I have to run my ram at Cas 2.5-3-3-6. I'm curious whether 3200MB/sec is a good Sandra score for 200fsb.
Thanks!
Thanks!
3200 would be the calculated max for 200 FSB. Unless you have a chipset "bug" that allows the memory to run faster (like due to multiple concurrent fetches) it's the very best you can get on dual-pumped memory. Quad-pumped, like on the P4 boards, would net a higher theoretical max at 200, namely 6400.
The plural of "anecdote" is not "data."
This was my first time running Sandra. I just looked at it again and realized my 3200 figure was the estimated maximum bandwidth, not my benchmark score.
How do I tell what my score is? People mention a single number, but there are lots of results.
look at the graph at the top and it will show two numbers at the end. The first is what most will talk about, and what your 3200mb/s is reffering to.
| MSI K8N Diamond Plus | WaterCooled A64X2 4200+ | 2x1024 PC4000 EB Plat | 2x BFG 7800GT | Maxtor DMax 10 SATA 250gb 16mb cache & 200gb 8 mb cache| OCZ 700watt GamerXtreme PSU | Plextor 716SA DL DVDRW
HeatWare
