nice cpu clock...what's the temperature at those speeds?
Got a pic of the CPU?
Woohoo ... your cascade looks neat !
Originally Posted by farksy
lool chek the pic again this is single stage
well done as i said be4
you need better cooling for the WR ^^
. . . WHO put this thing together? ME !
. . . WHO do i trust? ME !
. . . f*** it, as****
Best Stepping of Opteron 14X,isn't it!
Originally Posted by splmann
wahou HTT 391 Temp cpu please ??? cabne 0530apmw is not cold bug ???
Very Nice o/c
Nice work!!...
I second this question... 391HTT is truely amazing under phase! I would like to have such a chip for my cascade.Originally Posted by boblemagnifique
splmann, what was your idle temp?
Best Regards,
Xavier
"I prefer to fly alone... when alone, I perform those little coups of audacity which amuse me..." Col. René Fonck (1894-1953), the Ace of Aces.
A small Update !!!
http://valid.x86-secret.com/show_oc?id=94661
Nice and what temps do you have in windows idle/load?
Do you have HS off or on?
tnx
My Work: LittleDevil's SS Cases, LittleDevil's SS Worklog, LD CPU-R1 Dice/LN² Pots, LD GFX-R1 Dice/LN² Pots,
LittleDevil LD PC-V10, LittleDevil's K-Type Temp Display, |EMAIL: ldphasechange@gmail.com
LD PC-V8 Watercooling Cases: LINK
LD PC-V8 ATX/HPTX Watercoolig PC case with 10 expansion slots: LINK NEW!
www.ldcooling.com
Find US on Facebook
Keep it up; that's great mate!
Best Regards,
Xavier
Onwards and upwards!! Good results
Main rig:
CPU: I7 920C0 @ 3.6Ghz (180*20)
Mobo: DFI UT X58 T3eH8
RAM: 12GB OCZ DDR3-1600 Platinum
GPU/LCD: GeForce GTX280 + GeForce 8600GTS (Quad LCDs)
Intel X25-M G2 80GB, 12TB storage
PSU/Case: Corsair AX850, Silverstone TJ07
Very nice. You have a64tweaker pic of the 391 settings?
Very nice
Grtz
DFI Lanparty nF4 SLI-D || AMD Athlon64 4000+ SD || 7900 GT|| GEIL 2*512mb BH-5 @250 Mhz 2-2-2-5 ||2*256 Old BH-5 285Mhz 2-2-2-5 || Tagan 530W
Super Pi: 25s:Pic
@all Thanks
here a small Update!
http://valid.x86-secret.com/show_oc?id=94852
Regards from Switzerland
Roger
If you need one I can build you oneOriginally Posted by splmann
Buying parts for new cascade with better layout at the moment. Will start it next week.
Very nice clocks, this CPU is awesome!!
Nice CPU you got there ...
Go for WR : http://valid.x86-secret.com/show_oc.php?id=47280
Only 70MHz left
That cpu seems to be a golden one, try to freeze it futher down Anyway your singlestage look absolutely great
My Rig:
Intel Core 2 Duo E6400
2x512mb Micron PC3200 OEM D9DQW "Fatbody"
Biostar TForce P965 Deluxe
MSI/Medion GeForce 6700XL (Cheap )
Chieftec 360W (in search for someting better)
WD 160GB S-ATA
So close !!!!!! only 49 MHz
Still under Single Stage !!!
http://valid.x86-secret.com/show_oc?id=95188
Roger
