+ Reply to Thread
Results 1 to 7 of 7
Thread: Removing Intel Northy S478 IHS...
    Xtreme Member Celeron Gamer's Avatar
    Jun 2005
    0
    Okay, I've removed the shim of epoxy around it, but it still barely budges, does this mean I've solder TIM? Cause I don't want to stick a soldering pencil at my CPU
    Nov 2005
    0
    Quote Originally Posted by Celeron Gamer
    I removed the IHS from a 1.6A and 1.8A but, IIRC, Northwood C's were the first to use epoxy/solder/whatever as the TIM, making it unremoveable. I never even tried with my 2.6C or 3.0C.
    FWIW, removing the IHS lowered my cpu temp by 2-3C and increased my max OC by 0MHz on the 1.6 and 1.8As...
    Jun 2005
    0
    osnap, I just heard a crack after heating it at 57C, :O
    Xtreme Member FunkyRider's Avatar
    Dec 2005
    Antarctica
    0
    Oops, you killed it?
    CPU: Very Fast!
    Memory: Very Big!
    Motherboard: Very Luxurious!
    Hard Disk: Very Hard!
    VGA: Very Long!
    Case: Very Flash!
    Coolers: Very Cool!
    Speakers: Very Loud!
    Xtreme Member d@rkn1ko's Avatar
    Nov 2003
    france -- lille
    0
    normaly there is any problems with northwood. you can removing the ihs
    Xeon 3060 L631B115 max 4680 superpi SS 10.904
    Asus P5B deluxe + vdrop vcore vddr2 vmch mods
    2x1go crucial ballistix pc8000
    2x1go crucial ballistix pc6400
    8800 gts 320 // x800xl // 9250 pci
    corsair hx 620 // seasonic s12 500
    DOD chilly1 R402a
    watercooling // zalman9700
    Xtreme Cruncher 2fink's Avatar
    Oct 2004
    Germany, near Stuttgart
    0
    you can remove the soldered ihs. you have to heat it up and then lift it slowly. have a look over at hardwareasylum. bbmods showed there how to do it!
    E2160 @ 360x9, max 390x9 watercooled
    GA-P35-DS3
    Cellshock D9GMH @ 545mhz cl5-5-5-5-15
    Palit 7300gt 500/1000 @ 780/1600 watercooled
    I am Xtreme NickS's Avatar
    Apr 2005
    Upstate, NY
    0
    Quote Originally Posted by 2fink
    Yeah, that snap you might have heard was the solder releasing.
    Good luck with it, be sure to post piccies
    Nick
    Core i3-550 Clarkdale @ 4.2GHz, 1.36v (Corsair A50 HS/F) LinX Stable
    MSI H55-GD65 Motherboard
    G.Skill 4GBRL DDR3-1600 @ 1755, CL9, 1.55v
    Sapphire Radeon 5750 1GB
    Samsung F4 320GB - WD Green 1TB
    Xigmatek Utgard Case - Corsair VX550
+ Reply to Thread
