I look forward to reviewing these when I can get my paws on them![]()
it's never fast enough!
Anandtech has a review.
http://anandtech.com/memory/showdoc.aspx?i=2226&p=1
Everything extra is bad!
Originally Posted by Ubermann
That is previous product, rated DDR400 2-2-2-5/DDR560 3-4-4-8
However, personally, I can do DDR535 2.5-3-3-7![]()
OnePagebook that looking to be very good oc mem,becaus a still have to buy some sticks for my new a64 rig(first gone try my bh5's)i am tempted to get some of yours(you got PM btw)when will it be avalibel.
Asus P5K<*>OCZ 450w<*>E6600@4.0ghz@9x445@1.450v<*>TeamXtreem DDR2-800 cl3 2x1gb<*>Sapphire 3870 512mb DDR4
Asus P5E X48 DeLuxe<*>OCZ 700w<*>E8600 E0@4.6ghz@1.350v wc<*>Corsair Titanium DDR2-800 4x2gb<*>Sapphire 2x3870 2x512mb DDR4 CF
Do you handpick chip so they all run high ?
Yes! Bascially TCCD IC are all sameOriginally Posted by Ubermann
you mean most of the ics reach the same speed?
I finally got my tccd chips to run 276fsb 1:1 at 2.5-3-3-10 @1T. Awesome little sticks of mem!!
Originally Posted by saaya
Sorry about the confusion. What I mean is that Samsung TCCD just unique name for the IC, it doesn't have several kinds of specifications in terms of speed. The differce ram we list on web are just the effort we made(hand-pick and do serious stress testing) to let customers won't feel need to try for own luck (see if they can have the chance to get the awesome ram!)
Hope it clear some confusion!
Kev
stick-size?Originally Posted by Nimrod0031
512MB?
2x512MB?![]()
----- AMD K6-2 300 "Chomper" xxxxx xxxx xxxx /// 300 MHz @ 2,200 V -----
----- AMD Athlon XP 1700+ "Thouroghbred B" JIUHB 0306 MPMW /// 2400 MHz @ 1,900 V -----
----- AMD Athlon XP-M 2500+ "Barton" AQXEA 0327 UPMW /// 2450 MHz @ 1,850 V -----
----- AMD Athlon XP-M 2600+ "Barton" IQYHA 0401 XPMW /// 2500 MHz @ 1,750 V -----
----- AMD Athlon 64 3000+ "Newcastle CG" xxxxx 0418 WPMW /// 2600 MHz @ 1,600 V -----
----- AMD Athlon 64 3200+ "Winchester D0" xxxxx 0433 SPMW /// 2750 MHz @ 1,616 V -----
----- AMD Phenom II X2 555 BE "Callisto" xxxxx xxxx xxxx /// 4080MHz @ 1,375 V -----
----- AMD Ryzen "Zen" xxxxx xxxx xxxx /// TBA @ TBA -----
Hmm...wouldn't be nice if the factory was testing and ratting their IC's?Originally Posted by Onepagebook
Yup...it would be much better that way but....anyways....![]()
Hi
Onepagebook can you try GSkill TCCD on a AMD (32bit) system
cumps
here i found some prices ...
http://store.yahoo.com/digi4me/gskddrexseeo.html
hey tedy, welcome to XtremeSystems
nice prices!
Hehe, I like how there are different PC4400 sticks...some rated at 2.5-8-4-4 DDR550, other rated at 2.5-8-3-3 DDR550. Handpicked anyone?
Digi4me doesn't list any stock voltages though...I think I saw 2.5v on GSkill's site. Correct me if I'm wrong.
These are looking nice
http://store.yahoo.com/digi4me/gs1gbkit5x2d3.html
Less is more.
We are about to get a reseller here in sweden that will have Gskill in stock soon...I´ll order 1gig oc PC4800 as soon as they are in stock.
Yumyyy ....![]()
However I do have one question for Onepagebook ...have u guys tested how far they´ll go at 2-5-2-2 ...with both AMD and Intel plattforms..??
Please give a link if they can take online orders...
Originally Posted by Samael
They DO take online orders but it is all in swedish...and they don´t ship internationally...
Sorry m8![]()
afaik they are ALL 2.5-3-3-7 @ PC4400....Originally Posted by Gogeta
operating voltage.....hm, dunno, but onepagebook told a few times, that the optimal range is 2.6-2.9V....
Just received 2 pairs of GSkill RAMs and did some quick testing. Man, they are the real deal!! Due to some board problem (which OnePageBook helped me to solve - Thanks man!), I have not had enough time to find the max limit yet. But, as of now, it seems that both pairs can perform DDR560 2.5-3-3-7 at 2.7v vDIMM which is slightly above spec of DDR550. I ran all the typical RAM tests with no error at all. They probably still have some reserve to go higher. Or, I can try to raise the vdimm to 2.8v.
Here are some screenie during my tests.
BTW, I managed to run at DDR590 2.5-4-3-10 very quickly as shown here![]()
whats the performence hit when going from 2.5-3-3 to 2.5-3-4 ?
What kind of performance hit do you want me to measure? I can try to collect later. All I can tell for now is that the Sandra's INT unbuffered bandwidth only increased for a mere 20Mb/s. I guess this is one of the performance hit from using more relax timing here.
A 3dmark01 would be nice to see if there is any actual hit in performance![]()
Anyone know how these sticks perform on s754? Also what's the difference between F1-3200DSU1-1GBLE and F1-3200DSU1-1GBLF?
F1-3200DSU1-1GBLE
DDR I PC4400 2.5-3-3-7 PC3200 2-2-2-5 Dual channel kit
F1-3200DSU1-1GBLF
DDR I PC4400 2.5-3-3-7 PC3200 2-3-3-6 Dual channel kit
CPU: A64 3200+ 0501EPDW
Motherboard: DFI NF4 Ultra-D A.02 - Bios 2.17
Memory: 1GB GSkill LE 431
Graphics: Powercolor X850XT
PSU: OCZ PowerStream 520W
Storm G4 - H2O Cooled
