I was looking at your GF4 Ti4200 modding guide, and I had a question about it. I've got a PNY card, 64MB, and in your guide, there is a chip on the back of the card, on the upper right, that is one of the voltage ontrollers. I don't know if it controls the Vgpu or Vram, as you didn't specify in the article. The thing is, my card doesn't have that chip. Right above the chip on your card, I can see the letters U814, and on my card, U814 is indeed there, but its just a plain, white box, no chip there. Then on your card, there is the other chip on the upper left side of the back of the card. That one is marked U813 on your card. My card does have that U813 chip, but it's not the same kind of chip from your card. Mine only has 8 pins, 4 on each side, while your card's chip has 14 with 7 on each side. The only spot on my card that has a chip similar to the two on yours is at U816, on the lower right
of the card. I wanted to know if you could help me with my problem, I'd really like to Vmod this card, and unless it turns out that it's not possible with this card, I will be purchasing what I need from you. Please, if you can, help. I have linked some pictures of my card for you to see. Thanks for anything you can do for me Zack.
