X
    Subscribe to New Ads!
    Receive weekly ads in your inbox!
Results 1 to 10 of 10
Thread: Raptor RAID 0(2 X 74Gb)
    Xtreme Mentor
    May 2005
    Westlake Village, West Hills
    How do I fix this? Stripe size? Don't user silicon controller?
    PC Lab Qmicra V2 Case SFFi7 950 4.4GHz 200 x 22 1.36 volts
    Cooled by Swiftech GTZ - CPX-Pro - MCR420+MCR320+MCR220 | Completely Silent loads at 62c
    GTX 470 EVGA SuperClocked Plain stock
    12 Gigs OCZ Reaper DDR3 1600MHz) 8-8-8-24
    ASUS Rampage Gene II |Four OCZ Vertex 2 in RAID-0(60Gig x 4) | WD 2000Gig Storage
    Theater ::: Panasonic G20 50" Plasma | Onkyo SC5508 Processor | Emotiva XPA-5 and XPA-2 | CSi A6 Center| 2 x Polk RTi A9 Front Towers| 2 x Klipsch RW-12d
    Lian-LI HTPC | Panasonic Blu Ray 655k| APC AV J10BLK Conditioner |
    Evil Kitty
    Jun 2002
    Detroit, MI
    Use the Nvidia controller
    Defrag the array
    Turn off command queing
    9900k @ 5.1Ghz
    Asus Maximus Hero XI
    32GB (8 x 4) Gskill @4000
    Strix 2080 Ti OC
    OS & Apps: Samsung 970 Pro 512GB
    Games: Samsung 970 Pro 1TB
    Storage: Crucial M500 2TB
    Seasonic Platinum 1000W
    Phanteks Evolv X
    Evil Kitty
    Jun 2002
    Detroit, MI
    No, he's definitely running a bit slower than he should be for a pair of raid 74g raptors. Burst speed should be well over 200 MB/s, and sustained sequential read should be a bit over 100.0 MB/s. His bench isn't bad, but it can definitely be tweaked.
    9900k @ 5.1Ghz
    Strix 2080 Ti OC
    Phanteks Evolv X
    Xtreme Mentor
    May 2005
    SATA 150mb/s limit is for one drive.
    I'll see if that helps.
    Xtreme Mentor
    May 2005
    I don't see an option for that with the Sili controller.
    I think the NB controller is what I should have used, does anyone know of chipset drivers that will allow this with Raptor RAID? 6.7 and 6.66 doesn't work with Raptors and NF4 for me.
    It's also just defragged, I really need to find drivers to make them work. What does everyone else with Raptors in raid use in an NF4?
    Evil Kitty
    Jun 2002
    Detroit, MI
    Run off the Nvidia controller.
    Use these simple 6.70 NF4 drivers.
    http://www.nvidia.com/object/nforce_..._amd_6.70.html
    Then:
    Device manager>ATA ATAPI Controllers>nforce 4 Serial ATA Controller
    Right Click for Properties, then go to Primary and Secondary Channel tabs. Deselect NCQ.
    Go to this thread for more good info:
    http://www.xtremesystems.org/forums/...ad.php?t=98643
    Quote Originally Posted by Nanometer
    9900k @ 5.1Ghz
    Strix 2080 Ti OC
    Phanteks Evolv X
    Xtreme Mentor
    May 2005
    I used those drivers, but there were still problems getting the raptors to run in RAID 0. Alsom why dissable native command queing?
    Evil Kitty
    Jun 2002
    Detroit, MI
    NCQ is for the server environment with a large number of file requests coming in simultaneously. For desktop use NCQ adds nothing and slows things down.
    9900k @ 5.1Ghz
    Strix 2080 Ti OC
    Phanteks Evolv X
    xtreme energy
    Oct 2004
    Europe, Latvia
    Are you using PCI raid card? If using PCI card (I have promise) for raid I have the same low performance and I have no idea how to improve it. Using nvraid shows fine numbers though, check here:
    http://www.xtremesystems.org/forums/...ad.php?t=99487
    I am Xtreme
    Oct 2004
    U.S.A.
    there's info in this thread I posted that might help
    http://www.xtremesystems.org/forums/...highlight=raid
    Asus Z9PE-D8 WS with 64GB of registered ECC ram.|Dell 30" LCD 3008wfp:7970 video card
    LSI series raid controller
    SSDs: Crucial C300 256GB
    Standard drives: Seagate ST32000641AS & WD 1TB black
    OSes: Linux and Windows x64
