OK i had my slk-900 seating on my desk for about 5 months to brush off the dust and mod it onto my stock 9800 xt card. First i cut off about 5 fins from each side with dremel. Thats about it.
The thing i was contemplating was how to mount it on. After several attempts to zip tie it, Light BULB sprang over my head. I can put the zip tie between the fins and right throw the heatsink into the the 2 holes in the card. Worked perfect.
I added some padding in the back and 2 springs. And i found a xtra 80mm fan from my new lian-li case and zip tied it to the heatsink. The fan from the lian-li case is so quiet.
<---I love that smiley
