Platter
Enermax Liberty 500w
X-Fi XtremeMusic
CoolerMaster CM590
Vista Home Prem. X64 SP1
Westinghouse L2410NM
Logitech MX500, Saitek Eclipse, Logitech G25
05-21-2006, 05:31 PM
#14
Banned
I wc my videocard, I just made a bracket for 120mm and have it blowing on the card
05-22-2006, 11:38 AM
#15
Xtreme Mentor
Thanks for the info.
I'll check out if i can find v-cool here.
__________________
Watercooling setup:
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
